Topic "SFTP -> Status code: 2, Message: 259, Server: No such file.."
cjw
I can connect using ftp an sftp. I can upload with ftp, but uploading using sftp gives error. First I'll give you ftp upload log and afterwards sftp upload log containing error. What do I need to change to be able to upload using sftp?
This is my upload script
echo on
option batch on
open ftp://username:password@hostname
cd /files/sql
option transfer binary
put -delete c:\backup\files\sql\*.*
close
ftp upload log:
. 2010-04-27 14:58:16.153 --------------------------------------------------------------------------
. 2010-04-27 14:58:16.153 WinSCP Version 4.2.7 (Build 758) (OS 5.2.3790 Service Pack 2)
. 2010-04-27 14:58:16.153 Login time: dinsdag 27 april 2010 14:58:16
. 2010-04-27 14:58:16.153 Session name: username@hostname
. 2010-04-27 14:58:16.153 Host name: hostname (Port: 21)
. 2010-04-27 14:58:16.153 User name: username (Password: Yes, Key file: No)
. 2010-04-27 14:58:16.153 Tunnel: No
. 2010-04-27 14:58:16.153 Transfer Protocol: FTP
. 2010-04-27 14:58:16.153 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2010-04-27 14:58:16.153 Proxy: none
. 2010-04-27 14:58:16.153 FTP: FTPS: None; Passive: No [Force IP: No]
. 2010-04-27 14:58:16.153 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-04-27 14:58:16.153 Cache directory changes: Yes, Permanent: Yes
. 2010-04-27 14:58:16.153 DST mode: 1
. 2010-04-27 14:58:16.153 Connecting to hostname ...
. 2010-04-27 14:58:16.169 Connected with hostname. Waiting for welcome message...
< 2010-04-27 14:58:16.169 220 (vsFTPd 2.0.5)
> 2010-04-27 14:58:16.169 USER username
< 2010-04-27 14:58:16.185 331 Please specify the password.
> 2010-04-27 14:58:16.185 PASS ****************
< 2010-04-27 14:58:16.185 230 Login successful.
> 2010-04-27 14:58:16.185 SYST
< 2010-04-27 14:58:16.200 215 UNIX Type: L8
> 2010-04-27 14:58:16.200 FEAT
< 2010-04-27 14:58:16.200 211-Features:
< 2010-04-27 14:58:16.200  EPRT
< 2010-04-27 14:58:16.200  EPSV
< 2010-04-27 14:58:16.200  MDTM
< 2010-04-27 14:58:16.200  PASV
< 2010-04-27 14:58:16.200  REST STREAM
< 2010-04-27 14:58:16.200  SIZE
< 2010-04-27 14:58:16.200  TVFS
< 2010-04-27 14:58:16.200 211 End
. 2010-04-27 14:58:16.200 Connected
. 2010-04-27 14:58:16.200 --------------------------------------------------------------------------
. 2010-04-27 14:58:16.200 Using FTP protocol.
. 2010-04-27 14:58:16.200 Doing startup conversation with host.
> 2010-04-27 14:58:16.200 PWD
< 2010-04-27 14:58:16.216 257 "/"
. 2010-04-27 14:58:16.216 Getting current directory name.
. 2010-04-27 14:58:16.216 Startup conversation with host finished.
. 2010-04-27 14:58:16.216 Cached directory change via "/files/sql" to "/files/sql".
. 2010-04-27 14:58:16.216 Copying 2 files/directories to remote directory "/files/sql"
. 2010-04-27 14:58:16.216   PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-04-27 14:58:16.216   TM: B; ClAr: No; CPS: 0; ExclM(No):
. 2010-04-27 14:58:16.216   AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-04-27 14:58:16.216 File: "c:\backup\files\sql\q1.txt"
. 2010-04-27 14:58:16.216 Copying "c:\backup\files\sql\q1.txt" to remote directory started.
. 2010-04-27 14:58:16.216 Binary transfer mode selected.
. 2010-04-27 14:58:16.216 Starting upload of c:\backup\files\sql\q1.txt
> 2010-04-27 14:58:16.216 CWD /files/sql/
< 2010-04-27 14:58:16.216 250 Directory successfully changed.
> 2010-04-27 14:58:16.216 PWD
< 2010-04-27 14:58:16.216 257 "/files/sql"
> 2010-04-27 14:58:16.216 TYPE A
< 2010-04-27 14:58:16.232 200 Switching to ASCII mode.
> 2010-04-27 14:58:16.232 PORT 193,219,116,196,6,194
< 2010-04-27 14:58:16.232 200 PORT command successful. Consider using PASV.
