Topic "Delete Files - Permission denied"
Ralf
I use WinSCP V 4.2.7 as Client, the Server is WS FTP Pro 7.
The Code I use is something like that:
get -delete *.txt "D:\Beispiel FTP Transfer\Download vom Transparenztool\*.txt"
and I get Permission denied. In the log-file I can see something like this:
Deleting file "7886701145_137_2010.txt".
DELE /export/tsnl_no/7886701145_137_2010.txt
450 Deletion failed
The problem is the / at the beginning. In the Command-Line this will delete the file:
Executing user defined command.
dele export/tsnl_no/7886701145_137_2010.txt
250 deleted
Getting current directory name.
How can I change my script so that there is no / at the beginning of the commmands? Or is this only a Problem of WS FTP Pro 7 (FileZilla works fine)?
Ralf
I do not see why the slash at the beginning is a problem. Why the server does not accept it?
Ralf
I don't know. But I found this message http://winscp.net/forum/viewtopic.php?t=7140
It's the same problem (with WS FTP Por as server).
Ralf
Ralf
Edit: In WS FTP Pro there is in the User settings an option named 'Show home folder as root'... Now everingthing works fine !!!
Thanks for sharing the information!
