Topic "Getting an "Assertion Failed" error when using script"
kballard
OS: Windows Server 2003
WinSCP Version: 4.2.7
Protocol: SFTP
Script Used:
option batch on
option transfer binary
open uname:password@server
put \\path\file.zip
I run the script via:
Winscp.com /script="C:\scriptfile.txt"
When I run the above script, 4 times out of 5 I get the following error:
Assertion failed: xdrPtr && xdrPtr == *xdrLPP, file xx.cpp, line 2233
Once I click OK on that error, I get another message stating "Abnormal program termination"
The file being uploaded is usually about 190 MB in size. The machine on which the script is being called is a virtual machine, with full connectivity. The machine it's connecting to may sometimes drop the connection, but I don't think this is usually the case.
I have sent you a debug version.
kballard
Well, now that I have the debug version, it won't error. Go figure. Thanks for your help.
Let me know if ever happens.
kballard
The debug version is now throwing a similar but different error. I have the log, but do not see how to upload attachments here. I can upload the log contents, but it is a 147MB text file. If you can show me where to upload an attachment, or point me to the correct location in the log file to find the error, I can provide the info.
Thanks!
147 MB text file should be still reasonably large to email when compressed, shouldn't it?
kballard
It's 9MB. I can email to you.
kballard
I've sent you the latest error logs via email. I believe I sent it Tuesday this week.
Thanks!
Kevin
I take it that I didn't reply you. What was subject of the message?
kballard
Sorry, I should have been more clear. The subject was "RE: Error Log", and it was sent on August 16th.
Would you like me to re-send it?
I've got it. And I've replied you on August 17th. I've resent my reply just now.
kballard
Yes, got your email response. Downloaded and installed latest debug version. Worked great until today. I'm sending the logs to you via email. Thanks.
