Topic "winscp not working - timeout.."
czekker
i try to use v3.4.2
after prompting for password it says `starting the session` and after 30s (i increased the default 15s) gets timeout and says:
`host hasn't answered for 30 seconds`
the server logs looks ok:
> Dec 12 23:29:07 server.edu.pl sshd[10479]: Accepted password for username from xxx.xxx.xx.xxx port 1316 ssh2
> Dec 12 23:29:07 server.edu.pl sshd[10481]: subsystem request for sftp
and here goes the winscp log:
. WinSCP Version 3.4.2 (Build 197)
. Login time: 13 dec 2003 17:10:03
. Session name: server.edu.pl
. Host name: server.edu.pl (Port: 22)
. User name: username (Password: No, Key file: No)
. Transfer Protocol: SFTP
. SSH protocol version: 2 only; Compression: No
. Ping interval: 55 sec (0 = off); Timeout: 30 sec
. SSH Bugs: -,-,-,-,-,-,-,-,
. Proxy: none
. Shell: default, EOL: 0
. Local directory: E:\My Documents, Remote directory: home, Update: No, Cache: Yes
. Looking up host "server.edu.pl"
. Connecting to server.edu.pl port 22
. Server version: SSH-2.0-OpenSSH_3.7.1p1
. We claim version: SSH-2.0-WinSCP-release-3.4.2.197
. Host key fingerprint is:
. ssh-rsa 1024 6a:2c:e0:79:e8:3b:e9:d2:69:23:05:08:cc:68:fd:4c
! Using username "username".
. Keyboard-interactive authentication refused
. Session password prompt (username@server.edu.pl's password: )
. Asking user for password.
. Sent password
. Access granted
. Opened channel for session
. Started a shell/command
. Using SFTP protocol.
> Type: SSH_FXP_INIT, Size: 5, Number: -1
. Waiting for data timed out, asking user what to do.
. Asking user:
. Host hasn't answered for 30 seconds.
. Wait for another 30 seconds? Pressing 'Abort' button will close session. ()
. Attempt to close connection due to fatal exception:
* Terminated by user.
. Closing connection.
* (ESshFatal) Cannot initialize SFTP protocol. Is the host running a SFTP server?
any ideas?
thanx for help....
czekker wrote:
i try to use v3.4.2
well, the problem was with my `.profile` file....
now it's workin' great!
