Topic "error code 2"
endo56
I saw a similar topic that was asking about the status/error code 2, but couldn't see an answer.
I'm transferring files using a script, and catching the exit code of the application. The exit code is indicating to me that there was an error, and when I check the logs, the only Status/error code that is not 0, is 2.
. 2010-07-29 18:37:59.866 Copying 1 files/directories to remote directory "/test"
. 2010-07-29 18:37:59.866 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-07-29 18:37:59.866 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-07-29 18:37:59.866 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-07-29 18:37:59.866 File: "D:\logs\MktData\20100729\5162318\filename"
. 2010-07-29 18:37:59.882 Copying "D:\logs\MktData\20100729\5162318\filename" to remote directory started.
. 2010-07-29 18:37:59.882 Binary transfer mode selected.
. 2010-07-29 18:37:59.882 Checking existence of file.
> 2010-07-29 18:37:59.882 Type: SSH_FXP_LSTAT, Size: 65, Number: 220679
< 2010-07-29 18:38:02.522 Type: SSH_FXP_STATUS, Size: 29, Number: 220679
< 2010-07-29 18:38:02.522 Status/error code: 2
. 2010-07-29 18:38:02.522 Checking existence of partially transfered file.
> 2010-07-29 18:38:02.522 Type: SSH_FXP_LSTAT, Size: 74, Number: 220935
< 2010-07-29 18:38:02.725 Type: SSH_FXP_STATUS, Size: 29, Number: 220935
< 2010-07-29 18:38:02.725 Status/error code: 2
. 2010-07-29 18:38:02.725 Opening remote file.
> 2010-07-29 18:38:02.725 Type: SSH_FXP_OPEN, Size: 90, Number: 221187
< 2010-07-29 18:38:04.960 Type: SSH_FXP_HANDLE, Size: 13, Number: 221187
> 2010-07-29 18:38:04.960 Type: SSH_FXP_WRITE, Size: 4121, Number: 221702
. 2010-07-29 18:38:04.975 29 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-07-29 18:38:04.975 Type: SSH_FXP_CLOSE, Size: 13, Number: 225796
< 2010-07-29 18:38:04.991 Type: SSH_FXP_STATUS, Size: 24, Number: 225286
< 2010-07-29 18:38:04.991 Type: SSH_FXP_STATUS, Size: 24, Number: 225542
< 2010-07-29 18:38:05.147 Type: SSH_FXP_STATUS, Size: 24, Number: 225796
< 2010-07-29 18:38:05.210 Status/error code: 0
> 2010-07-29 18:38:05.210 Type: SSH_FXP_RENAME, Size: 134, Number: 226066
< 2010-07-29 18:38:11.116 Type: SSH_FXP_STATUS, Size: 24, Number: 226066
< 2010-07-29 18:38:11.116 Status/error code: 0
> 2010-07-29 18:38:11.116 Type: SSH_FXP_SETSTAT, Size: 77, Number: 221449
< 2010-07-29 18:38:11.897 Type: SSH_FXP_STATUS, Size: 24, Number: 221449
< 2010-07-29 18:38:11.897 Status/error code: 0
There are lots of these errors in a similar context.
What does the error mean?
Has the file transferred successfully in the end?
Is it possible to get a successful exit code even if this error occurs if it means the file was transferred successfully?
Thanks.
The status code here is irrelevant. Log file from the latest version (4.2.Cool might provide mode useful information.
endo56
Thanks for your reply. I'll have to see if I can upgrade.
Could the non-zero exit code be generated by anything else in the log? I'm unclear why it's exiting the application with an error.
Thanks.
No there's nothing relevant in the log.
endo56
Ok, thanks for the information, will try 4.2.
endo56
Hi Martin,
I'm trying 4.2.8 and previously I'd have a non-zero exit code about 1-20% of the time now the exit code is always non-zero.
Could the below lines be the reason?
Thanks.
< 2010-08-11 09:06:04.386 WinSCP: this is end-of-file:0
. 2010-08-11 09:06:04.386 Return code variable "$?" selected.
. 2010-08-11 09:06:04.386 Clearing all aliases.
