Topic "Zip and Unzip files"
imperialx
Is there a feature in WinSCP that can zip or unzip files? Thanks!
Local or remote file? For remote files you can use custom commands.
imperialx
Hi prikryl,
Forgive me if I didn't understand your reply, are you saying that I can indeed unzip files within WinSCP remotely?
I have this scenario where I zip my files locally then upload the zipped file through WinSCP at my hoster. Once uploaded, I would like to unzipped the file within WinSCP, is this possible?
And where can I input the custom commands?
Thank you for your help.
cheers,
-imperialx
Correct. Under some circumstances.
You will find all the details on the page linked in my previous post.
imperialx
Hi prikryl,
There is this one list "Zip" under custom commands section with this syntax unzip "!", however, I'm getting this error "Windows cannot find 'unzip'. Make sure you typed the name correctly, and then try again."
I uploaded a zipped file (photo.zip) to remote then select the uploaded zipped file, next, using the custom command dialog, I input this custom command unzip "!" and that is how I get the error.
Did I miss anything?
imperialx
I suppose you wanted to execute the command on the server side, didn't you? So make sure to select Remote command on the custom command dialog.
imperialx
Hi prikryl,
Under File > Custom Commands, I can't find the Remote command button.
imperialx
Tracster
I am trying to unzip a file on the remote site, and also get the error message "Windows cannot find unzip" after it copies the files to a temporary location.
Does this command only work on windows servers, as most servers are not run on windows?
Make sure you use remote custom command. You seem to be using local custom command.
Tomas Tobis
Hi Martin. I use WinScp in Windows style mode. I also would like to do zipping/unzipping, but it is horribly hard to do. Also the documentation you pointed to is hard to understand. Can you provide please real steps how to zip/unzip the remote file ? I mean file on FTP server I am connected to.
I tried many things, I tried to edit Custom commands, but then question appeared, how can I use them ? I tried also Commands/Open Terminal and I tried to Execute some commands. No success. I think it is time to show, how this magic really works Laughing
Tomas
P.S.: Wouldn't it be great to have context menu option for zipping/unzipping files ?
The custom commands do not work with FTP. Only with SCP and possibly with SFTP.
CoyoteKG
Hello, I'm trying to zip wordpress site over FTP, and transfer it locally.
I found this command on your documentation, but I don't know how to use it.
zip -r "!?&Enter an Archive Name:?archive.zip!" !&
Please, can you write example, like file name is just backup.zip
You cannot run arbitrary shell commands over FTP session. Only SFTP/SCP.
RichardHC
The easiest, fastest, best way to unzip a file on your hosting site is to be sure you zip it recursively so you have the files in their correct folders, upload it by FTP then log into your hosting service C-panel, select the file manager, go to the folder you uploaded the zip file to, select it then click on "extract" - add a path to where you want it unzipped to or just extract it into the root folder of your domain folder. Done. Easy.
Six years gone and I was hoping to find some "better" solution than filezilla+cpanel for zipping/unzipping on the server but seems no way Sad((
Any good news I missed?
I believe this thread shows the way. Or what are you looking for?
thx prikryl!
I imagine an easy peasy right-click zip/unzip option (rar, gzip, etc...) Wink
That's it.
Just define a custom command that works on your specific server.
http://winscp.net/eng/docs/custom_commands#archiving
There's no standard solution that works everywhere.
