Topic "using open command with -hostkey="xxx" on the commandline?"
Jace
To specify commands on the command-line, you have to use:
winscp /command "xxx" "yyy" etc
with xxx, yyy, etc being the commands you want to execute.
Now, I want to put an open command on the command-line, including the -hostkey="xxx" option. Problem is, both the hostkey (which contains spaces), as well as the whole open command, need to be placed in quotes (").
I tried this, for example:
winscp /command "open sftp://name:pasw@domain.com -hostkey=""ssh-rsa 2048 00:11:22:33:44:55:66:77:88:99:aa:bb:cc:dd:ee:ff"""
and several other variants, but it doesn't work.
Is there any way to work around this? (besides demanding that the fingerprint is stored in the .ini file)
The above syntax is correct. Are you using the latest version of WinSCP?
Jace
I think so, version 4.2.7 build 758 ?
(edit) sorry, my bad, apparently I made a mistake before, just tried again and it seems to work! Embarassed
