Topic "How to remove/hide Local view from Commander view?"
jsherk
EDIT:
My original resolution I posted here was WRONG, so I have removed it and now I have to ask the question:
Is it possible to hide the Local view in Commander view?
jsherk
Using Explorer view is one solution:
http://winscp.net/forum/viewtopic.php?p=30922
Susan_Susan
Everyone at our company needs that same (impossible to do) feature.
*STAY* in the "commander view" while *NOT* showing the local folder.
We *NEVER* use the local folder.
We *NEVER* use the "explorer view".
Why is WinSCP missing so many simple features?
Well the Explorer interface is the Commander interface without the local panel. What's wrong with it?
MrNerdHair
I second this request! Explorer mode lacks the essential ".." directory, and does not allow a directory tree at the top of the window. I usually use WinSCP in a thin, tall window next to my text editor, and a horizontal tree is perfect for using all those vertical pixels. Alas, only commander mode has it, and you can't lose the local folder in that mode.
MrNerdHair
(just registered, this is me now.)
OK, I'll consider adding the .. and an option to position the directory tree above the file list (instead of left of the list), if more people ask for it.