> 2010-08-11 09:06:04.386 unalias "ls" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:06:04.495 bash: line 4: unalias: ls: not found
< 2010-08-11 09:06:04.745 WinSCP: this is end-of-file:1
> 2010-08-11 09:06:04.745 unalias "echo" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:06:04.839 bash: line 5: unalias: echo: not found
< 2010-08-11 09:06:04.980 WinSCP: this is end-of-file:1
> 2010-08-11 09:06:04.980 unalias "pwd" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:06:05.073 bash: line 6: unalias: pwd: not found
< 2010-08-11 09:06:05.183 WinSCP: this is end-of-file:1
> 2010-08-11 09:06:05.183 unalias "cd" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:06:05.276 bash: line 7: unalias: cd: not found
< 2010-08-11 09:06:05.401 WinSCP: this is end-of-file:1
> 2010-08-11 09:06:05.401 unalias "groups" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:06:05.495 bash: line 8: unalias: groups: not found
< 2010-08-11 09:06:05.620 WinSCP: this is end-of-file:1
> 2010-08-11 09:06:05.620 unalias "scp" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:06:05.714 bash: line 9: unalias: scp: not found
< 2010-08-11 09:06:05.839 WinSCP: this is end-of-file:1
> 2010-08-11 09:06:05.839 unalias "rm" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:06:05.933 bash: line 10: unalias: rm: not found
< 2010-08-11 09:06:06.183 WinSCP: this is end-of-file:1
> 2010-08-11 09:06:06.183 unalias "mv" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:06:06.276 bash: line 11: unalias: mv: not found
< 2010-08-11 09:06:06.495 WinSCP: this is end-of-file:1
> 2010-08-11 09:06:06.495 unalias "mkdir" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:06:06.589 bash: line 12: unalias: mkdir: not found
< 2010-08-11 09:06:06.714 WinSCP: this is end-of-file:1
> 2010-08-11 09:06:06.714 unalias "chmod" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:06:06.808 bash: line 13: unalias: chmod: not found
< 2010-08-11 09:06:06.933 WinSCP: this is end-of-file:1
> 2010-08-11 09:06:06.933 unalias "chgrp" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:06:07.042 bash: line 14: unalias: chgrp: not found
< 2010-08-11 09:06:07.261 WinSCP: this is end-of-file:1
> 2010-08-11 09:06:07.261 unalias "chown" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:06:07.354 bash: line 15: unalias: chown: not found
< 2010-08-11 09:06:07.604 WinSCP: this is end-of-file:1
> 2010-08-11 09:06:07.604 unalias "unset" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:06:07.698 bash: line 16: unalias: unset: not found
< 2010-08-11 09:06:07.917 WinSCP: this is end-of-file:1
> 2010-08-11 09:06:07.917 unalias "unalias" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:06:08.011 bash: line 17: unalias: unalias: not found
< 2010-08-11 09:06:08.151 WinSCP: this is end-of-file:1
> 2010-08-11 09:06:08.151 unalias "ln" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:06:08.245 bash: line 18: unalias: ln: not found
< 2010-08-11 09:06:08.479 WinSCP: this is end-of-file:1
> 2010-08-11 09:06:08.479 unalias "cp" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:06:08.573 bash: line 19: unalias: cp: not found
No. Post a full log file.
endo56
Here it is. I've x'ed out the server/key/ip address/users.
