Topic "winscp428setup.exe not entirely silent"
jarre
2010-07-19 13:02:27.114 Successfully installed the file.
2010-07-19 13:02:27.114 -- Icon entry --
2010-07-19 13:02:27.114 Filename: C:\Documents and Settings\All Users\Start Menu\Programs\WinSCP\WinSCP.lnk
2010-07-19 13:02:27.174 -- Icon entry --
2010-07-19 13:02:27.174 Filename: C:\Documents and Settings\All Users\Start Menu\Programs\WinSCP\WinSCP Web Site.url
2010-07-19 13:02:27.174 Exception message:
2010-07-19 13:02:27.184 Message box (OK):
Access is denied.
If you install the new version (remote,0 session) over an older one the 0-session (wich by design have no GUI) gets a Message box -
an the installation will stop/fail (see log).
Can you either not install these url's if they exist or make the install fail to a default action not give a message box?
(yes it's the same error as in previous installations)
Regards/
JarrE
Why it fails to create the WinSCP Web Site.url file?
jarre
I do not know why.
At the moment I've added
remove_directory
stop_on_failure = n
destination = $(all_users_shell_programs)\WinSCP
descend_dirs = n
remove_empty_dirs = y
rename_if_locked = n
remove = n
remove_file
destination = Documentation.url
end
remove_file
destination = WinSCP.lnk
end
remove_file
destination = "WinSCP Web Site.url"
end
end
before the installation runs (using tivoli for distribution) and the installation then runs OK, but else it usually fails when updating URLs
