Topic "Not able to SFTP in MainFrame by Winscp"
singhpk
I am not able to do SFTP in mainframe. Error occurring is below ...
Connecting to 10.15.243.11:20021 ...
Connected with 10.15.243.11:20021, negotiating SSL connection...
SSL connection established. Waiting for welcome message...
Connected
Starting the session...
Reading remote directory...
Session started.
Active session: [1] MF
transfer binary
D:\manish\ZZZZ0705.T02 | 0 KiB | 0.0 KiB/s | binary | 0%
Error transferring file 'D:\manish\ZZZZ0705.T02'.
CWD cmd failed : EDC5129I No such file or directory.
(A)bort, (R)etry, (S)kip, Ski(p) all:
Please help. Crying or Very sad
DGorthat
Are you useing a proxy server?
in that case try another setting for passive or active mode for the filetransfer.
Dirk
singhpk
Dirk
No, I am not using proxy server.
File Protocol Using FTP & SSL Explicit Encryption.
pradeepbokaro
Very Happy I have resolved the problem, there was Syntax problem.
Now I able to do successful FTP to Mainframe dataset.
chang
Could you please elaborate on what you did to fix the syntax/issue?, i have the same issue
Tejaswi
I am trying to sftp from mainframe to windows. I have set up the keys properly but asking for password.
I have checked logs in windwows server for the perticular ID and i can see the below error message.
CAn not initialize user context.User ftpbudget does not exist or getting user info failed.
I assume you are not using WinSCP.
