Topic "Need help: connection failure after upgrade to WINSCP 4.2.7"
weimerm
I upgraded to WINSCP 4.2.7 from 3.8.2. All of my 3.8.2 connections worked as expected in 4.2.7 except for one SSH connection.
For this one exception I am getting the "incoming packet was garbled on decryption" error. Their server is: SSH-2.0-OpenSSH_4.3
Successful Log (debug level 2):
. 2010-07-01 11:13:31.367 --------------------------------------------------------------------------
. 2010-07-01 11:13:31.367 WinSCP Version 3.8.2 (Build 330) (OS 5.2.3790 Service Pack 2)
. 2010-07-01 11:13:31.367 Login time: Thursday, July 01, 2010 11:13:31 AM
. 2010-07-01 11:13:31.367 Session name: ####################
. 2010-07-01 11:13:31.367 Host name: ##################### (Port: 22)
. 2010-07-01 11:13:31.367 User name: #########(Password: Yes, Key file: Yes)
. 2010-07-01 11:13:31.367 Transfer Protocol: SFTP (SCP)
. 2010-07-01 11:13:31.367 SSH protocol version: 2; Compression: No
. 2010-07-01 11:13:31.367 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2010-07-01 11:13:31.367 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2010-07-01 11:13:31.367 Ping type: N, Ping interval: 30 sec; Timeout: 15 sec
. 2010-07-01 11:13:31.367 SSH Bugs: -,-,-,-,-,-,-,-
. 2010-07-01 11:13:31.367 SFTP Bugs: -,-,-
. 2010-07-01 11:13:31.367 Proxy: none
. 2010-07-01 11:13:31.367 Return code variable: Autodetect; Lookup user groups: Yes
. 2010-07-01 11:13:31.367 Shell: default, EOL: 0
. 2010-07-01 11:13:31.367 Local directory: C:\Documents and Settings\biadmin\My Documents, Remote directory: /POLP-STKSHK, Update: No, Cache: Yes
. 2010-07-01 11:13:31.367 Cache directory changes: Yes, Permanent: Yes
. 2010-07-01 11:13:31.367 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2010-07-01 11:13:31.367 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2010-07-01 11:13:31.367 Looking up host "www.mftcat.firstdataclients.com"
. 2010-07-01 11:13:36.742 Connecting to 216.66.216.10 port 22
. 2010-07-01 11:13:36.774 Waiting for the server to continue with the initialisation
. 2010-07-01 11:13:36.774 Looking for incoming data
. 2010-07-01 11:13:36.867 Select result is 1
. 2010-07-01 11:13:36.867 Server version: SSH-2.0-OpenSSH_4.3
. 2010-07-01 11:13:36.867 We claim version: SSH-2.0-WinSCP_release_3.8.2
. 2010-07-01 11:13:36.867 Using SSH protocol version 2
. 2010-07-01 11:13:36.867 Waiting for the server to continue with the initialisation
. 2010-07-01 11:13:36.867 Looking for incoming data
. 2010-07-01 11:13:36.883 Select result is 1
. 2010-07-01 11:13:36.883 Doing Diffie-Hellman group exchange
. 2010-07-01 11:13:36.883 Waiting for the server to continue with the initialisation
. 2010-07-01 11:13:36.883 Looking for incoming data
. 2010-07-01 11:13:36.930 Select result is 1
. 2010-07-01 11:13:36.930 Doing Diffie-Hellman key exchange
. 2010-07-01 11:13:37.039 Waiting for the server to continue with the initialisation
. 2010-07-01 11:13:37.039 Looking for incoming data
. 2010-07-01 11:13:37.242 Select result is 1
. 2010-07-01 11:13:37.367 Host key fingerprint is:
. 2010-07-01 11:13:37.367 ssh-rsa 2048 10:fc:27:5a:81:33:04:9d:d0:65:72:b2:18:bf:dd:bf
. 2010-07-01 11:13:37.367 Initialised AES-256 client->server encryption
. 2010-07-01 11:13:37.367 Initialised HMAC-SHA1 client->server MAC algorithm
. 2010-07-01 11:13:37.367 Initialised AES-256 server->client encryption
. 2010-07-01 11:13:37.367 Initialised HMAC-SHA1 server->client MAC algorithm
. 2010-07-01 11:13:37.367 Waiting for the server to continue with the initialisation
. 2010-07-01 11:13:37.367 Looking for incoming data
. 2010-07-01 11:13:37.461 Select result is 1
! 2010-07-01 11:13:37.461 Using username "POLP-STKSHK".
. 2010-07-01 11:13:37.461 Reading private key file "YYYYYYYYYYYYYYYYYYYYYYYYYYY.ppk"
. 2010-07-01 11:13:37.461 Waiting for the server to continue with the initialisation
. 2010-07-01 11:13:37.461 Looking for incoming data
. 2010-07-01 11:13:37.492 Select result is 1
! 2010-07-01 11:13:37.492 WARNING! THIS SYSTEM IS FOR AUT
FAILED REQUEST LOG:
. 2010-07-01 11:07:56.283 --------------------------------------------------------------------------
. 2010-07-01 11:07:56.283 WinSCP Version 4.2.7 (Build 758) (OS 5.2.3790 Service Pack 2)
. 2010-07-01 11:07:56.283 Login time: Thursday, July 01, 2010 11:07:56 AM
. 2010-07-01 11:07:56.283 Session name: #####################
. 2010-07-01 11:07:56.283 Host name: #######################.com (Port: 22)
. 2010-07-01 11:07:56.283 User name: YYYYYYYY (Password: Yes, Key file: Yes)
. 2010-07-01 11:07:56.283 Tunnel: No
. 2010-07-01 11:07:56.283 Transfer Protocol: SFTP (SCP)
. 2010-07-01 11:07:56.283 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2010-07-01 11:07:56.283 Proxy: none
. 2010-07-01 11:07:56.283 SSH protocol version: 2; Compression: No
. 2010-07-01 11:07:56.283 Bypass authentication: No
. 2010-07-01 11:07:56.283 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2010-07-01 11:07:56.283 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2010-07-01 11:07:56.283 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2010-07-01 11:07:56.283 SFTP Bugs: -,-
. 2010-07-01 11:07:56.283 Return code variable: Autodetect; Lookup user groups: Yes
. 2010-07-01 11:07:56.283 Shell: default, EOL: 0
