Topic "Can I find out how full the remote disk is using winscp?"
john.grassby@...
I keep loading pictures to my server. Its a sun. Is there something like Windows explorer where I can seect properties and find out how full the disk is???
No it is not possible.
Jim
Erm.. Yes there is...
You can use the console button to run a command like `df -kP` that prints out the disk space usage.... Smile
Ok, yes. However it should be noted that it works only with SCP protocol and on unix servers.
sma1353
yes if you go to propertires and hit calculate and try to use NC format
