Topic "Error: command su failed"
wcguy
Hi, I tried the search, but it seems down at the moment...,
any advice on this error message? I want to log in as root so as to work with some of the config files.
Yes, I do have root access, this is a virtual dedicated server at godaddy. It also doesn't work on my dedicated server.
Command 'su' failed with return code 1 and error message standard in must be a tty.
WCGuy
I CAN get in through putty, BTW.
WCGuy
OK, answered my own question. Had to set up properties, open putty, su in , and CLOSE THE PUTTY WINDOW!
The last part wasn't obvious.
Thanks anyway Maybe my dumb posts will help someother noob.