. 2010-07-01 11:07:56.283 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2010-07-01 11:07:56.283 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2010-07-01 11:07:56.283 Local directory: C:\Documents and Settings\biadmin\My Documents, Remote directory: /xxxxxxxxx, Update: No, Cache: Yes
. 2010-07-01 11:07:56.283 Cache directory changes: Yes, Permanent: Yes
. 2010-07-01 11:07:56.283 DST mode: 1
. 2010-07-01 11:07:56.314 Looking up host "###########################.com"
. 2010-07-01 11:07:56.314 Connecting to 216.66.216.10 port 22
. 2010-07-01 11:07:56.330 Selecting events 63 for socket 432
. 2010-07-01 11:07:56.330 Waiting for the server to continue with the initialisation
. 2010-07-01 11:07:56.330 Looking for incoming data
. 2010-07-01 11:07:56.330 Looking for network events
. 2010-07-01 11:07:56.330 Detected network event
. 2010-07-01 11:07:56.330 Enumerating network events for socket 432
. 2010-07-01 11:07:56.330 Enumerated 18 network events making 18 cumulative events for socket 432
. 2010-07-01 11:07:56.330 Handling network write event on socket 432 with error 0
. 2010-07-01 11:07:56.330 Handling network connect event on socket 432 with error 0
. 2010-07-01 11:07:56.424 Detected network event
. 2010-07-01 11:07:56.424 Enumerating network events for socket 432
. 2010-07-01 11:07:56.424 Enumerated 1 network events making 1 cumulative events for socket 432
. 2010-07-01 11:07:56.424 Handling network read event on socket 432 with error 0
. 2010-07-01 11:07:56.424 Server version: SSH-2.0-OpenSSH_4.3
. 2010-07-01 11:07:56.424 Using SSH protocol version 2
. 2010-07-01 11:07:56.424 We claim version: SSH-2.0-WinSCP_release_4.2.7
. 2010-07-01 11:07:56.424 Waiting for the server to continue with the initialisation
. 2010-07-01 11:07:56.424 Looking for incoming data
. 2010-07-01 11:07:56.424 Looking for network events
. 2010-07-01 11:07:56.439 Detected network event
. 2010-07-01 11:07:56.439 Enumerating network events for socket 432
. 2010-07-01 11:07:56.439 Enumerated 1 network events making 1 cumulative events for socket 432
. 2010-07-01 11:07:56.439 Handling network read event on socket 432 with error 0
. 2010-07-01 11:07:56.439 Doing Diffie-Hellman group exchange
. 2010-07-01 11:07:56.439 Waiting for the server to continue with the initialisation
. 2010-07-01 11:07:56.439 Looking for incoming data
. 2010-07-01 11:07:56.439 Looking for network events
. 2010-07-01 11:07:56.486 Detected network event
. 2010-07-01 11:07:56.486 Enumerating network events for socket 432
. 2010-07-01 11:07:56.486 Enumerated 1 network events making 1 cumulative events for socket 432
. 2010-07-01 11:07:56.486 Handling network read event on socket 432 with error 0
. 2010-07-01 11:07:56.486 Doing Diffie-Hellman key exchange with hash SHA-1
. 2010-07-01 11:07:56.564 Waiting for the server to continue with the initialisation
. 2010-07-01 11:07:56.564 Looking for incoming data
. 2010-07-01 11:07:56.564 Looking for network events
. 2010-07-01 11:07:56.768 Detected network event
. 2010-07-01 11:07:56.768 Enumerating network events for socket 432
. 2010-07-01 11:07:56.768 Enumerated 1 network events making 1 cumulative events for socket 432
. 2010-07-01 11:07:56.768 Handling network read event on socket 432 with error 0
. 2010-07-01 11:07:56.846 Selecting events 63 for socket 432
. 2010-07-01 11:07:56.846 Host key fingerprint is:
. 2010-07-01 11:07:56.846 ssh-rsa 2048 10:fc:27:5a:81:33:04:9d:d0:65:72:b2:18:bf:dd:bf
. 2010-07-01 11:07:56.846 Initialised AES-256 SDCTR client->server encryption
. 2010-07-01 11:07:56.846 Initialised HMAC-SHA1 client->server MAC algorithm
. 2010-07-01 11:07:56.846 Initialised AES-256 SDCTR server->client encryption
. 2010-07-01 11:07:56.846 Initialised HMAC-SHA1 server->client MAC algorithm
. 2010-07-01 11:07:56.846 Waiting for the server to continue with the initialisation
. 2010-07-01 11:07:56.846 Looking for incoming data
. 2010-07-01 11:07:56.846 Looking for network events
. 2010-07-01 11:07:56.940 Detected network event
. 2010-07-01 11:07:56.940 Enumerating network events for socket 432
. 2010-07-01 11:07:56.940 Enumerated 33 network events making 33 cumulative events for socket 432
. 2010-07-01 11:07:56.940 Handling network read event on socket 432 with error 0
. 2010-07-01 11:07:56.940 Selecting events 0 for socket 432
. 2010-07-01 11:07:56.940 Incoming packet was garbled on decryption
* 2010-07-01 11:07:56.940 (ESshFatal) Incoming packet was garbled on decryption
* 2010-07-01 11:07:56.940 Authentication failed.
I'm not aware of such problem with 4.2.7. Are you able to connect with the latest PuTTY?
weimerm
Incoming packet was garbled on decryption.
weimerm
Putty Log:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2010.07.07 10:16:14 =~=~=~=~=~=~=~=~=~=~=~=
Event Log: Writing new session log (SSH raw data mode) to file: E:\putty.log
Event Log: Looking up host "www.mft1.firstdataclients.com"
Event Log: Connecting to 216.66.216.11 port 22
Incoming raw data
00000000 53 53 48 2d 32 2e 30 2d 4f 70 65 6e 53 53 48 5f SSH-2.0-OpenSSH_
00000010 34 2e 33 0a 4.3.
Event Log: Server version: SSH-2.0-OpenSSH_4.3
Event Log: We claim version: SSH-2.0-PuTTY_Release_0.60
Outgoing raw data
00000000 53 53 48 2d 32 2e 30 2d 50 75 54 54 59 5f 52 65 SSH-2.0-PuTTY_Re
00000010 6c 65 61 73 65 5f 30 2e 36 30 0d 0a lease_0.60..
