Topic "Queue List - How long did successful transfers take?"
jsherk
When a file successfully completes a transfer (background transfer) it is removed/disappears from the queue list.
It would be nice if completed transfers left some kind of information in the queue list so you could see how long it took. The font color could be a lighter color (grey?) instead of black just to distinguish it from current transfers and waiting transfers.
It would also be nice if failed transfers left some kind of information in queue list as well. The font color could be red and italicized to distinguish it from current transfers and waiting transfers.
For example:
OPERATION  SOURCE     DESTINATION  TRANSFERED  TIME/SPEED        PROGRESS
Download   /test.txt  C:\test.txt  5,000 B     0:00:32@157B/s    Completed
Download   /more.txt  C:\more.txt  ---         ---               FAILED
Thanks for your post. This request has been added to tracker.
I believe that failed transfers are not removed unless you acknowledge the error, are they?
jsherk
Yes, you are correct, failed transfers must be acknowledged first, so let me change my suggestion slightly...
I would like an option for failed transfers that does NOT require acknowledgement, but instead simply leaves the information in the queue list. This way, if I am transfering a large number of files unattended, if there is an error, it will continue with the other transfers without waiting for user input. You can then check the queue list to see if file transfers completed or failed.
OK, but that's a huge change. I'll see if more people asks for this.
gilles_Fr
This post is marked as fixed in the tracker.
But when using WinSCP (version 5.7), once a file is transfered, it just disapears from the list of the queue...
Am I missing something?
You have to enable that.
There's a link to documentation in the tracker.
See Display completed transfer in queue for:
http://winscp.net/eng/docs/ui_pref_background
