Topic ""a sendto" hook"
Gianmarco
I am a very happy WinSCP user from long time.
I use it daily with our FreeBSD boxes and it works without any problems. Thanks for this !
Sorry if what I ask is implemented but I was not able to find it Smile
What about to let winscp aware of the sendto interface of the Win explorer ?
In the right mouse click:
Send by/to winscp
and then the winscp pop up let me choosing an eventually saved session or a simple user@host / password combination , send and then exit Smile
Thanks again for attention.
Send by/to winscp
uhm .. no answer is it a so silly idea ? Smile
No it's not Smile I'll consider it.
i think mounting as a drive should come first... any estimations when it will come..?
No estimation. It is just a wish. It is too complicated, porobably I will never implement this one.
Gianmarco
Thanks for the hook... it is very appreciated.
If I can ask again Smile, what about to have the "creating the context menu ... ", also in the exe itslelf ? Perhaps in the tools buttons.
Btw, is it only this link :
c:\Documents and Settings\username\SendTo\WinSCP2 (upload using SCP).lnk
that made the game ?
Do you mean an option that will create a "send to" hook, when you have not chosen it in installer?
Yes. But also I had to learn WinSCP to handle list of files given as parameters, when a hook is executed.
Yes, because I usually don't download the "setup" version but only the exe itself.
And I really use and like that option Smile So I asked if it will be possible to have the possibility to create it by the program itself, not only from the installer.
Ah, I asking it to "auto" fix the point of above Smile
Thanks for your kind reply
Gianmarco