Outgoing packet type 20 / 0x14 (SSH2_MSG_KEXINIT)
00000000 d2 9e c0 d7 52 ee e6 0f 22 20 c3 f5 0b 6b a7 3d ....R..." ...k.=
00000010 00 00 00 7e 64 69 66 66 69 65 2d 68 65 6c 6c 6d ...~diffie-hellm
00000020 61 6e 2d 67 72 6f 75 70 2d 65 78 63 68 61 6e 67 an-group-exchang
00000030 65 2d 73 68 61 32 35 36 2c 64 69 66 66 69 65 2d e-sha256,diffie-
00000040 68 65 6c 6c 6d 61 6e 2d 67 72 6f 75 70 2d 65 78 hellman-group-ex
00000050 63 68 61 6e 67 65 2d 73 68 61 31 2c 64 69 66 66 change-sha1,diff
00000060 69 65 2d 68 65 6c 6c 6d 61 6e 2d 67 72 6f 75 70 ie-hellman-group
00000070 31 34 2d 73 68 61 31 2c 64 69 66 66 69 65 2d 68 14-sha1,diffie-h
00000080 65 6c 6c 6d 61 6e 2d 67 72 6f 75 70 31 2d 73 68 ellman-group1-sh
00000090 61 31 00 00 00 0f 73 73 68 2d 72 73 61 2c 73 73 a1....ssh-rsa,ss
000000a0 68 2d 64 73 73 00 00 00 9f 61 65 73 32 35 36 2d h-dss....aes256-
000000b0 63 74 72 2c 61 65 73 32 35 36 2d 63 62 63 2c 72 ctr,aes256-cbc,r
000000c0 69 6a 6e 64 61 65 6c 2d 63 62 63 40 6c 79 73 61 ijndael-cbc@lysa
000000d0 74 6f 72 2e 6c 69 75 2e 73 65 2c 61 65 73 31 39 tor.liu.se,aes19
000000e0 32 2d 63 74 72 2c 61 65 73 31 39 32 2d 63 62 63 2-ctr,aes192-cbc
000000f0 2c 61 65 73 31 32 38 2d 63 74 72 2c 61 65 73 31 ,aes128-ctr,aes1
00000100 32 38 2d 63 62 63 2c 62 6c 6f 77 66 69 73 68 2d 28-cbc,blowfish-
00000110 63 74 72 2c 62 6c 6f 77 66 69 73 68 2d 63 62 63 ctr,blowfish-cbc
00000120 2c 33 64 65 73 2d 63 74 72 2c 33 64 65 73 2d 63 ,3des-ctr,3des-c
00000130 62 63 2c 61 72 63 66 6f 75 72 32 35 36 2c 61 72 bc,arcfour256,ar
00000140 63 66 6f 75 72 31 32 38 00 00 00 9f 61 65 73 32 cfour128....aes2
00000150 35 36 2d 63 74 72 2c 61 65 73 32 35 36 2d 63 62 56-ctr,aes256-cb
00000160 63 2c 72 69 6a 6e 64 61 65 6c 2d 63 62 63 40 6c c,rijndael-cbc@l
00000170 79 73 61 74 6f 72 2e 6c 69 75 2e 73 65 2c 61 65 ysator.liu.se,ae
00000180 73 31 39 32 2d 63 74 72 2c 61 65 73 31 39 32 2d s192-ctr,aes192-
00000190 63 62 63 2c 61 65 73 31 32 38 2d 63 74 72 2c 61 cbc,aes128-ctr,a
000001a0 65 73 31 32 38 2d 63 62 63 2c 62 6c 6f 77 66 69 es128-cbc,blowfi
000001b0 73 68 2d 63 74 72 2c 62 6c 6f 77 66 69 73 68 2d sh-ctr,blowfish-
000001c0 63 62 63 2c 33 64 65 73 2d 63 74 72 2c 33 64 65 cbc,3des-ctr,3de
000001d0 73 2d 63 62 63 2c 61 72 63 66 6f 75 72 32 35 36 s-cbc,arcfour256
000001e0 2c 61 72 63 66 6f 75 72 31 32 38 00 00 00 1f 68 ,arcfour128....h
000001f0 6d 61 63 2d 73 68 61 31 2c 68 6d 61 63 2d 73 68 mac-sha1,hmac-sh
00000200 61 31 2d 39 36 2c 68 6d 61 63 2d 6d 64 35 00 00 a1-96,hmac-md5..
00000210 00 1f 68 6d 61 63 2d 73 68 61 31 2c 68 6d 61 63 ..hmac-sha1,hmac
00000220 2d 73 68 61 31 2d 39 36 2c 68 6d 61 63 2d 6d 64 -sha1-96,hmac-md
00000230 35 00 00 00 09 6e 6f 6e 65 2c 7a 6c 69 62 00 00 5....none,zlib..
00000240 00 09 6e 6f 6e 65 2c 7a 6c 69 62 00 00 00 00 00 ..none,zlib.....
00000250 00 00 00 00 00 00 00 00 ........
Outgoing raw data
00000000 00 00 02 64 0a 14 d2 9e c0 d7 52 ee e6 0f 22 20 ...d......R..."
00000010 c3 f5 0b 6b a7 3d 00 00 00 7e 64 69 66 66 69 65 ...k.=...~diffie
00000020 2d 68 65 6c 6c 6d 61 6e 2d 67 72 6f 75 70 2d 65 -hellman-group-e
00000030 78 63 68 61 6e 67 65 2d 73 68 61 32 35 36 2c 64 xchange-sha256,d
00000040 69 66 66 69 65 2d 68 65 6c 6c 6d 61 6e 2d 67 72 iffie-hellman-gr
00000050 6f 75 70 2d 65 78 63 68 61 6e 67 65 2d 73 68 61 oup-exchange-sha
00000060 31 2c 64 69 66 66 69 65 2d 68 65 6c 6c 6d 61 6e 1,diffie-hellman
00000070 2d 67 72 6f 75 70 31 34 2d 73 68 61 31 2c 64 69 -group14-sha1,di
00000080 66 66 69 65 2d 68 65 6c 6c 6d 61 6e 2d 67 72 6f ffie-hellman-gro
00000090 75 70 31 2d 73 68 61 31 00 00 00 0f 73 73 68 2d up1-sha1....ssh-
000000a0 72 73 61 2c 73 73 68 2d 64 73 73 00 00 00 9f 61 rsa,ssh-dss....a
000000b0 65 73 32 35 36 2d 63 74 72 2c 61 65 73 32 35 36 es256-ctr,aes256
000000c0 2d 63 62 63 2c 72 69 6a 6e 64 61 65 6c 2d 63 62 -cbc,rijndael-cb
000000d0 63 40 6c 79 73 61 74 6f 72 2e 6c 69 75 2e 73 65 c@lysator.liu.se
000000e0 2c 61 65 73 31 39 32 2d 63 74 72 2c 61 65 73 31 ,aes192-ctr,aes1
000000f0 39 32 2d 63 62 63 2c 61 65 73 31 32 38 2d 63 74 92-cbc,aes128-ct
00000100 72 2c 61 65 73 31 32 38 2d 63 62 63 2c 62 6c 6f r,aes128-cbc,blo
00000110 77 66 69 73 68 2d 63 74 72 2c 62 6c 6f 77 66 69 wfish-ctr,blowfi
00000120 73 68 2d 63 62 63 2c 33 64 65 73 2d 63 74 72 2c sh-cbc,3des-ctr,
00000130 33 64 65 73 2d 63 62 63 2c 61 72 63 66 6f 75 72 3des-cbc,arcfour
00000140 32 35 36 2c 61 72 63 66 6f 75 72 31 32 38 00 00 256,arcfour128..
00000150 00 9f 61 65 73 32 35 36 2d 63 74 72 2c 61 65 73 ..aes256-ctr,aes
00000160 32 35 36 2d 63 62 63 2c 72 69 6a 6e 64 61 65 6c 256-cbc,rijndael
00000170 2d 63 62 63 40 6c 79 73 61 74 6f 72 2e 6c 69 75 -cbc@lysator.liu
00000180 2e 73 65 2c 61 65 73 31 39 32 2d 63 74 72 2c 61 .se,aes192-ctr,a
00000190 65 73 31 39 32 2d 63 62 63 2c 61 65 73 31 32 38 es192-cbc,aes128
000001a0 2d 63 74 72 2c 61 65 73 31 32 38 2d 63 62 63 2c -ctr,aes128-cbc,
000001b0 62 6c 6f 77 66 69 73 68 2d 63 74 72 2c 62 6c 6f blowfish-ctr,blo
000001c0 77 66 69 73 68 2d 63 62 63 2c 33 64 65 73 2d 63 wfish-cbc,3des-c
000001d0 74 72 2c 33 64 65 73 2d 63 62 63 2c 61 72 63 66 tr,3des-cbc,arcf
000001e0 6f 75 72 32 35 36 2c 61 72 63 66 6f 75 72 31 32 our256,arcfour12
000001f0 38 00 00 00 1f 68 6d 61 63 2d 73 68 61 31 2c 68 8....hmac-sha1,h
00000200 6d 61 63 2d 73 68 61 31 2d 39 36 2c 68 6d 61 63 mac-sha1-96,hmac
00000210 2d 6d 64 35 00 00 00 1f 68 6d 61 63 2d 73 68 61 -md5....hmac-sha
00000220 31 2c 68 6d 61 63 2d 73 68 61 31 2d 39 36 2c 68 1,hmac-sha1-96,h
00000230 6d 61 63 2d 6d 64 35 00 00 00 09 6e 6f 6e 65 2c mac-md5....none,
00000240 7a 6c 69 62 00 00 00 09 6e 6f 6e 65 2c 7a 6c 69 zlib....none,zli
00000250 62 00 00 00 00 00 00 00 00 00 00 00 00 00 ed 94 b...............