. 2010-08-11 09:04:35.808 --------------------------------------------------------------------------
. 2010-08-11 09:04:35.808 WinSCP Version 4.2.8 (Build 818) (OS 5.2.3790 Service Pack 2)
. 2010-08-11 09:04:35.808 Login time: 11 August 2010 09:04:35
. 2010-08-11 09:04:35.808 Session name: xxxxxxxxxxx
. 2010-08-11 09:04:35.808 Host name: xxxxxxxxxxxxxx (Port: 22)
. 2010-08-11 09:04:35.808 User name: xxxxxxxx (Password: Yes, Key file: No)
. 2010-08-11 09:04:35.808 Tunnel: No
. 2010-08-11 09:04:35.808 Transfer Protocol: SCP
. 2010-08-11 09:04:35.808 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2010-08-11 09:04:35.808 Proxy: none
. 2010-08-11 09:04:35.808 SSH protocol version: 2; Compression: No
. 2010-08-11 09:04:35.808 Bypass authentication: No
. 2010-08-11 09:04:35.808 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2010-08-11 09:04:35.808 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2010-08-11 09:04:35.808 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2010-08-11 09:04:35.808 SFTP Bugs: -,-
. 2010-08-11 09:04:35.808 Return code variable: Autodetect; Lookup user groups: Yes
. 2010-08-11 09:04:35.808 Shell: default
. 2010-08-11 09:04:35.808 EOL: 0, UTF: 2
. 2010-08-11 09:04:35.808 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2010-08-11 09:04:35.808 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2010-08-11 09:04:35.808 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-08-11 09:04:35.808 Cache directory changes: Yes, Permanent: Yes
. 2010-08-11 09:04:35.808 DST mode: 1
. 2010-08-11 09:04:35.808 Looking up host "xxxxxxxxxxxxxxxxx"
. 2010-08-11 09:04:35.808 Connecting to 10.1.1.4 port 22
. 2010-08-11 09:04:35.823 Server version: SSH-2.0-Sun_SSH_1.1.1
. 2010-08-11 09:04:35.823 We believe remote version has SSH-2 ignore bug
. 2010-08-11 09:04:35.823 Using SSH protocol version 2
. 2010-08-11 09:04:35.823 We claim version: SSH-2.0-WinSCP_release_4.2.8
. 2010-08-11 09:04:35.855 Doing Diffie-Hellman group exchange
. 2010-08-11 09:04:35.855 Doing Diffie-Hellman key exchange with hash SHA-1
. 2010-08-11 09:04:35.902 Host key fingerprint is:
. 2010-08-11 09:04:35.902 ssh-rsa 1024 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
. 2010-08-11 09:04:35.902 Initialised AES-128 SDCTR client->server encryption
. 2010-08-11 09:04:35.902 Initialised HMAC-SHA1 client->server MAC algorithm
. 2010-08-11 09:04:35.902 Initialised AES-128 SDCTR server->client encryption
. 2010-08-11 09:04:35.902 Initialised HMAC-SHA1 server->client MAC algorithm
! 2010-08-11 09:04:35.948 Using username "xxxxxxxxxxxx".
. 2010-08-11 09:04:35.980 Prompt (5, SSH server authentication, Using keyboard-interactive authentication., Password: )
. 2010-08-11 09:04:35.980 Using stored password.
. 2010-08-11 09:04:36.058 Access granted
. 2010-08-11 09:04:36.089 Opened channel for session
. 2010-08-11 09:04:36.152 Started a shell/command
. 2010-08-11 09:04:36.152 --------------------------------------------------------------------------
. 2010-08-11 09:04:36.152 Using SCP protocol.
. 2010-08-11 09:04:36.152 Doing startup conversation with host.
. 2010-08-11 09:04:36.152 Skipping host startup message (if any).
> 2010-08-11 09:04:36.152 echo "WinSCP: this is end-of-file:0"
< 2010-08-11 09:04:36.245 Access to this computer is prohibited unless authorised
< 2010-08-11 09:04:36.245 Accessing programs or data unrelated to your job is prohibited
< 2010-08-11 09:04:36.245 If you are not authorised, disconnect now.
< 2010-08-11 09:04:36.245 This server is supported by IES UNIX Support Group:
< 2010-08-11 09:04:36.245 For IES ES support group contact details please refer to:
< 2010-08-11 09:04:36.245 For server information details please search for server 'hostname' in the GTO
< 2010-08-11 09:04:36.245 Asset Centre system:
< 2010-08-11 09:04:36.245 Where the Asset Centre 'HCL Access' field value equals 'Yes - In Scope', the
< 2010-08-11 09:04:36.245 server is then subject to 24 x 7 first level direct support by HCL Comnet,
< 2010-08-11 09:04:36.245 who's contact details are available at:
< 2010-08-11 09:04:36.245 You have new mail.
< 2010-08-11 09:04:36.480 Hello hoandre
< 2010-08-11 09:04:36.480 WinSCP: this is end-of-file:0
. 2010-08-11 09:04:36.480 Detecting variable containing return code of last command.
. 2010-08-11 09:04:36.480 Trying "$status".
