Topic "Understanding log file"
DirectMax
Hi!
I need to know the size of a transferred file. I'm reading the log file but I can't identify the size of the file. Someone could tell me where i can find it?
Thanx
. 2010-05-14 07.00.01.366 Copying 1 files/directories to remote directory "/xxxxx/xxxxxx/user"
. 2010-05-14 07.00.01.366 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-05-14 07.00.01.366 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-05-14 07.00.01.366 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-05-14 07.00.01.366 File: "d:\Data\xxxx\xxxxxx\xxxxx\xxxxxxxx.in"
. 2010-05-14 07.00.01.366 Copying "d:\Data\xxxx\xxxxxx\xxxxx\xxxxxxxx.in" to remote directory started.
. 2010-05-14 07.00.01.366 Binary transfer mode selected.
. 2010-05-14 07.00.01.366 Opening remote file.
> 2010-05-14 07.00.01.366 Type: SSH_FXP_OPEN, Size: 69, Number: 259
< 2010-05-14 07.00.01.366 Type: SSH_FXP_HANDLE, Size: 13, Number: 259
> 2010-05-14 07.00.01.366 Type: SSH_FXP_WRITE, Size: 4121, Number: 774
. 2010-05-14 07.00.01.366 1 skipped SSH_FXP_WRITE, P_DATA and SSH_FXP_STATUS packets.
> 2010-05-14 07.00.01.381 Type: SSH_FXP_CLOSE, Size: 13, Number: 1284
> 2010-05-14 07.00.01.381 Type: SSH_FXP_SETSTAT, Size: 65, Number: 521
< 2010-05-14 07.00.01.381 Type: SSH_FXP_STATUS, Size: 24, Number: 774
< 2010-05-14 07.00.01.381 Type: SSH_FXP_STATUS, Size: 24, Number: 1030
< 2010-05-14 07.00.01.381 Type: SSH_FXP_STATUS, Size: 24, Number: 1284
< 2010-05-14 07.00.01.381 Status/error code: 0
< 2010-05-14 07.00.01.600 Type: SSH_FXP_STATUS, Size: 24, Number: 521
< 2010-05-14 07.00.01.600 Status/error code: 0
The plain text log file is not intended for automatic interpreting. You can use XML logging.