00000260 ab 8c a4 c7 bd 71 5a 78 .....qZx
Event Log: Using SSH protocol version 2
Incoming raw data
00000000 00 00 02 5c 05 14 01 8f 85 c0 24 22 e9 9a 1e 5c ...\......$"...\
00000010 94 39 bb b3 e0 72 00 00 00 59 64 69 66 66 69 65 .9...r...Ydiffie
00000030 78 63 68 61 6e 67 65 2d 73 68 61 31 2c 64 69 66 xchange-sha1,dif
00000040 66 69 65 2d 68 65 6c 6c 6d 61 6e 2d 67 72 6f 75 fie-hellman-grou
00000050 70 31 34 2d 73 68 61 31 2c 64 69 66 66 69 65 2d p14-sha1,diffie-
00000060 68 65 6c 6c 6d 61 6e 2d 67 72 6f 75 70 31 2d 73 hellman-group1-s
00000070 68 61 31 00 00 00 1f 73 73 68 2d 72 73 61 2c 73 ha1....ssh-rsa,s
00000080 73 68 2d 64 73 73 2c 73 73 68 2d 64 73 73 2c 73 sh-dss,ssh-dss,s
00000090 73 68 2d 72 73 61 00 00 00 81 61 65 73 31 32 38 sh-rsa....aes128
000000a0 2d 63 62 63 2c 33 64 65 73 2d 63 62 63 2c 62 6c -cbc,3des-cbc,bl
000000b0 6f 77 66 69 73 68 2d 63 62 63 2c 63 61 73 74 31 owfish-cbc,cast1
000000c0 32 38 2d 63 62 63 2c 61 72 63 66 6f 75 72 31 32 28-cbc,arcfour12
000000d0 38 2c 61 72 63 66 6f 75 72 32 35 36 2c 61 72 63 8,arcfour256,arc
000000e0 66 6f 75 72 2c 61 65 73 31 39 32 2d 63 62 63 2c four,aes192-cbc,
000000f0 61 65 73 32 35 36 2d 63 62 63 2c 61 65 73 31 32 aes256-cbc,aes12
00000100 38 2d 63 74 72 2c 61 65 73 31 39 32 2d 63 74 72 8-ctr,aes192-ctr
00000110 2c 61 65 73 32 35 36 2d 63 74 72 00 00 00 81 61 ,aes256-ctr....a
00000120 65 73 31 32 38 2d 63 62 63 2c 33 64 65 73 2d 63 es128-cbc,3des-c
00000130 62 63 2c 62 6c 6f 77 66 69 73 68 2d 63 62 63 2c bc,blowfish-cbc,
00000140 63 61 73 74 31 32 38 2d 63 62 63 2c 61 72 63 66 cast128-cbc,arcf
00000150 6f 75 72 31 32 38 2c 61 72 63 66 6f 75 72 32 35 our128,arcfour25
00000160 36 2c 61 72 63 66 6f 75 72 2c 61 65 73 31 39 32 6,arcfour,aes192
00000170 2d 63 62 63 2c 61 65 73 32 35 36 2d 63 62 63 2c -cbc,aes256-cbc,
00000180 61 65 73 31 32 38 2d 63 74 72 2c 61 65 73 31 39 aes128-ctr,aes19
00000190 32 2d 63 74 72 2c 61 65 73 32 35 36 2d 63 74 72 2-ctr,aes256-ctr
000001a0 00 00 00 3a 68 6d 61 63 2d 6d 64 35 2c 68 6d 61 ...:hmac-md5,hma
000001b0 63 2d 73 68 61 31 2c 68 6d 61 63 2d 72 69 70 65 c-sha1,hmac-ripe
000001c0 6d 64 31 36 30 2c 68 6d 61 63 2d 73 68 61 31 2d md160,hmac-sha1-
000001d0 39 36 2c 68 6d 61 63 2d 6d 64 35 2d 39 36 00 00 96,hmac-md5-96..
000001e0 00 3a 68 6d 61 63 2d 6d 64 35 2c 68 6d 61 63 2d .:hmac-md5,hmac-
000001f0 73 68 61 31 2c 68 6d 61 63 2d 72 69 70 65 6d 64 sha1,hmac-ripemd
00000200 31 36 30 2c 68 6d 61 63 2d 73 68 61 31 2d 39 36 160,hmac-sha1-96
00000210 2c 68 6d 61 63 2d 6d 64 35 2d 39 36 00 00 00 15 ,hmac-md5-96....
00000220 6e 6f 6e 65 2c 7a 6c 69 62 40 6f 70 65 6e 73 73 none,zlib@openss
00000230 68 2e 63 6f 6d 00 00 00 15 6e 6f 6e 65 2c 7a 6c h.com....none,zl
00000240 69 62 40 6f 70 65 6e 73 73 68 2e 63 6f 6d 00 00 ib@openssh.com..
00000250 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Incoming packet type 20 / 0x14 (SSH2_MSG_KEXINIT)
00000000 01 8f 85 c0 24 22 e9 9a 1e 5c 94 39 bb b3 e0 72 ....$"...\.9...r
00000010 00 00 00 59 64 69 66 66 69 65 2d 68 65 6c 6c 6d ...Ydiffie-hellm
00000030 65 2d 73 68 61 31 2c 64 69 66 66 69 65 2d 68 65 e-sha1,diffie-he
00000040 6c 6c 6d 61 6e 2d 67 72 6f 75 70 31 34 2d 73 68 llman-group14-sh
00000050 61 31 2c 64 69 66 66 69 65 2d 68 65 6c 6c 6d 61 a1,diffie-hellma
00000060 6e 2d 67 72 6f 75 70 31 2d 73 68 61 31 00 00 00 n-group1-sha1...