> 2010-08-11 09:04:36.480 echo "$status" ; echo "WinSCP: this is end-of-file:0"
< 2010-08-11 09:04:36.808 WinSCP: this is end-of-file:0
. 2010-08-11 09:04:36.808 The response is not numerical exit code
. 2010-08-11 09:04:36.808 Trying "$?".
> 2010-08-11 09:04:36.808 echo "$?" ; echo "WinSCP: this is end-of-file:0"
< 2010-08-11 09:04:36.902 0
< 2010-08-11 09:04:37.136 WinSCP: this is end-of-file:0
. 2010-08-11 09:04:37.136 Return code variable "$?" selected.
. 2010-08-11 09:04:37.136 Clearing all aliases.
> 2010-08-11 09:04:37.136 unalias "ls" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:04:37.230 bash: line 4: unalias: ls: not found
< 2010-08-11 09:04:37.448 WinSCP: this is end-of-file:1
> 2010-08-11 09:04:37.448 unalias "echo" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:04:37.542 bash: line 5: unalias: echo: not found
< 2010-08-11 09:04:37.667 WinSCP: this is end-of-file:1
> 2010-08-11 09:04:37.667 unalias "pwd" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:04:37.761 bash: line 6: unalias: pwd: not found
< 2010-08-11 09:04:37.777 WinSCP: this is end-of-file:1
> 2010-08-11 09:04:37.777 unalias "cd" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:04:37.870 bash: line 7: unalias: cd: not found
< 2010-08-11 09:04:37.995 WinSCP: this is end-of-file:1
> 2010-08-11 09:04:37.995 unalias "groups" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:04:38.089 bash: line 8: unalias: groups: not found
< 2010-08-11 09:04:38.214 WinSCP: this is end-of-file:1
> 2010-08-11 09:04:38.214 unalias "scp" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:04:38.308 bash: line 9: unalias: scp: not found
< 2010-08-11 09:04:38.433 WinSCP: this is end-of-file:1
> 2010-08-11 09:04:38.433 unalias "rm" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:04:38.526 bash: line 10: unalias: rm: not found
< 2010-08-11 09:04:38.761 WinSCP: this is end-of-file:1
> 2010-08-11 09:04:38.761 unalias "mv" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:04:38.855 bash: line 11: unalias: mv: not found
< 2010-08-11 09:04:38.870 WinSCP: this is end-of-file:1
> 2010-08-11 09:04:38.870 unalias "mkdir" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:04:38.948 bash: line 12: unalias: mkdir: not found
< 2010-08-11 09:04:39.105 WinSCP: this is end-of-file:1
> 2010-08-11 09:04:39.105 unalias "chmod" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:04:39.198 bash: line 13: unalias: chmod: not found
< 2010-08-11 09:04:39.526 WinSCP: this is end-of-file:1
> 2010-08-11 09:04:39.526 unalias "chgrp" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:04:39.620 bash: line 14: unalias: chgrp: not found
< 2010-08-11 09:04:39.855 WinSCP: this is end-of-file:1
> 2010-08-11 09:04:39.855 unalias "chown" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:04:39.948 bash: line 15: unalias: chown: not found
< 2010-08-11 09:04:40.183 WinSCP: this is end-of-file:1
> 2010-08-11 09:04:40.183 unalias "unset" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:04:40.276 bash: line 16: unalias: unset: not found
< 2010-08-11 09:04:40.417 WinSCP: this is end-of-file:1
> 2010-08-11 09:04:40.448 unalias "unalias" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:04:40.542 bash: line 17: unalias: unalias: not found
< 2010-08-11 09:04:40.745 WinSCP: this is end-of-file:1
> 2010-08-11 09:04:40.745 unalias "ln" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:04:40.839 bash: line 18: unalias: ln: not found
< 2010-08-11 09:04:41.073 WinSCP: this is end-of-file:1
> 2010-08-11 09:04:41.073 unalias "cp" ; echo "WinSCP: this is end-of-file:$?"
! 2010-08-11 09:04:41.167 bash: line 19: unalias: cp: not found
< 2010-08-11 09:04:41.276 WinSCP: this is end-of-file:1
. 2010-08-11 09:04:41.276 Clearing national user variables.
> 2010-08-11 09:04:41.276 unset "LANG" ; echo "WinSCP: this is end-of-file:$?"
