Topic "Timed Out Errors"
valsair
Ok Iphone is jailbreak with spirit went to cydia and downloaded Open ssh and bossPrefs then downloaded Winscp I Put in Ip Address into Host port is 22 user name root and pass alpine disabled my windows firewall and under connections i raised my server response time out and i still get timed out anyone know what else i could try to make this work?
Thank You
Newest to this
1. Complete 3.1.2 restore to my mb 3g
2. Spirit Jailbreak run.
4. In cydia, installed Steffwiz , then all sources
(as described)(http://www.youtube.com/watch?v=RBI_4HUG3_g)
3. WinSCP Open.
Problem....Noticed, now WinSCP reads my pod as 2.1 (jailed)
yet setting indicates 3.1.2(7d11)
cant go to var under raw data...fixes??
^^^^valsair^^^ is automaticssh installed on your device?if not do so, also make sure to enable ssh. try rebooting device and router.
Newest to this
<<<<<<<<<<<<<<CORRECTION>>>>>>>>>>>>>>>>>>
IT WASNT WINSCP TO RECOGNIZE IPOD AS (JAILED)
I MEANT TO REFER TO IFUNBOX.
IFUNBOX WILL NO LONGER SHOW ME VAR/ ,
AFTER SPIRIT JAILBREAK,
other jailbreaks worked under.
Newest to this
afc2add needs manual install after spirit break. Found in Cydia
^^^^Sorry cant think of anyting for you man, but i can say if you spirit jailbroke and whan to ssh. you can do so by installing ifunbox. This program does same as winscp only with the cable. Winscp does have advantages to see folder properties for example.You should download the automatic ssh also from cydia. Maybe , most likely this will help timout.
