Topic "winscp spool ?"
toni00
is there some way that i can see what os commands is winscp executing ?
For example i select 5 files through winscp and delete them, and i would like to see what command winscp used to do that ...
Turn on logging and check the log file.
hi Martyn.
Sory but the exact comands were not written in the logs....
I tryed to get them in normal logging mode and debug 1 and 2....
Is there some logging i can turn on on the linux side ?
What protocol are you using?
SFTP.
Should i change it ?
Well, SFTP is binary protocol, so there are no intelligible commands. So you may try SCP instead.