< 2010-08-11 09:04:41.386 WinSCP: this is end-of-file:0
> 2010-08-11 09:04:41.386 unset "LANGUAGE" ; echo "WinSCP: this is end-of-file:$?"
< 2010-08-11 09:04:41.479 WinSCP: this is end-of-file:0
> 2010-08-11 09:04:41.479 unset "LC_CTYPE" ; echo "WinSCP: this is end-of-file:$?"
< 2010-08-11 09:04:41.573 WinSCP: this is end-of-file:0
> 2010-08-11 09:04:41.573 unset "LC_COLLATE" ; echo "WinSCP: this is end-of-file:$?"
< 2010-08-11 09:04:41.667 WinSCP: this is end-of-file:0
> 2010-08-11 09:04:41.667 unset "LC_MONETARY" ; echo "WinSCP: this is end-of-file:$?"
< 2010-08-11 09:04:41.776 WinSCP: this is end-of-file:0
> 2010-08-11 09:04:41.776 unset "LC_NUMERIC" ; echo "WinSCP: this is end-of-file:$?"
< 2010-08-11 09:04:41.870 WinSCP: this is end-of-file:0
> 2010-08-11 09:04:41.870 unset "LC_TIME" ; echo "WinSCP: this is end-of-file:$?"
< 2010-08-11 09:04:41.979 WinSCP: this is end-of-file:0
> 2010-08-11 09:04:41.979 unset "LC_MESSAGES" ; echo "WinSCP: this is end-of-file:$?"
< 2010-08-11 09:04:42.073 WinSCP: this is end-of-file:0
> 2010-08-11 09:04:42.073 unset "LC_ALL" ; echo "WinSCP: this is end-of-file:$?"
< 2010-08-11 09:04:42.167 WinSCP: this is end-of-file:0
> 2010-08-11 09:04:42.167 unset "HUMAN_BLOCKS" ; echo "WinSCP: this is end-of-file:$?"
< 2010-08-11 09:04:42.276 WinSCP: this is end-of-file:0
. 2010-08-11 09:04:42.276 Looking up groups and users.
> 2010-08-11 09:04:42.276 groups ; echo "WinSCP: this is end-of-file:$?"
< 2010-08-11 09:04:42.401 gswpoper ratejira gswptrad grmuatlx
< 2010-08-11 09:04:42.589 WinSCP: this is end-of-file:0
. 2010-08-11 09:04:42.589 Following groups found:
. 2010-08-11 09:04:42.589 "xxxxxx" [0]
. 2010-08-11 09:04:42.589 Following membership found:
. 2010-08-11 09:04:42.589 Following users found:
. 2010-08-11 09:04:42.589 Getting current directory name.
> 2010-08-11 09:04:42.589 pwd ; echo "WinSCP: this is end-of-file:$?"
< 2010-08-11 09:04:42.698 /home/grimis
< 2010-08-11 09:04:42.698 WinSCP: this is end-of-file:0
. 2010-08-11 09:04:42.698 Startup conversation with host finished.
< 2010-08-11 09:04:42.698 Script: Active session: [1] xxxxxxxxx@xxxxxxxxxxxxxxxxx
> 2010-08-11 09:04:42.698 Script: cd /applogs/sdos/intraday/mktdata/
. 2010-08-11 09:04:42.698 Cached directory change via "/applogs/sdos/intraday/mktdata/" to "/applogs/sdos/intraday/mktdata".
. 2010-08-11 09:04:42.698 Getting current directory name.
< 2010-08-11 09:04:42.698 Script: /applogs/sdos/intraday/mktdata
> 2010-08-11 09:04:42.698 Script: put "D:\logs\RiskEngine\MktData\20100811\2470873\A3473~TGOTC~GOS\TwoSidedDelta"
. 2010-08-11 09:04:42.698 Copying 1 files/directories to remote directory "/applogs/sdos/intraday/mktdata"
. 2010-08-11 09:04:42.698 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-08-11 09:04:42.698 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-08-11 09:04:42.698 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-08-11 09:04:42.698 Locating to cached directory "/applogs/sdos/intraday/mktdata".
> 2010-08-11 09:04:42.698 cd "/applogs/sdos/intraday/mktdata" ; echo "WinSCP: this is end-of-file:$?"
