Topic "REQ: "Ask password directly before connecting" checkbox/feature"
d4
Howdy!
Could you please add this feature? Cause it is somewhat annoying to wait some time for "Enter password" dialog to appear after you pressed RETURN in session manager panel.
Please, please, pleeeeease Smile
Wonderful plugin in other means!
cheers
-d
Keep in mind that password authentication is not by far only mean of authentication in SSH. The plugin cannot know what means of authentication the server supports before it connects.
Well, this _is_ the way to tell it to use password auth Wink
thanks for your quick reply!
-d
Hmm, I'll see. But I have to say that I do not consider this to be a high priority issue.
d4
Thanks in advance! Smile
-d