00000070 1f 73 73 68 2d 72 73 61 2c 73 73 68 2d 64 73 73 .ssh-rsa,ssh-dss
00000080 2c 73 73 68 2d 64 73 73 2c 73 73 68 2d 72 73 61 ,ssh-dss,ssh-rsa
00000090 00 00 00 81 61 65 73 31 32 38 2d 63 62 63 2c 33 ....aes128-cbc,3
000000a0 64 65 73 2d 63 62 63 2c 62 6c 6f 77 66 69 73 68 des-cbc,blowfish
000000b0 2d 63 62 63 2c 63 61 73 74 31 32 38 2d 63 62 63 -cbc,cast128-cbc
000000c0 2c 61 72 63 66 6f 75 72 31 32 38 2c 61 72 63 66 ,arcfour128,arcf
000000d0 6f 75 72 32 35 36 2c 61 72 63 66 6f 75 72 2c 61 our256,arcfour,a
000000e0 65 73 31 39 32 2d 63 62 63 2c 61 65 73 32 35 36 es192-cbc,aes256
000000f0 2d 63 62 63 2c 61 65 73 31 32 38 2d 63 74 72 2c -cbc,aes128-ctr,
00000100 61 65 73 31 39 32 2d 63 74 72 2c 61 65 73 32 35 aes192-ctr,aes25
00000110 36 2d 63 74 72 00 00 00 81 61 65 73 31 32 38 2d 6-ctr....aes128-
00000120 63 62 63 2c 33 64 65 73 2d 63 62 63 2c 62 6c 6f cbc,3des-cbc,blo
00000130 77 66 69 73 68 2d 63 62 63 2c 63 61 73 74 31 32 wfish-cbc,cast12
00000140 38 2d 63 62 63 2c 61 72 63 66 6f 75 72 31 32 38 8-cbc,arcfour128
00000150 2c 61 72 63 66 6f 75 72 32 35 36 2c 61 72 63 66 ,arcfour256,arcf
00000160 6f 75 72 2c 61 65 73 31 39 32 2d 63 62 63 2c 61 our,aes192-cbc,a
00000170 65 73 32 35 36 2d 63 62 63 2c 61 65 73 31 32 38 es256-cbc,aes128
00000180 2d 63 74 72 2c 61 65 73 31 39 32 2d 63 74 72 2c -ctr,aes192-ctr,
00000190 61 65 73 32 35 36 2d 63 74 72 00 00 00 3a 68 6d aes256-ctr...:hm
000001a0 61 63 2d 6d 64 35 2c 68 6d 61 63 2d 73 68 61 31 ac-md5,hmac-sha1
000001b0 2c 68 6d 61 63 2d 72 69 70 65 6d 64 31 36 30 2c ,hmac-ripemd160,
000001c0 68 6d 61 63 2d 73 68 61 31 2d 39 36 2c 68 6d 61 hmac-sha1-96,hma
000001d0 63 2d 6d 64 35 2d 39 36 00 00 00 3a 68 6d 61 63 c-md5-96...:hmac
000001e0 2d 6d 64 35 2c 68 6d 61 63 2d 73 68 61 31 2c 68 -md5,hmac-sha1,h
000001f0 6d 61 63 2d 72 69 70 65 6d 64 31 36 30 2c 68 6d mac-ripemd160,hm
00000200 61 63 2d 73 68 61 31 2d 39 36 2c 68 6d 61 63 2d ac-sha1-96,hmac-
00000210 6d 64 35 2d 39 36 00 00 00 15 6e 6f 6e 65 2c 7a md5-96....none,z
00000220 6c 69 62 40 6f 70 65 6e 73 73 68 2e 63 6f 6d 00 lib@openssh.com.
00000230 00 00 15 6e 6f 6e 65 2c 7a 6c 69 62 40 6f 70 65 ...none,zlib@ope
00000240 6e 73 73 68 2e 63 6f 6d 00 00 00 00 00 00 00 00 nssh.com........
00000250 00 00 00 00 00 .....
Event Log: Doing Diffie-Hellman group exchange
Outgoing packet type 30 / 0x1e (SSH2_MSG_KEX_DH_GEX_REQUEST)
00000000 00 00 08 00 ....
Outgoing raw data
00000000 00 00 00 0c 06 1e 00 00 08 00 77 c5 7d 89 3e 56 ..........w.}.>V
Incoming raw data
00000000 00 00 01 14 08 1f 00 00 01 01 00 ff ff ff ff ff ................
00000010 ff ff ff c9 0f da a2 21 68 c2 34 c4 c6 62 8b 80 .......!h.4..b..
00000020 dc 1c d1 29 02 4e 08 8a 67 cc 74 02 0b be a6 3b ...).N..g.t....;
00000030 13 9b 22 51 4a 08 79 8e 34 04 dd ef 95 19 b3 cd .."QJ.y.4.......
00000040 3a 43 1b 30 2b 0a 6d f2 5f 14 37 4f e1 35 6d 6d :C.0+.m._.7O.5mm
00000050 51 c2 45 e4 85 b5 76 62 5e 7e c6 f4 4c 42 e9 a6 Q.E...vb^~..LB..
00000060 37 ed 6b 0b ff 5c b6 f4 06 b7 ed ee 38 6b fb 5a 7.k..\......8k.Z
00000070 89 9f a5 ae 9f 24 11 7c 4b 1f e6 49 28 66 51 ec .....$.|K..I(fQ.
00000080 e4 5b 3d c2 00 7c b8 a1 63 bf 05 98 da 48 36 1c .[=..|..c....H6.
00000090 55 d3 9a 69 16 3f a8 fd 24 cf 5f 83 65 5d 23 dc U..i.?..$._.e]#.
000000a0 a3 ad 96 1c 62 f3 56 20 85 52 bb 9e d5 29 07 70 ....b.V .R...).p
000000b0 96 96 6d 67 0c 35 4e 4a bc 98 04 f1 74 6c 08 ca ..mg.5NJ....tl..
000000c0 18 21 7c 32 90 5e 46 2e 36 ce 3b e3 9e 77 2c 18 .!|2.^F.6.;..w,.
000000d0 0e 86 03 9b 27 83 a2 ec 07 a2 8f b5 c5 5d f0 6f ....'........].o
000000e0 4c 52 c9 de 2b cb f6 95 58 17 18 39 95 49 7c ea LR..+...X..9.I|.
000000f0 95 6a e5 15 d2 26 18 98 fa 05 10 15 72 8e 5a 8a .j...&......r.Z.
00000100 ac aa 68 ff ff ff ff ff ff ff ff 00 00 00 01 02 ..h.............
00000110 00 00 00 00 00 00 00 00 ........
Incoming packet type 31 / 0x1f (SSH2_MSG_KEX_DH_GEX_GROUP)
00000000 00 00 01 01 00 ff ff ff ff ff ff ff ff c9 0f da ................
00000010 a2 21 68 c2 34 c4 c6 62 8b 80 dc 1c d1 29 02 4e .!h.4..b.....).N
00000020 08 8a 67 cc 74 02 0b be a6 3b 13 9b 22 51 4a 08 ..g.t....;.."QJ.
00000030 79 8e 34 04 dd ef 95 19 b3 cd 3a 43 1b 30 2b 0a y.4.......:C.0+.
00000040 6d f2 5f 14 37 4f e1 35 6d 6d 51 c2 45 e4 85 b5 m._.7O.5mmQ.E...
00000050 76 62 5e 7e c6 f4 4c 42 e9 a6 37 ed 6b 0b ff 5c vb^~..LB..7.k..\
00000060 b6 f4 06 b7 ed ee 38 6b fb 5a 89 9f a5 ae 9f 24 ......8k.Z.....$
00000070 11 7c 4b 1f e6 49 28 66 51 ec e4 5b 3d c2 00 7c .|K..I(fQ..[=..|
00000080 b8 a1 63 bf 05 98 da 48 36 1c 55 d3 9a 69 16 3f ..c....H6.U..i.?
00000090 a8 fd 24 cf 5f 83 65 5d 23 dc a3 ad 96 1c 62 f3 ..$._.e]#.....b.
000000a0 56 20 85 52 bb 9e d5 29 07 70 96 96 6d 67 0c 35 V .R...).p..mg.5
000000b0 4e 4a bc 98 04 f1 74 6c 08 ca 18 21 7c 32 90 5e NJ....tl...!|2.^
000000c0 46 2e 36 ce 3b e3 9e 77 2c 18 0e 86 03 9b 27 83 F.6.;..w,.....'.
