Topic "error message login"
seb
I have this message error when i want to login :
"Server's host key did not match the signature supplied"
I can connect with putty in ssh then ssh is ok.
thanks for your help.
Seb.
Very Happy
Which version of Putty are you using? Can you try latest development snapshot?
redav
I am using Putty 0.53b and had the same problem. My solution was to save the session in Putty, then Import the Putty session to WinSCP and it then accepted the host key sent by the server.
Cheers,
redav
