Topic "Easier login after Hibernation"
donquixote
Hi
When my system wakes up from hibernate mode, all SSH connections are naturally cut off, including putty and winscp.
Unfortunately, WinSCP asks me twice for the password: At first it shows a password dialog which never succeeds to log me in. Then I get a message "Connection was closed by the server" or something. Then I have to type the password again.
Sometimes I am even back at the list of saved connections, after the first login attempt.
Would it be possible to remember the password in cases like this, and try a second time? The best would be if I don't need a mouse in the entire procedure, and I get as few dialogs as possible Smile
Thanks!
[Btw, putty isn't perfect either: First I need to respond to an error message telling me that the connection was cut. Then I have to click "Restart session" in the menu, and then type the password.]
This feature would spare you the first password prompt.
donquixote
Thanks! this would be a step forward.
To learn when and how passwords are saved to stored session and remembered in memory please read:
http://winscp.net/eng/docs/security_credentials