< 2010-08-11 09:04:42.792 WinSCP: this is end-of-file:0
> 2010-08-11 09:04:42.823 echo "WinSCP: this is begin-of-file" ; scp -r -d -t "/applogs/sdos/intraday/mktdata" ; echo "WinSCP: this is end-of-file:$?"
< 2010-08-11 09:04:42.901 WinSCP: this is begin-of-file
. 2010-08-11 09:04:43.026 SCP remote side confirmation (0)
. 2010-08-11 09:04:43.026 File: "D:\logs\RiskEngine\MktData\20100811\2470873\A3473~TGOTC~GOS\TwoSidedDelta"
. 2010-08-11 09:04:43.026 Copying "D:\logs\RiskEngine\MktData\20100811\2470873\A3473~TGOTC~GOS\TwoSidedDelta" to remote directory started.
. 2010-08-11 09:04:43.026 Binary transfer mode selected.
> 2010-08-11 09:04:43.026 T1281510248 0 1281510248 0
. 2010-08-11 09:04:43.120 SCP remote side confirmation (0)
> 2010-08-11 09:04:43.120 C0644 650 TwoSidedDelta
. 2010-08-11 09:04:43.229 SCP remote side confirmation (0)
. 2010-08-11 09:04:43.229 Sending BINARY data (first block, 650 bytes)
. 2010-08-11 09:04:43.229 Sending NULL.
. 2010-08-11 09:04:43.339 SCP remote side confirmation (0)
. 2010-08-11 09:04:43.339 Copying "D:\logs\RiskEngine\MktData\20100811\2470873\A3473~TGOTC~GOS\TwoSidedDelta" to remote directory finished.
> 2010-08-11 09:04:43.339 E
. 2010-08-11 09:04:43.417 SCP remote side confirmation (0)
< 2010-08-11 09:04:43.589 WinSCP: this is end-of-file:0
> 2010-08-11 09:04:43.589 Script: put "D:\logs\RiskEngine\MktData\20100811\2470873\A3473~TGOTC~GOS\DividendDelta"
. 2010-08-11 09:04:43.589 Copying 1 files/directories to remote directory "/applogs/sdos/intraday/mktdata"
. 2010-08-11 09:04:43.589 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-08-11 09:04:43.589 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-08-11 09:04:43.589 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
> 2010-08-11 09:04:43.589 echo "WinSCP: this is begin-of-file" ; scp -r -d -t "/applogs/sdos/intraday/mktdata" ; echo "WinSCP: this is end-of-file:$?"
< 2010-08-11 09:04:43.682 WinSCP: this is begin-of-file
. 2010-08-11 09:04:43.917 SCP remote side confirmation (0)
. 2010-08-11 09:04:43.917 File: "D:\logs\RiskEngine\MktData\20100811\2470873\A3473~TGOTC~GOS\DividendDelta"
. 2010-08-11 09:04:43.917 Copying "D:\logs\RiskEngine\MktData\20100811\2470873\A3473~TGOTC~GOS\DividendDelta" to remote directory started.
. 2010-08-11 09:04:43.917 Binary transfer mode selected.
> 2010-08-11 09:04:43.917 T1281510248 0 1281510248 0
. 2010-08-11 09:04:44.011 SCP remote side confirmation (0)
> 2010-08-11 09:04:44.011 C0644 417 DividendDelta
. 2010-08-11 09:04:44.120 SCP remote side confirmation (0)
. 2010-08-11 09:04:44.120 Sending BINARY data (first block, 417 bytes)
. 2010-08-11 09:04:44.120 Sending NULL.
. 2010-08-11 09:04:44.229 SCP remote side confirmation (0)
. 2010-08-11 09:04:44.229 Copying "D:\logs\RiskEngine\MktData\20100811\2470873\A3473~TGOTC~GOS\DividendDelta" to remote directory finished.
> 2010-08-11 09:04:44.229 E
. 2010-08-11 09:04:44.339 SCP remote side confirmation (0)
< 2010-08-11 09:04:44.573 WinSCP: this is end-of-file:0
> 2010-08-11 09:04:44.573 Script: close
. 2010-08-11 09:04:44.573 Closing connection.
