Topic "synchronize changed file sequence in 4.7"
jensm
I just upgraded from 4.3 to 4.7. I found that the synchronize feature now transfers file in a different order. With 4.3 it appeared to either copy older files first or it sorted the files by filename and then transferred in that order. I can't tell how it was done because my filenames use timestamps.
With 4.7 files are transferred in random order which causes my app to break. Is there a way to configure that?
Thanks!
Jens
No it is not configurable.
