portable winscp and local shortcuts
vadvi
hi
i use the portable winscp (version 4.2.7) and i can't follow the local shortcuts with it.
ramancheema_20
LINKS and local shortcuts
Can you be more specific about what you want to do?
I need help in creating links.I searche lot of options.A the end ,I was advised to go under File-->Link
The link option is grayed.How can it be active-
Re: LINKS and local shortcuts
You were asking about "following" links, not "creating".
The command File > New Link is disabled, when you have the remote panel selected and the server does not allow creating links.
If you want to create a local shortcut, you have to focus the local panel first.