. 2010-08-11 09:04:44.573 Sending special code: 12
. 2010-08-11 09:04:44.573 Sent EOF message
There's nothing justifying the non-zero exit code. Can you show how do you run WinSCP and how do you check for its exit code?
endo56
Hi Martin, thanks for looking.
Everything is done in VBA.
I create a script with a set of files to send.
e.g.
option batch on
open user@host -Hostkey="ssh-rsa 1024 xx:xx:xx:xx:xx"
cd /xxxxx/xxxxx/xxxxxxxxx/xxxx/
put "D:\logs\xxxxxx\MktData\20100813\5258851\filename"
close
This is the module that executes the process:
Private Type STARTUPINFO
cb As Long
lpReserved As String
lpDesktop As String
lpTitle As String
dwX As Long
dwY As Long
dwXSize As Long
dwYSize As Long
dwXCountChars As Long
dwYCountChars As Long
dwFillAttribute As Long
dwFlags As Long
wShowWindow As Integer
cbReserved2 As Integer
lpReserved2 As Long
hStdInput As Long
hStdOutput As Long
hStdError As Long
End Type
Private Type PROCESS_INFORMATION
hProcess As Long
hThread As Long
dwProcessID As Long
dwThreadID As Long
End Type
Private Declare Function WaitForSingleObject Lib "kernel32" (ByVal _
hHandle As Long, ByVal dwMilliseconds As Long) As Long
Private Declare Function CreateProcessA Lib "kernel32" (ByVal _
lpApplicationName As String, ByVal lpCommandLine As String, ByVal _
lpProcessAttributes As Long, ByVal lpThreadAttributes As Long, _
ByVal bInheritHandles As Long, ByVal dwCreationFlags As Long, _
ByVal lpEnvironment As Long, ByVal lpCurrentDirectory As String, _
lpStartupInfo As STARTUPINFO, lpProcessInformation As _
PROCESS_INFORMATION) As Long
Private Declare Function CloseHandle Lib "kernel32" _
(ByVal hObject As Long) As Long
Private Declare Function GetExitCodeProcess Lib "kernel32" _
(ByVal hProcess As Long, lpExitCode As Long) As Long
Private Const NORMAL_PRIORITY_CLASS = &H20&
Private Const INFINITE = -1&
Public Function ExecCmd(cmdline$)
Dim proc As PROCESS_INFORMATION
Dim start As STARTUPINFO
' Initialize the STARTUPINFO structure:
start.cb = Len(start)
' Start the shelled application:
ret& = CreateProcessA(vbNullString, cmdline$, 0&, 0&, 1&, _
NORMAL_PRIORITY_CLASS, 0&, vbNullString, start, proc)
' Wait for the shelled application to finish:
ret& = WaitForSingleObject(proc.hProcess, INFINITE)
Call GetExitCodeProcess(proc.hProcess, ret&)
Call CloseHandle(proc.hThread)
Call CloseHandle(proc.hProcess)
ExecCmd = ret&
End Function
This is how the process is called:
retVal = ExecCmd("winscp419.com" & " /script=""" & outputFile & """ /ini=" & Range("UploadIni") & " /log=""" & logFile & """")
I then check that retVal = 0 to declare it a "successful" transfer.
This works quite well with 4.19. Except for cases where I get !0 exit code without understanding why (my first post). With 4.28 I get 100% !0 exit code.
Thanks for your help.
Well, there's a known bug with "close" command in 4.2.8 that may cause your problem. Strange is that I do not see any evidence for that in the log file. Anyway, can you try 4.2.7?
endo56
Hi Martin,
4.2.7 is working better, I'm not seeing the 100% !0 I had with 4.2.8.
The three !0 errors I've had so far are also explained in the logs. This particular error I had never seen in 4.1.9:
< 2010-08-16 09:36:32.236 Status code: 4, Message: 26898, Server: Failure, Language:
* 2010-08-16 09:36:32.236 (ETerminal) General failure (server should provide error description).
* 2010-08-16 09:36:32.236 Error code: 4
* 2010-08-16 09:36:32.236 Error message from server: Failure
* 2010-08-16 09:36:32.236 Request code: 18
. 2010-08-16 09:36:32.236 Asking user:
. 2010-08-16 09:36:32.236 Transfer was succesfully finished, but temporary transfer file 'xxxxx.filepart' could not be renamed to target file name 'xxxxx'. If the problem persists, you may try to turn off transfer resume support. ("General failure (server should provide error description).
