Topic "GSSAPI Error With 4.2.8"
a178235
Assertion failed: s->gsslib file putty\ssh.c, line 7970
a178235
Assertion failed: s->gsslib file putty\ssh.c, line 7974
prikryl
Thanks, but I need log file generated by the debug version.
The log below doesn't seems to indicate anything as it's cut short. Is there a more detailed log created? What's weird is that it seemed to work one time, but I haven't been able to get it working since.
. 2010-08-02 14:31:33.838 --------------------------------------------------------------------------
. 2010-08-02 14:31:33.856 WinSCP Version 4.2.8 (Build 818) (OS 6.1.7600)
. 2010-08-02 14:31:33.859 Login time: Monday, August 02, 2010 2:31:33 PM
. 2010-08-02 14:31:33.864 --------------------------------------------------------------------------
. 2010-08-02 14:31:33.868 Session name: username@replaced.server.name.com
. 2010-08-02 14:31:33.871 Host name: replaced.server.name.com (Port: 22)
. 2010-08-02 14:31:33.874 User name: username (Password: No, Key file: No)
. 2010-08-02 14:31:33.877 Tunnel: No
. 2010-08-02 14:31:33.880 Transfer Protocol: SFTP (SCP)
. 2010-08-02 14:31:33.883 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2010-08-02 14:31:33.885 Proxy: none
. 2010-08-02 14:31:33.889 SSH protocol version: 2; Compression: No
. 2010-08-02 14:31:33.902 Bypass authentication: No
. 2010-08-02 14:31:33.906 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: Yes
. 2010-08-02 14:31:33.908 GSSAPI: Forwarding: No; Server realm:
. 2010-08-02 14:31:33.911 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2010-08-02 14:31:33.914 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2010-08-02 14:31:33.918 SFTP Bugs: -,-
. 2010-08-02 14:31:33.921 Return code variable: Autodetect; Lookup user groups: Yes
. 2010-08-02 14:31:33.924 Shell: default
. 2010-08-02 14:31:33.926 EOL: 0, UTF: 2
. 2010-08-02 14:31:33.930 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2010-08-02 14:31:33.933 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2010-08-02 14:31:33.936 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-08-02 14:31:33.940 Cache directory changes: Yes, Permanent: Yes
. 2010-08-02 14:31:33.942 DST mode: 1
. 2010-08-02 14:31:33.947 --------------------------------------------------------------------------
. 2010-08-02 14:31:34.980 Looking up host "replaced.server.name.com"
. 2010-08-02 14:31:35.005 Connecting to 10.10.10.10 port 22
. 2010-08-02 14:31:35.023 Selecting events 63 for socket 896
. 2010-08-02 14:31:35.102 Waiting for the server to continue with the initialisation
. 2010-08-02 14:31:35.108 Looking for incoming data
. 2010-08-02 14:31:35.119 Looking for network events
. 2010-08-02 14:31:35.127 Detected network event
. 2010-08-02 14:31:35.135 Enumerating network events for socket 896
. 2010-08-02 14:31:35.144 Enumerated 19 network events making 19 cumulative events for socket 896
. 2010-08-02 14:31:35.154 Handling network read event on socket 896 with error 0
. 2010-08-02 14:31:35.161 Server version: SSH-2.0-OpenSSH_4.2
. 2010-08-02 14:31:35.171 We believe remote version has SSH-2 ignore bug
. 2010-08-02 14:31:35.180 Using SSH protocol version 2
. 2010-08-02 14:31:35.190 We claim version: SSH-2.0-WinSCP_release_4.2.8
. 2010-08-02 14:31:35.205 Handling network write event on socket 896 with error 0
. 2010-08-02 14:31:35.214 Handling network connect event on socket 896 with error 0
. 2010-08-02 14:31:35.228 Waiting for the server to continue with the initialisation
. 2010-08-02 14:31:35.236 Looking for incoming data
