Topic "BUG: Swedish chars in password"
farrington
I have noticed that you are not able to log on to a server if the password contains letters other than a-zA-Z.
At least the character "" (only tested with lowercase ) is passed faulty, and thereby the login attempt fails.
Runs WinSCP 4.2.7 (Build 758) with Commander interface on Windows XP SP3.
The protocol used is FTP, but as I haven't tried on other protocols I don't know if other protocols are affected.
I have tried to log in on the server in this case with another ftp-client, without failing to log in.
/marcus
farrington
. 2010-03-26 17:07:52.906 --------------------------------------------------------------------------
. 2010-03-26 17:07:52.906 WinSCP Version 4.2.7 (Byggd 758) (OS 5.1.2600 Service Pack 3)
. 2010-03-26 17:07:52.906 Login time: den 26 mars 2010 17:07:52
. 2010-03-26 17:07:52.906 Session name: Kunder - ********
. 2010-03-26 17:07:52.906 Host name: ftp.********.se (Port: 21)
. 2010-03-26 17:07:52.921 User name: ********** (Password: Yes, Key file: No)
. 2010-03-26 17:07:52.921 Tunnel: No
. 2010-03-26 17:07:52.921 Transfer Protocol: FTP
. 2010-03-26 17:07:52.921 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2010-03-26 17:07:52.921 Proxy: none
. 2010-03-26 17:07:52.921 FTP: FTPS: None; Passive: No [Force IP: No]
. 2010-03-26 17:07:52.921 Local directory: C:\, Remote directory: home, Update: No, Cache: Yes
. 2010-03-26 17:07:52.921 Cache directory changes: Yes, Permanent: Yes
. 2010-03-26 17:07:52.921 DST mode: 1
. 2010-03-26 17:07:52.921 --------------------------------------------------------------------------
. 2010-03-26 17:07:53.000 Ansluter till ftp.<cut-out>.se ...
. 2010-03-26 17:07:53.000 Ansluten med ftp.<cut-out>.se. Vntar p vlkomstmeddelande...
< 2010-03-26 17:07:53.000 220-Welcome to <cut-out> FTP
< 2010-03-26 17:07:53.000 220-You are user number 6 of 150 allowed.
< 2010-03-26 17:07:53.000 220-Local time is now 17:07. Server port: 21.
< 2010-03-26 17:07:53.015 220 You will be disconnected after 30 minutes of inactivity.
> 2010-03-26 17:07:53.015 USER <cut-out>
< 2010-03-26 17:07:53.015 331 User <cut-out> OK. Password required
> 2010-03-26 17:07:53.015 PASS ***********
< 2010-03-26 17:07:53.062 530 Authentication failed, sorry
. 2010-03-26 17:07:53.062 Anslutning misslyckades.
. 2010-03-26 17:07:53.062 Password prompt (no password provided or last login attempt failed)
* 2010-03-26 17:07:59.968 (ESshFatal) Autentisering misslyckades.
In what encoding does the server accept the password?
farrington
I have no idea, but since it works to login with the Windows command line ftp client...
UTF-8 I guess.
Well, works in FileZilla... Crying or Very sad (Don't say I have to get use to FileZilla...)
/marcus
OK, I'll check it.
farrington
Well... new version, and still this behavior.
Maybe I should post a bug report in the tracker... (but that's not open for me)
I'm working on Unicode version of WinSCP. Though it is huge task, so it takes a time.
farrington
Awesome man, looking forward to that.