000000d0 a2 ec 07 a2 8f b5 c5 5d f0 6f 4c 52 c9 de 2b cb .......].oLR..+.
000000e0 f6 95 58 17 18 39 95 49 7c ea 95 6a e5 15 d2 26 ..X..9.I|..j...&
000000f0 18 98 fa 05 10 15 72 8e 5a 8a ac aa 68 ff ff ff ......r.Z...h...
00000100 ff ff ff ff ff 00 00 00 01 02 ..........
Event Log: Doing Diffie-Hellman key exchange with hash SHA-1
Outgoing packet type 32 / 0x20 (SSH2_MSG_KEX_DH_GEX_INIT)
00000000 00 00 01 01 00 9a a7 0f 49 f4 2b 32 d8 d2 ba 81 ........I.+2....
00000010 2b 65 77 39 82 73 de a6 63 18 44 d4 5e 36 7f ee +ew9.s..c.D.^6..
00000020 17 30 f9 48 5e 88 27 7e 50 cc be ed b9 ce 06 d0 .0.H^.'~P.......
00000030 a4 2c a7 25 57 f8 7b 6a 21 94 df 62 db b2 91 97 .,.%W.{j!..b....
00000040 89 b4 2e 58 a3 09 7e be 20 cb db f5 10 c3 9c 6d ...X..~. ......m
00000050 3e f5 18 80 df 0f 92 98 60 ae c8 ad e8 b8 50 d4 >.......`.....P.
00000060 dd 57 4b b8 45 60 c5 a3 78 e5 5e ea 45 8b 0e 73 .WK.E`..x.^.E..s
00000070 98 57 0b d4 cc 5b 60 91 35 00 60 6b 30 ac 2e 72 .W...[`.5.`k0..r
00000080 31 4b 4e 70 92 e9 12 e6 48 8b e0 23 76 b7 c0 d7 1KNp....H..#v...
00000090 80 70 05 3b e0 c0 d6 ad 23 5d 91 09 11 99 ee d1 .p.;....#]......
000000a0 47 28 67 71 53 5e 10 10 12 ed c4 8d 9a 0c 69 93 G(gqS^........i.
000000b0 42 27 42 5d b0 bf 48 02 50 33 88 18 b3 30 b0 cf B'B]..H.P3...0..
000000c0 d9 d3 ba ab 8d fa 67 59 38 d6 4e eb 2f b7 17 76 ......gY8.N./..v
000000d0 a8 d2 86 c0 7f a4 d0 52 99 6b 3f 63 2d 5f e6 62 .......R.k?c-_.b
000000e0 85 64 05 6c 50 d6 ea 0a 29 2c b1 02 ad 4f e1 1f .d.lP...),...O..
000000f0 b3 56 7c ee 40 e4 d8 df ab f6 3b bf 8d e3 7b 63 .V|.@.....;...{c
00000100 de fc 68 ef e8 ..h..
Outgoing raw data
00000000 00 00 01 0c 05 20 00 00 01 01 00 9a a7 0f 49 f4 ..... ........I.
00000010 2b 32 d8 d2 ba 81 2b 65 77 39 82 73 de a6 63 18 +2....+ew9.s..c.
00000020 44 d4 5e 36 7f ee 17 30 f9 48 5e 88 27 7e 50 cc D.^6...0.H^.'~P.
00000030 be ed b9 ce 06 d0 a4 2c a7 25 57 f8 7b 6a 21 94 .......,.%W.{j!.
00000040 df 62 db b2 91 97 89 b4 2e 58 a3 09 7e be 20 cb .b.......X..~. .
00000050 db f5 10 c3 9c 6d 3e f5 18 80 df 0f 92 98 60 ae .....m>.......`.
00000060 c8 ad e8 b8 50 d4 dd 57 4b b8 45 60 c5 a3 78 e5 ....P..WK.E`..x.
00000070 5e ea 45 8b 0e 73 98 57 0b d4 cc 5b 60 91 35 00 ^.E..s.W...[`.5.
00000080 60 6b 30 ac 2e 72 31 4b 4e 70 92 e9 12 e6 48 8b `k0..r1KNp....H.
00000090 e0 23 76 b7 c0 d7 80 70 05 3b e0 c0 d6 ad 23 5d .#v....p.;....#]
000000a0 91 09 11 99 ee d1 47 28 67 71 53 5e 10 10 12 ed ......G(gqS^....
000000b0 c4 8d 9a 0c 69 93 42 27 42 5d b0 bf 48 02 50 33 ....i.B'B]..H.P3
000000c0 88 18 b3 30 b0 cf d9 d3 ba ab 8d fa 67 59 38 d6 ...0........gY8.
000000d0 4e eb 2f b7 17 76 a8 d2 86 c0 7f a4 d0 52 99 6b N./..v.......R.k
000000e0 3f 63 2d 5f e6 62 85 64 05 6c 50 d6 ea 0a 29 2c ?c-_.b.d.lP...),
000000f0 b1 02 ad 4f e1 1f b3 56 7c ee 40 e4 d8 df ab f6 ...O...V|.@.....
00000100 3b bf 8d e3 7b 63 de fc 68 ef e8 c4 a8 ff 7c 33 ;...{c..h.....|3
Incoming raw data
00000000 00 00 03 3c 09 21 00 00 01 15 00 00 00 07 73 73 ...<.!........ss
00000010 68 2d 72 73 61 00 00 00 01 23 00 00 01 01 00 ee h-rsa....#......
00000020 d7 fc 18 d7 89 1f 0d 12 12 58 bc 16 8c e8 c3 22 .........X....."
00000030 f1 a2 b0 90 86 25 2f 9e 78 7d 89 90 6b 5d b1 58 .....%/.x}..k].X
00000040 22 75 49 56 74 94 cb 64 58 8e 74 23 e2 af 20 5e "uIVt..dX.t#.. ^
00000050 cc 1e 42 e4 f8 db b6 14 0a a9 7f 2c 56 4b 7a 9f ..B........,VKz.
00000060 1d 1b 7d ee 32 29 76 58 15 68 79 0f 36 7f fd 96 ..}.2)vX.hy.6...
00000070 a6 8c 1e 2d e8 50 c2 8f 6a 6c f7 25 c6 cc e3 a3 ...-.P..jl.%....
00000080 dc 13 a1 0f ce 28 af 2f 1a 9f df 5d 54 dd 5c cb .....(./...]T.\.
00000090 f4 19 e9 4e 5b be 7d d5 e3 a4 90 a2 29 e8 c8 f4 ...N[.}.....)...
000000a0 8b 8e be ce 06 8c 02 b1 18 d5 33 d7 a7 d0 1e 3d ..........3....=
000000b0 d7 b9 69 5f 88 20 e8 0b 77 87 1b 73 dd 16 ab c2 ..i_. ..w..s....
000000c0 b2 4b 4d 89 a4 b9 4a 92 ab 8f c8 c9 22 04 c4 c6 .KM...J....."...
000000d0 ea f9 ea 7b ed 14 7a ce 64 fe dc 27 03 cf a5 73 ...{..z.d..'...s
000000e0 c6 4d 25 f8 7e 58 a5 de a8 59 02 50 2a 17 19 95 .M%.~X...Y.P*...
