Topic ""gethostbyname: unknown error""
sick
Happy new year!
everytime i'm tryig to connect this is the message i see. And this is the LogFile:
. WinSCP Version 3.4.2 (Build 197)
. Login time: Samstag, 3. Januar 2004 15:53:47
. Session name: wsl04@informatik.uni-ulm.de
. Host name: informatik.uni-ulm.de (Port: 22)
. User name: wsl04 (Password: Yes, Key file: No)
. Transfer Protocol: SCP
. SSH Bugs: -,-,-,-,-,-,-,-,
. Proxy: none
. Shell: default, EOL: 0
. Looking up host "informatik.uni-ulm.de"
* (ESshFatal) gethostbyname: unknown error
I've tried various versions of WinSCP (even 1.0, which worked really fine for me about 2 years ago).Anyone got an idea?
sick
OK,
maybe i should post some more information: I'm using WinXP with SP1 (without SP1 same problem) and a 56k Modem. I'm using ZoneAlarm Pro as a firewall, but WinSCP doesn't even get so far (or ZA is not telling me). Anyway, disabling it doesn't solve the problem. I don't use any proxy, just Proxomitron as a webfilter. Disabling it also doesnt solve the problem... Don't know what else i can tell you that may help finding a solution.
Please try to connect to your server using Putty SSH client.
sick
Ok,
I've tried it, but I get the same error-message. The hostname-lookup doesn't work at all. When I'm trying to login with the IP-Address it works but unfortunately I haven't got the IPs of all the servers I need...
To lookup IP it should be enough for eaxample to type "ping <hostname>" on DOS command line.
sick
thx,
but it isn't so simple. Same problem as in WinSCP (hast-name lookup fails). Seems to be a system-problem. Maybe an XP-Problem, because with Win2000 and 98 I've used WinSCP without problems. But I have no idea what it could be.
So I cannot help you in such case Sad
