Topic ""FTPES" and "Moving from FileZilla""
klininger
I have almost the exact scenario as http://winscp.net/forum/viewtopic.php?t=7112
It's a FTPES connection that I'm trying to make.
Here's the filezilla log:
Status:   Resolving address of xxx.xxx.com
Status:   Connecting to xx.xx.xx.xx:21...
Status:   Connection established, waiting for welcome message...
Response:   220 Welcome to xxx.
Command:   AUTH TLS
Response:   234 AUTH command OK. Initializing SSL connection.
Status:   Initializing TLS...
Status:   Verifying certificate...
Command:   USER xxx
Status:   TLS/SSL connection established.
Response:   331 User name okay, need password.
Command:   PASS *********
Response:   230 User logged in, proceed.
Command:   SYST
Response:   215 UNIX Type: L8
Command:   FEAT
Response:   211-Extension supported
Response:    AUTH TLS
Response:    SSCN
Response:    PBSZ
Response:    PROT
Response:    CCC
Response:    CLNT
Response:    MDTM
Response:    MDTM YYYYMMDDHHMMSS[+-TZ];filename
Response:    SIZE
Response:    SITE PSWD;EXEC;SET;INDEX;ZONE;CHMOD;MSG
Response:    REST STREAM
Response:    XCRC filename;start;end
Response:    MODE Z
Response:    MLST Type*;Size*;Create;Modify*;Win32.ea*;
Response:   211 End
Command:   PBSZ 0
Response:   200 PBSZ command OK. Protection buffer size set to 0.
Command:   PROT P
Response:   200 PROT command OK. Using private data connection.
Status:   Connected
Status:   Retrieving directory listing...
Command:   PWD
Response:   257 "/" is current directory.
Command:   TYPE I
Response:   200 Type set to I.
Command:   PASV
Response:   227 Entering Passive Mode (65,160,41,58,78,34)
Command:   MLSD
Response:   150 Opening BINARY mode data connection for MLSD.
Response:   226 Transfer complete.
Status:   Directory listing successful
Response:   421 Connection timed out - closing.
. 2010-04-08 13:27:26.924 --------------------------------------------------------------------------
. 2010-04-08 13:27:26.924 WinSCP Version 4.2.7 (Build 758) (OS 5.1.2600 Service Pack 3)
. 2010-04-08 13:27:26.924 Login time: Thursday, April 08, 2010 1:27:26 PM
. 2010-04-08 13:27:26.924 Session name: xxx
. 2010-04-08 13:27:26.924 Host name: xxx.xxx.com (Port: 21)
. 2010-04-08 13:27:26.924 User name: xxx (Password: Yes, Key file: No)
. 2010-04-08 13:27:26.924 Tunnel: No
. 2010-04-08 13:27:26.924 Transfer Protocol: SFTP (SCP)
. 2010-04-08 13:27:26.924 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2010-04-08 13:27:26.924 Proxy: none
. 2010-04-08 13:27:26.924 SSH protocol version: 2; Compression: No
. 2010-04-08 13:27:26.924 Bypass authentication: No
. 2010-04-08 13:27:26.924 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2010-04-08 13:27:26.924 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2010-04-08 13:27:26.924 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2010-04-08 13:27:26.924 SFTP Bugs: -,-
. 2010-04-08 13:27:26.924 Return code variable: Autodetect; Lookup user groups: Yes
. 2010-04-08 13:27:26.924 Shell: default, EOL: 0
. 2010-04-08 13:27:26.924 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2010-04-08 13:27:26.924 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2010-04-08 13:27:26.940 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-04-08 13:27:26.940 Cache directory changes: Yes, Permanent: Yes
. 2010-04-08 13:27:26.940 DST mode: 1
. 2010-04-08 13:27:26.940 --------------------------------------------------------------------------
. 2010-04-08 13:27:27.096 Looking up host "xxx.xxx.com"
. 2010-04-08 13:27:27.096 Connecting to 10.10.75.23 port 21
. 2010-04-08 13:27:27.158 Waiting for the server to continue with the initialisation
. 2010-04-08 13:27:27.158 Detected network event
. 2010-04-08 13:27:31.721 Detected network event
. 2010-04-08 13:27:31.721 Waiting for the server to continue with the initialisation
. 2010-04-08 13:27:46.721 Waiting for data timed out, asking user what to do.
. 2010-04-08 13:27:46.721 Asking user:
. 2010-04-08 13:27:46.721 Host is not communicating for 15 seconds.
. 2010-04-08 13:27:46.721 Wait for another 15 seconds? ()
. 2010-04-08 13:27:52.330 Attempt to close connection due to fatal exception:
* 2010-04-08 13:27:52.330 Terminated by user.
. 2010-04-08 13:27:52.330 Closing connection.
. 2010-04-08 13:27:52.330 Sending special code: 12
* 2010-04-08 13:27:52.330 (ESshFatal) Terminated by user.
Any ideas?
I appreciate your help!
You are starting SFTP, not FTPS, connection with WinSCP. Make sure to use FTPS.
klininger
prikryl,
Thanks for the reply. Sorry for being dense (I'm not an FTP expert)...My drop down box doesn't have an FTPS option.
I started trying all options. I selected FTP, and then selected TLS Explicit encryption. This allowed me to connect and login. Again, not knowing much about FTP, I'm sure FTPS somehow does translate into what I did.
Anyway, I'm up and running. Thanks!
Kurt