000000f0 16 02 58 e3 2a 0b 3e ef e5 47 cd a3 c7 db 71 33 ..X.*.>..G....q3
00000100 fe 08 17 de 29 75 a4 a9 0b 28 1e b1 09 ff f0 6f ....)u...(.....o
00000110 71 f8 9c 02 9a 11 e7 21 c3 64 c9 80 ba e9 37 00 q......!.d....7.
00000120 00 01 01 00 a4 6a cf b7 e6 78 18 e3 fa a6 8d 63 .....j...x.....c
00000130 31 10 38 16 77 ed 21 76 94 42 17 29 75 4a 7f 01 1.8.w.!v.B.)uJ..
00000140 10 4e 59 5e 9d a0 32 c5 bb 92 d2 42 33 40 1e e1 .NY^..2....B3@..
00000150 c5 38 2e 46 76 24 86 66 73 f1 9f 85 e1 3f 08 89 .8.Fv$.fs....?..
00000160 c4 81 47 90 e5 57 06 b5 b1 d7 67 cf 5e 29 ef e7 ..G..W....g.^)..
00000170 df b4 3c c8 af 22 41 71 4e 5d 28 cb 0c 16 ae dd ..<.."AqN](.....
00000180 45 ca 11 54 52 96 d5 0d 23 00 70 d5 90 a5 d9 4f E..TR...#.p....O
00000190 ac bc df 7b 91 66 ba 42 48 df d9 01 b3 63 1b 65 ...{.f.BH....c.e
000001a0 23 41 2e 9c fa 52 73 2a 06 55 eb 6e 5d f9 89 24 #A...Rs*.U.n]..$
000001b0 fa 4a 09 3e 99 73 0b d2 aa b2 10 59 f5 cb 8b f9 .J.>.s.....Y....
000001c0 d8 12 47 e5 ac 3d f5 ea 1b 3d e9 a0 42 d3 4c 17 ..G..=...=..B.L.
000001d0 ac f1 c0 55 9e d1 af 1f ee 5b 9e 8e ad 0b a7 35 ...U.....[.....5
000001e0 2e 81 76 23 a9 65 a3 ba ba a3 d3 36 38 57 7a fa ..v#.e.....68Wz.
000001f0 50 b7 b6 00 55 9e 3d 53 32 4a 89 95 d2 4c 23 56 P...U.=S2J...L#V
00000200 ac 54 0b 07 1b 71 f6 d2 62 49 df 19 30 26 d5 b1 .T...q..bI..0&..
00000210 2b 72 29 14 07 7b 23 d4 1e 09 4f d0 c8 54 74 ff +r)..{#...O..Tt.
00000220 99 5c f0 53 00 00 01 0f 00 00 00 07 73 73 68 2d .\.S........ssh-
00000230 72 73 61 00 00 01 00 44 f2 31 c2 2b 87 da 8f f4 rsa....D.1.+....
00000240 5a 93 13 ac fe 29 04 4e 28 9a 05 80 5f ff 46 e1 Z....).N(..._.F.
00000250 a8 7a 2f 85 ee 14 2f b2 a2 60 3e 5f 90 2d b7 9a .z/.../..`>_.-..
00000260 c5 47 0d 2c 33 d2 81 29 8a 94 ed 79 b8 37 bd 91 .G.,3..)...y.7..
00000270 47 80 45 3e 0e 9a ad fa 8a 1f 3c a4 9b be f8 51 G.E>......<....Q
00000280 20 0c 24 a6 4b c6 b0 65 8b 94 14 41 43 1b 99 a4 .$.K..e...AC...
00000290 b5 50 5b 73 63 2a c8 f3 c0 dd a6 23 b2 66 02 37 .P[sc*.....#.f.7
000002a0 55 c6 d1 61 78 62 70 38 1b 99 fe 9f fd b2 71 3b U..axbp8......q;
000002b0 d2 bf 2f 0e 49 d9 98 2f 6b d5 be 80 ee 4c bb ba ../.I../k....L..
000002c0 5f c0 ca 73 59 a8 56 d8 2a 08 b3 d9 c2 f4 41 49 _..sY.V.*.....AI
000002d0 4c 93 1c f9 4f 4a ad 3b 64 75 68 81 50 63 97 15 L...OJ.;duh.Pc..
000002e0 b4 48 80 95 a3 c6 31 4c ce e1 6a 59 27 9c dc ec .H....1L..jY'...
000002f0 3a f5 57 5c 1f ce 33 5a ef b4 6f d7 8a 35 bf 0d :.W\..3Z..o..5..
00000300 58 ee 39 58 5a 39 ff a3 63 ce 88 59 2b 3e fc 5b X.9XZ9..c..Y+>.[
00000310 e1 5e 84 f4 84 31 c6 9a 12 5c 32 f1 8a 37 cd e4 .^...1...\2..7..
00000320 87 50 58 e1 9c 0a 14 13 60 74 b1 38 dd 25 e6 ae .PX.....`t.8.%..
00000330 1f 60 30 47 df 6c bc 00 00 00 00 00 00 00 00 00 .`0G.l..........
00000340 00 00 00 0c 0a 15 00 00 00 00 00 00 00 00 00 00 ................
Incoming packet type 33 / 0x21 (SSH2_MSG_KEX_DH_GEX_REPLY)
00000000 00 00 01 15 00 00 00 07 73 73 68 2d 72 73 61 00 ........ssh-rsa.
00000010 00 00 01 23 00 00 01 01 00 ee d7 fc 18 d7 89 1f ...#............
00000020 0d 12 12 58 bc 16 8c e8 c3 22 f1 a2 b0 90 86 25 ...X.....".....%
00000030 2f 9e 78 7d 89 90 6b 5d b1 58 22 75 49 56 74 94 /.x}..k].X"uIVt.
00000040 cb 64 58 8e 74 23 e2 af 20 5e cc 1e 42 e4 f8 db .dX.t#.. ^..B...
00000050 b6 14 0a a9 7f 2c 56 4b 7a 9f 1d 1b 7d ee 32 29 .....,VKz...}.2)
00000060 76 58 15 68 79 0f 36 7f fd 96 a6 8c 1e 2d e8 50 vX.hy.6......-.P
00000070 c2 8f 6a 6c f7 25 c6 cc e3 a3 dc 13 a1 0f ce 28 ..jl.%.........(
00000080 af 2f 1a 9f df 5d 54 dd 5c cb f4 19 e9 4e 5b be ./...]T.\....N[.
00000090 7d d5 e3 a4 90 a2 29 e8 c8 f4 8b 8e be ce 06 8c }.....).........
000000a0 02 b1 18 d5 33 d7 a7 d0 1e 3d d7 b9 69 5f 88 20 ....3....=..i_.
000000b0 e8 0b 77 87 1b 73 dd 16 ab c2 b2 4b 4d 89 a4 b9 ..w..s.....KM...
000000c0 4a 92 ab 8f c8 c9 22 04 c4 c6 ea f9 ea 7b ed 14 J....."......{..
000000d0 7a ce 64 fe dc 27 03 cf a5 73 c6 4d 25 f8 7e 58 z.d..'...s.M%.~X
000000e0 a5 de a8 59 02 50 2a 17 19 95 16 02 58 e3 2a 0b ...Y.P*.....X.*.
