Topic "Script to GET files without replace"
Floribar
Hi everybody,
I have a FTP server where lots of diferents files are stored and most of them not mine.
(I cannot use the command "synchronise"...)
Using an SSIS PAckage, i get the proper files using a mask with the
"get" command.
It works fine, except that I am getting lots of file now, and I wish not to get the ones I already have.
I mean to use the "get" command in a batch, but where the option "confirm replace" would be "NO".
How can I do that?.
I have been trying the diferent options "Batch", "confirm" and I am still downloading the one I have got.
Thanks for your help.
What is the reason you cannot use synchronize?
Floribar
in the ftp folder, theres are lots of file which have nothing to do with my project and that I shouldn't copy in my destination folder.
I only want some with have a certain format name ( e.i: BE100302_20100420_ATCR7888.030.2009041.csv).
In this folder FTP, there are word document, zip,... I don't want all these files sinchronised.
Is it posible to sinchronise only the files type I need with a mask?
o is it posible to get with batch without the Replace option?
Thanks.
Yes.
option include <mask>
Floribar
Perfect!
Will try it right now!
Floribar
Thanks a lot!
It works perfectly!
