Topic "UTF-8 filenames in SCP mode?"
AnrDaemon
When you configure WinSCP to work in SCP mode, it do not allow you to enable UTF-8 filenames on remote side.
It is a bug or intended (mis)feature?
Far2 x86, if that matters.
Intended misfeature.
AnrDaemon
Great :X
And how to read non-ASCII file names then?
This issue is being tracked already.
AnrDaemon
Thanks.
Thank you for your nice post. It is very helpful to me
dma_k
I vote for this feature. I believe, WinSCP should be transformed from ACSII to Unicode version for that (which is a bit of work)? Otherwise remote folder contents should be in the charset compatible with FAR console charset (no way to display Chinese on Cyrillic). I am right?
dma_k
Pity that full Unicode support is in WinSCP since 5.0, but FAR manager users cannot benefit from this.
irex
nope. WinSCP 5.0.2 beta does not support Unicode encoding in SCP mode.
AnrDaemon
Here's hope that once 5.0 is out, the FAR manager plugin could get some love as well.
irex
Does anyone have a success for filename Unicode encoding in SCP mode with WinSCP 5.0.2 beta?
It's strange that when I use ssh@cygwin to login the server, all filenames are decoded correctly, but winscp can't.
irex
Here is a list of ssh clients:
http://en.wikipedia.org/wiki/Comparison_of_SSH_clients
But I am not sure which one support scp and filename utf-8 encoding/decoding.
AnrDaemon
PuTTY does, for sure.
bredhedden1
thanks for helpful wikipedia source which is helpful especially for me.
exopper
I also vote for this feature!
now in winscp5.5,UTF-8 filenames is not allowed in SCP mode Crying or Very sad
found "UTF-8 is not supported with SCP protocol." here: http://winscp.net/eng/docs/ui_login_environment
DropBear can transport UTF-8 encode filenames in scp,but remote panel display it in ansi.
when use sshd as host,in scp mode,the remote panel always display filenames in ansi encoding too.
can i change this default encoding to UTF-8?
RalphGL
using scp connection to a server with LANG=de_DE.UTF-8 did not use UTF-8 coding for filenames.
no way to choose the right character set with winscp?
winscp-version is 5.5.6 built 4746
RalphGL
I think the information on http://winscp.net/eng/docs/ui_login_environment#utf is wrong.
utf-8 did not work in winscp with a scp-connection either LANG is set on the remote site to UTF-8 or not.
Is it allowed to change the wrong information there? Or will it work as described sooner or later?
As documented, UTF-8 is supported with SCP protocol in the latest beta release only. Please upgrade.
See http://winscp.net/tracker/show_bug.cgi?id=325
RalphGL
Thank you for your hint! Although utf-8 is set (LANG=de_DE.uft-8) the last beta version did not use UTF-8 if option AUTO is set. But there is an option to change to utf-8 manually and after changing the option utf-8 is used.
RalphGL
I created a login file, but I don´t think there is any hint for debugging in it.
The "UTF-8 encoding for filenames" was set to "On". If it is set to "Auto" it did not work.
scp.log (29.76 KB) Private file
Description: The **** are replacements made by me.
Thanks, but this is a log for "On". I need a log for "Auto".
RalphGL
sorry, here a log with option auto is coming
scp.log (833.1 KB) Private file
Description: **** here original content ist hidden
... here i removed some content
RalphGL
[quote="RalphGL"]sorry, this was the wrong log, the new is attached now
scp-auto.log (82.53 KB) Private file
Description: Log with option auto
RalphGL
please ignore this file, use scp-auto.log instead, sorry
Thanks for the log:
Quote:
> 2015-02-10 08:08:27.850 echo $LANG ; echo "WinSCP: this is end-of-file:$?"
< 2015-02-10 08:08:27.850 de_DE@euro
There's no UTF-8.
Maybe you set the LANG to "UTF-8" for interactive sessions only.
RalphGL
Maybe - but i´m not sure, where to change the environment settings for non-interactive shells. Is it /etc/profile.d/ or better /etc/ssh/sshd_config or better to create a user specific ~/.ssh/environment?
I can´t identify the file where LANG=de_DE@euro may be set.
It varies. Try .bashrc (instead of .bash_profile).
Do you use PuTTY? What is value of LANG, when you login with PuTTY with Connection > SSH > TTY > Don't allocate a pseudo terminal turned off?
RalphGL
in my .bashrc
LANG=de_DE.UTF-8
export LANG
is st.
Normally "Don't allocate a pseudo terminal" is off and the result of set|grep LANG is
LANG=de_DE.UTF-8
LANGUAGE=de_DE:en
If i activate the button before connecting i cant enter enything (no bash?)
Well, I'm not an expert on *nix shell environment. But clearly, as you can see, WinSCP behaves correctly, based on the information it gets from your server.