000000f0 3e ef e5 47 cd a3 c7 db 71 33 fe 08 17 de 29 75 >..G....q3....)u
00000100 a4 a9 0b 28 1e b1 09 ff f0 6f 71 f8 9c 02 9a 11 ...(.....oq.....
00000110 e7 21 c3 64 c9 80 ba e9 37 00 00 01 01 00 a4 6a .!.d....7......j
00000120 cf b7 e6 78 18 e3 fa a6 8d 63 31 10 38 16 77 ed ...x.....c1.8.w.
00000130 21 76 94 42 17 29 75 4a 7f 01 10 4e 59 5e 9d a0 !v.B.)uJ...NY^..
00000140 32 c5 bb 92 d2 42 33 40 1e e1 c5 38 2e 46 76 24 2....B3@...8.Fv$
00000150 86 66 73 f1 9f 85 e1 3f 08 89 c4 81 47 90 e5 57 .fs....?....G..W
00000160 06 b5 b1 d7 67 cf 5e 29 ef e7 df b4 3c c8 af 22 ....g.^)....<.."
00000170 41 71 4e 5d 28 cb 0c 16 ae dd 45 ca 11 54 52 96 AqN](.....E..TR.
00000180 d5 0d 23 00 70 d5 90 a5 d9 4f ac bc df 7b 91 66 ..#.p....O...{.f
00000190 ba 42 48 df d9 01 b3 63 1b 65 23 41 2e 9c fa 52 .BH....c.e#A...R
000001a0 73 2a 06 55 eb 6e 5d f9 89 24 fa 4a 09 3e 99 73 s*.U.n]..$.J.>.s
000001b0 0b d2 aa b2 10 59 f5 cb 8b f9 d8 12 47 e5 ac 3d .....Y......G..=
000001c0 f5 ea 1b 3d e9 a0 42 d3 4c 17 ac f1 c0 55 9e d1 ...=..B.L....U..
000001d0 af 1f ee 5b 9e 8e ad 0b a7 35 2e 81 76 23 a9 65 ...[.....5..v#.e
000001e0 a3 ba ba a3 d3 36 38 57 7a fa 50 b7 b6 00 55 9e .....68Wz.P...U.
000001f0 3d 53 32 4a 89 95 d2 4c 23 56 ac 54 0b 07 1b 71 =S2J...L#V.T...q
00000200 f6 d2 62 49 df 19 30 26 d5 b1 2b 72 29 14 07 7b ..bI..0&..+r)..{
00000210 23 d4 1e 09 4f d0 c8 54 74 ff 99 5c f0 53 00 00 #...O..Tt..\.S..
00000220 01 0f 00 00 00 07 73 73 68 2d 72 73 61 00 00 01 ......ssh-rsa...
00000230 00 44 f2 31 c2 2b 87 da 8f f4 5a 93 13 ac fe 29 .D.1.+....Z....)
00000240 04 4e 28 9a 05 80 5f ff 46 e1 a8 7a 2f 85 ee 14 .N(..._.F..z/...
00000250 2f b2 a2 60 3e 5f 90 2d b7 9a c5 47 0d 2c 33 d2 /..`>_.-...G.,3.
00000260 81 29 8a 94 ed 79 b8 37 bd 91 47 80 45 3e 0e 9a .)...y.7..G.E>..
00000270 ad fa 8a 1f 3c a4 9b be f8 51 20 0c 24 a6 4b c6 ....<....Q .$.K.
00000280 b0 65 8b 94 14 41 43 1b 99 a4 b5 50 5b 73 63 2a .e...AC....P[sc*
00000290 c8 f3 c0 dd a6 23 b2 66 02 37 55 c6 d1 61 78 62 .....#.f.7U..axb
000002a0 70 38 1b 99 fe 9f fd b2 71 3b d2 bf 2f 0e 49 d9 p8......q;../.I.
000002b0 98 2f 6b d5 be 80 ee 4c bb ba 5f c0 ca 73 59 a8 ./k....L.._..sY.
000002c0 56 d8 2a 08 b3 d9 c2 f4 41 49 4c 93 1c f9 4f 4a V.*.....AIL...OJ
000002d0 ad 3b 64 75 68 81 50 63 97 15 b4 48 80 95 a3 c6 .;duh.Pc...H....
000002e0 31 4c ce e1 6a 59 27 9c dc ec 3a f5 57 5c 1f ce 1L..jY'...:.W\..
000002f0 33 5a ef b4 6f d7 8a 35 bf 0d 58 ee 39 58 5a 39 3Z..o..5..X.9XZ9
00000300 ff a3 63 ce 88 59 2b 3e fc 5b e1 5e 84 f4 84 31 ..c..Y+>.[.^...1
00000310 c6 9a 12 5c 32 f1 8a 37 cd e4 87 50 58 e1 9c 0a ...\2..7...PX...
00000320 14 13 60 74 b1 38 dd 25 e6 ae 1f 60 30 47 df 6c ..`t.8.%...`0G.l
00000330 bc .
Event Log: Host key fingerprint is:
Event Log: ssh-rsa 2048 0d:17:22:1e:80:3c:81:21:0b:16:34:2a:f6:63:22:66
Outgoing packet type 21 / 0x15 (SSH2_MSG_NEWKEYS)
Outgoing raw data
00000000 00 00 00 0c 0a 15 4d 08 86 0f f7 da 2d 3a 67 0c ......M.....-:g.
Event Log: Initialised AES-256 SDCTR client->server encryption
Event Log: Initialised HMAC-SHA1 client->server MAC algorithm
Outgoing raw data
Incoming packet type 21 / 0x15 (SSH2_MSG_NEWKEYS)
Event Log: Initialised AES-256 SDCTR server->client encryption
Event Log: Initialised HMAC-SHA1 server->client MAC algorithm
Outgoing packet type 5 / 0x05 (SSH2_MSG_SERVICE_REQUEST)
00000000 00 00 00 0c 73 73 68 2d 75 73 65 72 61 75 74 68 ....ssh-userauth
Outgoing raw data
00000000 11 a3 b3 e6 55 03 5f 9f c9 27 ef 02 88 30 0b d1 ....U._..'...0..
00000010 e0 03 95 2d bc ce 02 3d ee dc 13 e2 4c 89 86 b3 ...-...=....L...
00000020 1e ad ca 44 0d 49 a3 b9 1e d9 83 72 9e c4 a7 5c ...D.I.....r...\
00000030 15 26 82 46 .&.F
Incoming raw data
00000000 51 a6 00 83 b4 3f b9 d5 73 47 b0 73 dd 61 ec 76 Q....?..sG.s.a.v
00000010 00 6d 0b 6a 44 36 aa fb e3 d2 21 13 fc 34 75 96 .m.jD6....!..4u.
00000020 57 f8 ce e0 8c 56 d9 30 59 fb 43 43 b3 11 79 d8 W....V.0Y.CC..y.
00000030 2b 32 ba 61 04 46 5c 27 ee 5e bb ce c5 f5 8d 91 +2.a.F\'.^......
00000040 c1 7e 8c 0d 68 19 32 b0 d8 88 38 28 a4 9c c8 ea .~..h.2...8(....
00000050 45 85 3c 32 E.<2
Event Log: Incoming packet was garbled on decryption
OK, thanks. Can you please report this to PuTTY development team?