> 2010-04-27 14:58:16.232 LIST
< 2010-04-27 14:58:16.247 150 Here comes the directory listing.
< 2010-04-27 14:58:16.247 226 Directory send OK.
> 2010-04-27 14:58:16.247 TYPE I
< 2010-04-27 14:58:16.247 200 Switching to Binary mode.
> 2010-04-27 14:58:16.247 PORT 193,219,116,196,6,195
< 2010-04-27 14:58:16.263 200 PORT command successful. Consider using PASV.
> 2010-04-27 14:58:16.263 STOR q1.txt
< 2010-04-27 14:58:16.263 150 Ok to send data.
< 2010-04-27 14:58:16.278 226 File receive OK.
. 2010-04-27 14:58:16.278 Upload successful
. 2010-04-27 14:58:16.278 File: "c:\backup\files\sql\q2.txt"
. 2010-04-27 14:58:16.278 Copying "c:\backup\files\sql\q2.txt" to remote directory started.
. 2010-04-27 14:58:16.278 Binary transfer mode selected.
. 2010-04-27 14:58:16.278 Starting upload of c:\backup\files\sql\q2.txt
> 2010-04-27 14:58:16.278 TYPE I
< 2010-04-27 14:58:16.278 200 Switching to Binary mode.
> 2010-04-27 14:58:16.278 PORT 193,219,116,196,6,196
< 2010-04-27 14:58:16.294 200 PORT command successful. Consider using PASV.
> 2010-04-27 14:58:16.294 STOR q2.txt
< 2010-04-27 14:58:16.310 150 Ok to send data.
< 2010-04-27 14:58:16.310 226 File receive OK.
. 2010-04-27 14:58:16.310 Upload successful
. 2010-04-27 14:58:16.310 Disconnected from server
This is my upload script using sftp. Only the open line is different
open sftp://username:password@hostname -hostkey="ssh-rsa 1024 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
sftp upload log containing error:
. 2010-04-27 14:48:26.783 --------------------------------------------------------------------------
. 2010-04-27 14:48:26.783 WinSCP Version 4.2.7 (Build 758) (OS 5.2.3790 Service Pack 2)
. 2010-04-27 14:48:26.783 Login time: dinsdag 27 april 2010 14:48:26
. 2010-04-27 14:48:26.783 Session name: username@hostname
. 2010-04-27 14:48:26.783 Host name: hostname (Port: 22)
. 2010-04-27 14:48:26.783 User name: username (Password: Yes, Key file: No)
. 2010-04-27 14:48:26.783 Tunnel: No
. 2010-04-27 14:48:26.783 Transfer Protocol: SFTP
. 2010-04-27 14:48:26.783 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2010-04-27 14:48:26.783 Proxy: none
. 2010-04-27 14:48:26.783 SSH protocol version: 2; Compression: No
. 2010-04-27 14:48:26.783 Bypass authentication: No
. 2010-04-27 14:48:26.783 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2010-04-27 14:48:26.783 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2010-04-27 14:48:26.783 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2010-04-27 14:48:26.783 SFTP Bugs: -,-
. 2010-04-27 14:48:26.783 Return code variable: Autodetect; Lookup user groups: Yes
. 2010-04-27 14:48:26.783 Shell: default, EOL: 0
. 2010-04-27 14:48:26.783 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2010-04-27 14:48:26.783 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2010-04-27 14:48:26.783 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-04-27 14:48:26.783 Cache directory changes: Yes, Permanent: Yes
. 2010-04-27 14:48:26.783 DST mode: 1
. 2010-04-27 14:48:26.783 Looking up host "hostname"
. 2010-04-27 14:48:26.783 Connecting to hostname port 22
. 2010-04-27 14:48:26.814 Server version: SSH-2.0-OpenSSH_4.3p2 Debian-9etch3
. 2010-04-27 14:48:26.814 Using SSH protocol version 2
. 2010-04-27 14:48:26.814 We claim version: SSH-2.0-WinSCP_release_4.2.7
. 2010-04-27 14:48:26.814 Doing Diffie-Hellman group exchange
. 2010-04-27 14:48:26.861 Doing Diffie-Hellman key exchange with hash SHA-1
. 2010-04-27 14:48:27.033 Host key fingerprint is:
. 2010-04-27 14:48:27.033 ssh-rsa 1024 f8:3b:f3:cc:66:87:ec:03:f3:1d:f3:96:cd:45:74:82
. 2010-04-27 14:48:27.033 Initialised AES-256 SDCTR client->server encryption
. 2010-04-27 14:48:27.033 Initialised HMAC-SHA1 client->server MAC algorithm
. 2010-04-27 14:48:27.033 Initialised AES-256 SDCTR server->client encryption
. 2010-04-27 14:48:27.033 Initialised HMAC-SHA1 server->client MAC algorithm
! 2010-04-27 14:48:27.080 Using username "username".
