Topic "Synchronize inside script"
mapmusic
Here is part of my WinSCP script.
cd /Clips
lcd d:\clips
synchronize local -delete -speed=10240
I think after this script remote files should be deleted.
But files remains in remote dir.
I need to delete these after successfull transfer.
Thanks for tips
Martin
You probably want to do:
get -delete -speed=10240
mapmusic
I use synchronize because I need to copy only files which are not in local directory.
M.
OK, but you are misusing synchronization then. As synchronization aims to end with synchronized directories, not with one of the directoeries being empty.
Anyway, you can use synchronization and remove the remote directory once synchronization ends.
I have added topic on deleting files after synchronization to FAQ.
