| Author | Message |
Agent
Posts: 10 |
Posted: 11 May 2010 13:28
HI,
got the following problem since 3.7. When I have a file selected on the left window *local* and change to the right window *remote* and after that back to the local selected file it automatically start to rename the filename. This also happens vice versa on the remote site. Only when exactly selecting the file icon this does not happen. It is like the selected file on both sites will be kept in mind and as soon you come backt to the same one it is like hit F2 or a slow double click. Can this be avoided somehow? Regards Agent |
| Advertisements |
prikryl
Posts: 16484 Location: Prague, Czech republic |
Posted: 12 May 2010
Agent
Posts: 10 |
Posted: 3 Dec 2010 12:15
Hi Martin,
even if it is already on Tracker Bug 570? Any ETA when this will be fixed? It is really annoying. Would be great to have this in next version. When will this be released? Thanks in advance for your answer. Cheers Agent |
prikryl
Posted: 6 Dec 2010
I've raised priority of the bug.
_________________ Martin Prikryl |
| Advertisements |
Site design by Black Gate
