Topic "Help - Simply scripting for connections"
pjmartins
Hi there,
Great product! I'm looking for some simple connection scripts.. Literally to simply run a shortcut that will connect the user to a server direct. This simply runs the application with the hostname and port defined. Then the user simply enter username and password...
Is this possible as i've tried a few without any luck!
pjmartins
Do I understand right that the script should just initiate connection to specific host, nothing more?
pjmartins
That's the one, maybe change port if possible but that is pretty much it.
Much apprecaited!
pjmartins
Please help!
winscp.exe hostname:port
