Topic "open ssh connection with option -hostkey like a parameter"
ivarodr
i am doing a .cmd file to automate a ssh connection to a server and when i use the option -hostkey in the open command i don't have the expected results because i get the message "i don't understand the server key....".
This is part of my .cmd file:
cd C:\Program Files\WinSCP
start winscp.com /command "option batch on" "option confirm off" "open %2:%3@%1 -hostkey=%6"
I call this .cmd from vbs.
I am sure that the problem is located in parameter %6 and i think that the problem comes from the type of the param because is like it didn't have been recognised like a String.
Please help.
THX.
Can you post a log file? The error message does not look familiar to me.
ivarodr
Excuse me, it has been my error in the definition of the error message.
The complete error message is:
I don't understand the server key. There is no guarantee of that remote "team" is really who you think it is.
The digital rsa2 fingerprint of the server key is: ssh-rsa 2048 ...........................
If you meet this "team" you have to answer yes, .....
The server key doesn't have been verified!!!
Escuse my poor English.
THX.
ivarodr
[quote Smile ="prikryl"]Can you post a log file?[/quote]
. 2010-06-10 15:19:21.893 --------------------------------------------------------------------------
. 2010-06-10 15:19:21.894 WinSCP Version 4.2.7 (Build 758) (OS 6.1.7600)
. 2010-06-10 15:19:21.894 Login time: jueves, 10 de junio de 2010 15:19:21
. 2010-06-10 15:19:21.894 --------------------------------------------------------------------------
. 2010-06-10 15:19:21.895 Session name: sgbe6
. 2010-06-10 15:19:21.895 Host name: sgbe6 (Port: 22)
. 2010-06-10 15:19:21.895 User name: (Password: No, Key file: No)
. 2010-06-10 15:19:21.896 Tunnel: No
. 2010-06-10 15:19:21.896 Transfer Protocol: SFTP (SCP)
. 2010-06-10 15:19:21.896 Ping type: -, Ping interval: 30 sec; Timeout: 6000 sec
. 2010-06-10 15:19:21.897 Proxy: none
. 2010-06-10 15:19:21.897 SSH protocol version: 2; Compression: No
. 2010-06-10 15:19:21.897 Bypass authentication: No
. 2010-06-10 15:19:21.897 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2010-06-10 15:19:21.898 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2010-06-10 15:19:21.898 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2010-06-10 15:19:21.898 SFTP Bugs: -,-
. 2010-06-10 15:19:21.898 Return code variable: Autodetect; Lookup user groups: Yes
. 2010-06-10 15:19:21.898 Shell: default, EOL: 1
. 2010-06-10 15:19:21.898 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2010-06-10 15:19:21.899 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2010-06-10 15:19:21.899 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-06-10 15:19:21.899 Cache directory changes: Yes, Permanent: Yes
. 2010-06-10 15:19:21.899 DST mode: 0
. 2010-06-10 15:19:21.899 --------------------------------------------------------------------------
. 2010-06-10 15:19:22.126 Looking up host "sgbe6"
. 2010-06-10 15:19:22.131 Connecting to 10.95.15.20 port 22
. 2010-06-10 15:19:22.189 Server version: SSH-2.0-OpenSSH_4.6
. 2010-06-10 15:19:22.189 Using SSH protocol version 2
. 2010-06-10 15:19:22.189 We claim version: SSH-2.0-WinSCP_release_4.2.7
. 2010-06-10 15:19:22.206 Doing Diffie-Hellman group exchange
. 2010-06-10 15:19:22.244 Doing Diffie-Hellman key exchange with hash SHA-1
. 2010-06-10 15:19:22.618 Asking user:
. 2010-06-10 15:19:22.618 The server's host key was not found in the cache. You have no guarantee that the server is the computer you think it is.
. 2010-06-10 15:19:22.618 The server's rsa2 key fingerprint is:
. 2010-06-10 15:19:22.618 ssh-rsa 2048 f7.......
. 2010-06-10 15:19:22.619
. 2010-06-10 15:19:22.619 If you trust this host, press Yes. To connect without adding host key to the cache, press No. To abandon the connection press Cancel.
. 2010-06-10 15:19:22.619 Continue connecting and add host key to the cache? ()
. 2010-06-10 15:19:27.574 Attempt to close connection due to fatal exception:
* 2010-06-10 15:19:27.575 Host key wasn't verified!
. 2010-06-10 15:19:27.575 Closing connection.
. 2010-06-10 15:19:27.575 Sending special code: 12
* 2010-06-10 15:19:27.625 (ESshFatal) Host key wasn't verified!
* 2010-06-10 15:19:27.626 Authentication failed.
OK, so what do you pass to %6?
ivarodr
I pass to %6 a vbs variable with the value of the RSAKey as String.
I get this error message if i pass the rsa key like a parametre of my script but i don't get this error message if a do the same action in a winscp console.
This is my vbs code:
Dim ws, oExec....
RSAkey="ssh-rsa 2048 ....."
set ws = CreateObject("WScript.Shell")
Set oExec = ws.Exec(PathScript&" "&serverIP&" "&user&" "&pass&" "&node&" "&country&" "&RSAkey)
Dim output
output=""
Do Until oExec.stdOut.AtEndOfStream
output=output&oExec.stdOut.Read(1)
Loop
An interesting thing is that if a execute my script from cmd.exe passing the same parametres (with an unique difference what is pass the RSAKey like a literal String , not saving it in a variable) adding "%6" i don't get the error message, i am going crazy.
You need to enclose the hostkey into double-quotes. That's probably also your difference between calling using variable and literal string (where you probably add the double-quotes).
