Topic "Parameters not working for encryption type"
JimGriffith
I'm trying to setup a script that specifies an explicit connection using port 21. If I use ftps in the session it tries to connect over 990. If I use ftp it tries to connect with no encryption. I've tried putting the parameters in multiple places with the same results.
script:
open ftps:user:pass@ftps.siteaddress.com /passive /explicitssl
option transfer binary
Results: connects to 990 using implicit encryption
script:
open ftp:user:pass@ftps.siteaddress.com /passive /explicitssl
results: connection via port 21 with no encryption
I've tried putting in the command line in different places as well
winscp.exe /script=c:\script.txt /passive /explicitssl /log=c:\log.txt
winscp.exe /passive /explicitssl /script=c:\script.txt /log=c:\log.txt
winscp.exe /script=c:\script.txt /log=c:\log.txt /passive /explicitssl
It appears to be ignoring the passive and encryption parameters and relying strictly on the protocol for it's connection method. Any suggestions? Thanks!
Sorry, not having enough time to read this carefully. What is this different to the problem we have already solved?
JimGriffith
The previous issue was specifying a port number. This issue is using the /explicitssl and /explicittls parameters. It's not recognizing these.
