Topic "WinSCP v4.2.7 slow and times out - filezilla 3.3.2.1 works"
First, just want to say thanks for a great utility!!!!!
This is the first time I have had any problems with it.Transfering from WINXP PRO SP3 to Solaris 8 stops at 34282 bytes with server not responding.The same transfer takes 2 seconds using filezilla.
The log is attached. If you want to email me a debug version for further detailsplease do so...
Many thanks!
. 2010-05-19 10:21:11.984 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
< 2010-05-19 10:21:11.984 Type: SSH_FXP_ATTRS, Size: 37, Number: 2056
. 2010-05-19 10:21:11.984 Storing reserved response
. 2010-05-19 10:21:54.562 Waiting for data timed out, asking user what to do.
. 2010-05-19 10:21:54.562 Asking user:
username is frankk74
Mrs. Stup
Does WinSCP 4.1.9 work properly? Have You tried
