Topic "WinSCP doesn't switch account for PuTTY"
DaSilva
I have two connections saved in WinSCP and when I connect to the second connection it works as it should in WinSCP but as soon as I want to open PuTTY with the same login data as I have used in WinSCP (Ctrl+P) it opens PuTTY with the login data from the first connection and fails to login.
I cannot find an option to change this behaviour.
How can I fix it?
Thanks!
Just to check that my understanding is correct:
1) You have two stored session in WinSCP, let's say "A" and "B"
2) You start WinSCP
3) Double click the "B" session to open it
4) Then you press Ctrl+P to start PuTTY
5) PuTTY opens the "A" session
Is this correct?
DaSilva
Yes, but the last step is a little bit strange because PuTTY tries to connect to the IP from session B (which is already active in WinSCP) but with the login data from session A.
Do you have stored session "B" in PuTTY?
DaSilva
No sessions are stored in PuTTY
I have sent you a debug version.
DaSilva
Thanks, you got my reply Wink
EDIT: I have deleted the "WinSCP temporary session" in PuTTY because I thought WinSCP would add a new one but it doesn't. Now the PuTTY feature doesn't work anymore from WinSCP because PuTTY always asks me for the connection data.
How can I solve that?