. 2010-08-02 14:31:35.246 Looking for network events
. 2010-08-02 14:31:35.253 Detected network event
. 2010-08-02 14:31:35.263 Enumerating network events for socket 896
. 2010-08-02 14:31:35.271 Enumerated 1 network events making 1 cumulative events for socket 896
. 2010-08-02 14:31:35.279 Handling network read event on socket 896 with error 0
. 2010-08-02 14:31:35.286 Doing Diffie-Hellman group exchange
. 2010-08-02 14:31:35.303 Waiting for the server to continue with the initialisation
. 2010-08-02 14:31:35.311 Looking for incoming data
. 2010-08-02 14:31:35.323 Looking for network events
. 2010-08-02 14:31:35.331 Detected network event
. 2010-08-02 14:31:35.341 Enumerating network events for socket 896
. 2010-08-02 14:31:35.363 Enumerated 1 network events making 1 cumulative events for socket 896
. 2010-08-02 14:31:35.375 Handling network read event on socket 896 with error 0
. 2010-08-02 14:31:35.385 Doing Diffie-Hellman key exchange with hash SHA-1
. 2010-08-02 14:31:35.476 Waiting for the server to continue with the initialisation
. 2010-08-02 14:31:35.485 Looking for incoming data
. 2010-08-02 14:31:35.498 Looking for network events
. 2010-08-02 14:31:35.507 Detected network event
. 2010-08-02 14:31:35.516 Enumerating network events for socket 896
. 2010-08-02 14:31:35.524 Enumerated 1 network events making 1 cumulative events for socket 896
. 2010-08-02 14:31:35.536 Handling network read event on socket 896 with error 0
. 2010-08-02 14:31:35.709 Selecting events 63 for socket 896
. 2010-08-02 14:31:35.719 Host key fingerprint is:
. 2010-08-02 14:31:35.728 ssh-rsa 1024 4a:c2:c9:23:28:0c:3b:3b:5b:e8:86:2c:39:09:3e:d2
. 2010-08-02 14:31:35.739 Initialised AES-256 SDCTR client->server encryption
. 2010-08-02 14:31:35.749 Initialised HMAC-SHA1 client->server MAC algorithm
. 2010-08-02 14:31:35.759 Initialised AES-256 SDCTR server->client encryption
. 2010-08-02 14:31:35.767 Initialised HMAC-SHA1 server->client MAC algorithm
. 2010-08-02 14:31:35.782 Waiting for the server to continue with the initialisation
. 2010-08-02 14:31:35.790 Looking for incoming data
. 2010-08-02 14:31:35.800 Looking for network events
. 2010-08-02 14:31:35.808 Detected network event
. 2010-08-02 14:31:35.816 Enumerating network events for socket 896
. 2010-08-02 14:31:35.831 Enumerated 1 network events making 1 cumulative events for socket 896
. 2010-08-02 14:31:35.840 Handling network read event on socket 896 with error 0
! 2010-08-02 14:31:35.846 Using username "username".
. 2010-08-02 14:31:35.936 Waiting for the server to continue with the initialisation
. 2010-08-02 14:31:35.944 Looking for incoming data
. 2010-08-02 14:31:35.952 Looking for network events
. 2010-08-02 14:31:35.959 Detected network event
. 2010-08-02 14:31:35.969 Enumerating network events for socket 896
. 2010-08-02 14:31:35.976 Enumerated 1 network events making 1 cumulative events for socket 896
. 2010-08-02 14:31:35.986 Handling network read event on socket 896 with error 0
prikryl
I've meant the debug log as described in the email I've sent you.
Anyway, I was able to resolve the problem with help of another user.
This bug is being tracked already.
ChadH
I get the same error:
Assertion failed: s->gsslib, file putty\ssh.c, line 7970
This is using AD integrated Kerberos on the server. I have a 'kerberized' version of Putty installed, if that makes any difference. You mentioned that this is resolved, but I don't see any information on what the 'fix' is, and I'm running version 4.2.8 (build 818).
Chad
