Topic "Error: synchroniz directories by using the Keepuptodate"
Hedemann
I am trying to synchroniz a remote directories by using the Keepuptodate command. But it doesn't seems to work - I recieved a error after the first file copied and the synchronization stops.
I recieved this error:
Upload of file 'test.txt' was successful, but error occurred while set
ting the permissions and/or timestamp. If the problem persists, turn on 'Ignore
permission errors' option.
The server does not support the operation.
Error code: 8
Can anyone help me Very Happy
Hedemann
Hi
I have read the FAQ and maualen, but I can't find a solution to the problem.
Please give a clue
So what did you try to do already?
Hedemann
Hi, I have at test script containing this:
option batch on
open XXXXXXX:TestUser@ZZZZZ.WW
pwd
cd /users/TestUser
option transfer binary
Keepuptodate -nopermissions -nopreservetime C:\WinSCP\WinSCPData\TestUser
close
I have tried different variation of the keepuptodata command but without luck.
Your script looks correct. What version of WinSCP are you using? Have you tried the latest one? If you are using the latest one, please post a log file.
