Topic "WinSCP in fully potable configuration and portaPuTTY"
maiux
Hello. I use both WinSCP (fully portable mode) and PortaPuTTY.
Integration fails: opening a WinSCP temporary session in PortaPuTTY will result in PortaPuTTY's configuration dialog.
I think I diagnosed the problem: PortaPuTTY stores sessions in .ini files put in .putty folder near the putty.exe
It will ignore the registry session data. How come out from this issue?
For reference: http://code.google.com/p/portaputty/
Many thanks
WinSCP does not support with format of PuTTY configuration.
