Topic "automated overwrite"
techpros
I have a .bat script that is being run every three minutes to update weather info. But it is asking me every time for every upload if I want to overwrite the existing file. I want to to just automatically overwrite it without asking me. here is my bat file:
cd grayville.org/data
ascii
put "c:\vws\upload\weatherinfo.txt"
binary
put "c:\vws\jpeg\broadcast.jpg"
put "c:\vws\jpeg\vws457.jpg"
put "c:\vws\jpeg\vws458.jpg"
put "c:\vws\jpeg\vws459.jpg"
cd ../../graylight.org/data
binary
put "c:\program files\aninoquisi\lightning2000\lightning.jpg"
ascii
put "C:\Documents and Settings\norman\Desktop\info.txt"
put "C:\Program Files\Aninoquisi\Lightning2000\Nowcasts\lightning.txt"
close
MrPatrick
I'm using the following in the middle of a small script to pull down some files from a remote site:
winscp /console /open user:pwd@hostIP /privatekey=pvtkey.ppk /option confirm off /command "get *.* d:\folder" "close" "exit"
The trouble is that I'm still getting asked if I want to overwrite. I'm sure its just my syntax but I've tried all the combinations of the 'confirm off' switch I can think of (having read and re-read the FAQ) and I just can't get it working.
Other than that I've got it all working. Can you help?!
Patrick
winscp /console /command "open user:pwd@hostIP -privatekey=pvtkey.ppk" "option confirm off" "get *.* d:\folder" "close" "exit"
