Topic "unable to list home directory"
mauri3000856
Hi.
I'm using winscp 4.2.7 build 758 in windows 2003 r2 sp2.
I'm using (for testing) in the same machine Core FTP server.
When i try to sftp using filezilla client all is ok
When i use winscp i can login but immediatly i recevive an error messagge:
Cannot get real path for '.'.
No such file or directory.
Error code: 2
Error message from server: No such file
Request code: 16
All is ok using filezilla client.
Can anybody help me?
Can you post a log file both from WinSCP and Filezilla?
mauri300856
Hi.
Using 4.2.5 all is fine.
Do you need the log anyway?
Can you try 4.2.6?
mauri300856
prikryl wrote:
Can you try 4.2.6?
Hi.
Using 4.2.6 i can list the home directory.
Bye.
Ok. Can you now reinstall the 4.2.7 over 4.2.6 and try again?
mauri300856
Hi.
I made a complete install over 4.2.6 and now it's ok.
What does it means?
Should i do two installations?
Bye
I do not know what it means. I was just pretty sure that there was no change between 4.2.5 and 4.2.7 that could introduce the problem.