. 2010-04-27 14:48:27.095 Prompt (5, SSH server authentication, Using keyboard-interactive authentication., Password: )
. 2010-04-27 14:48:27.095 Using stored password.
. 2010-04-27 14:48:27.095 Prompt (5, SSH server authentication, , <no prompt>)
. 2010-04-27 14:48:27.095 Ignoring empty SSH server authentication request
. 2010-04-27 14:48:27.111 Access granted
. 2010-04-27 14:48:27.111 Opened channel for session
. 2010-04-27 14:48:27.173 Started a shell/command
. 2010-04-27 14:48:27.173 --------------------------------------------------------------------------
. 2010-04-27 14:48:27.173 Using SFTP protocol.
. 2010-04-27 14:48:27.173 Doing startup conversation with host.
> 2010-04-27 14:48:27.173 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2010-04-27 14:48:27.173 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2010-04-27 14:48:27.173 SFTP version 3 negotiated.
. 2010-04-27 14:48:27.173 We believe the server has signed timestamps bug
. 2010-04-27 14:48:27.173 We will use UTF-8 strings for status messages only
. 2010-04-27 14:48:27.173 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2010-04-27 14:48:27.173 Getting current directory name.
. 2010-04-27 14:48:27.173 Getting real path for '.'
> 2010-04-27 14:48:27.173 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2010-04-27 14:48:27.189 Type: SSH_FXP_NAME, Size: 51, Number: 16
. 2010-04-27 14:48:27.189 Real path is '/home/username'
. 2010-04-27 14:48:27.189 Startup conversation with host finished.
. 2010-04-27 14:48:27.189 Cached directory change via "/files/sql" to "/files/sql".
. 2010-04-27 14:48:27.189 Getting current directory name.
. 2010-04-27 14:48:27.189 Copying 2 files/directories to remote directory "/files/sql"
. 2010-04-27 14:48:27.189   PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-04-27 14:48:27.189   TM: B; ClAr: No; CPS: 0; ExclM(No):
. 2010-04-27 14:48:27.189   AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-04-27 14:48:27.189 File: "c:\backup\files\sql\q1.txt"
. 2010-04-27 14:48:27.189 Copying "c:\backup\files\sql\q1.txt" to remote directory started.
. 2010-04-27 14:48:27.189 Binary transfer mode selected.
. 2010-04-27 14:48:27.189 Opening remote file.
> 2010-04-27 14:48:27.189 Type: SSH_FXP_OPEN, Size: 42, Number: 259
< 2010-04-27 14:48:27.189 Type: SSH_FXP_STATUS, Size: 29, Number: 259
< 2010-04-27 14:48:27.189 Status code: 2, Message: 259, Server: No such file, Language:
> 2010-04-27 14:48:27.189 Type: SSH_FXP_LSTAT, Size: 26, Number: 519
< 2010-04-27 14:48:27.189 Type: SSH_FXP_STATUS, Size: 29, Number: 519
< 2010-04-27 14:48:27.189 Status code: 2, Message: 519, Server: No such file, Language:
* 2010-04-27 14:48:27.189 (ETerminal) No such file or directory.
* 2010-04-27 14:48:27.189 Error code: 2
* 2010-04-27 14:48:27.189 Error message from server: No such file
* 2010-04-27 14:48:27.189 Request code: 3
. 2010-04-27 14:48:27.189 Asking user:
. 2010-04-27 14:48:27.189 Cannot create remote file '/files/sql/q1.txt'. ("No such file or directory.
. 2010-04-27 14:48:27.189 Error code: 2
. 2010-04-27 14:48:27.189 Error message from server: No such file
. 2010-04-27 14:48:27.189 Request code: 3")
* 2010-04-27 14:48:27.189 (EScpSkipFile) Cannot create remote file '/files/sql/q1.txt'.
* 2010-04-27 14:48:27.189 No such file or directory.
. 2010-04-27 14:48:27.189 Closing connection.
. 2010-04-27 14:48:27.189 Sending special code: 12
. 2010-04-27 14:48:27.189 Sent EOF message
The error that I mean is and then it repeats some times
cjw
Wait, this is probably nothing. I'm fixing problem now.... I will remove post probably in 5 minutes or so
cjw
It was because cd / in ftp leads to different folder than cd / in sftp.
after doing cd / in sftp it couldn't find files.
Cause maybe helpful for other people experiencing same error uploading with sftp instead of ftp... I'll leave the post.
