Topic "Duplicate directory issue"
waseem
I selected Duplicate (Shift+F5) option on one directory which has sub-directories; in each directory HIPAA files are there. I was expecting this option will create only one duplicate copy of selected directory recursively but WinScp created thousand of unwanted copies of same directory recursively.
Looks like this is serious issue with WinScp
What protocol are you using? Are you able to reproduce the problem?
waseem
Protocol is FTP, Port # is 21, its reproducable.
A L N
Yes.. It is defect in WINSCP software. I believe, Duplicate operation follows the below steps.
1.) WINSCP first creates Directory (Copy Of ....)
2.) and then It executes "cp -r * " command with in current Directory.
Solution:
If you navigate to newly created Directory (Copy Of ....) and then
execute "cp -r ../* "
