Topic "FTP compatibility"
mmatt
Has anyone had an issue using WinSCP with GoDaddy hosting using FTP? WinSCP works with every other provider and FTP/SFTP/SCP servers I've used but hangs at the directory retrieving stage with GoDaddy. I've tried GoDaddy with 2 other FTP clients and it works fine. Any suggestions?