. 2010-08-16 09:36:32.236 Error code: 4
. 2010-08-16 09:36:32.236 Error message from server: Failure
. 2010-08-16 09:36:32.236 Request code: 18")
* 2010-08-16 09:36:32.251 (EScpSkipFile) Transfer was succesfully finished, but temporary transfer file 'xxxxx.filepart' could not be renamed to target file name 'xxxxx'. If the problem persists, you may try to turn off transfer resume support.
* 2010-08-16 09:36:32.251 General failure (server should provide error description).
* 2010-08-16 09:36:32.251 Error code: 4
* 2010-08-16 09:36:32.251 Error message from server: Failure
* 2010-08-16 09:36:32.251 Request code: 18
I don't particularly need resume functionality as this is a fully automated process and any !0 exit code is considered a failure and the job is retried automatically.
If a transfer was halted and WinSCP successfully recovered and resumed the transfer would that still result in a !0 exit code?
If yes, how can I turn off the resume functionality?
Thanks.
What does it mean "halted"? If connection is lost, WinSCP reconnects and restarts transfer (resumes if possible and allowed). If it finishes successfully at the end, exit code is 0.
endo56
Thanks, will have a look.
endo56
The following returns me a non-zero exit code with 4.1.9, even though it successfully transfers all the files.
Do you know if it's fixed in 4.2.7? (it's difficult to replicate)
Thanks.
> 2010-11-24 12:17:06.930 Type: SSH_FXP_OPEN, Size: 89, Number: 19203
. 2010-11-24 12:17:21.930 Waiting for data timed out, asking user what to do.
. 2010-11-24 12:17:21.930 Asking user:
. 2010-11-24 12:17:21.930 Host has not answered for 15 seconds.
. 2010-11-24 12:17:21.930 Wait for another 15 seconds? ()
. 2010-11-24 12:17:21.930 Attempt to close connection due to fatal exception:
* 2010-11-24 12:17:21.930 Terminated by user.
. 2010-11-24 12:17:21.930 Closing connection.
. 2010-11-24 12:17:21.930 Sending special code: 12
. 2010-11-24 12:17:21.930 Sent EOF message
. 2010-11-24 12:17:21.930 Connection was lost, asking what to do.
. 2010-11-24 12:17:21.930 Terminated by user. ()
. 2010-11-24 12:17:28.196 Looking up host "xxxxxxxxxxxxxxx"
. 2010-11-24 12:17:28.196 Connecting to xxxxxxxxxx port 22
. 2010-11-24 12:17:28.196 Server unexpectedly closed network connection
. 2010-11-24 12:17:28.196 Connection was lost, asking what to do.
. 2010-11-24 12:17:28.196 Asking user:
. 2010-11-24 12:17:28.196 Server unexpectedly closed network connection. ()
. 2010-11-24 12:17:34.446 Looking up host "xxxxxxxxxxxxxxxxxxxxx"
. 2010-11-24 12:17:34.446 Connecting to xxxxxxxxxxxx port 22
. 2010-11-24 12:17:34.446 Server version: SSH-2.0-Sun_SSH_1.1.1
. 2010-11-24 12:17:34.446 We claim version: SSH-2.0-WinSCP_release_4.1.9
. 2010-11-24 12:17:34.446 SSPI: acquired credentials for: xxxxxxx@xxxxxxxxxx
. 2010-11-24 12:17:34.446 Constructed service principal name 'host/xxxxxxxxxxxxxxxxxxxx'
. 2010-11-24 12:17:34.446 GSSKEX disabled: The specified target is unknown or unreachable
I do not think there is anything in the log snippet that causes the non zero exit code. Please post a full log file from 4.2.9 showing the problem.
endo56
Here's a log with 4.2.7 that gave me a non-zero exit code, I'll try and get something similar with 4.2.9.
4.2.8 was giving me non-zero exit codes with every run.
Thanks.
. 2010-12-07 19:24:28.438 --------------------------------------------------------------------------
. 2010-12-07 19:24:28.438 WinSCP Version 4.2.7 (Build 758) (OS 5.2.3790 Service Pack 2)
. 2010-12-07 19:24:28.438 Login time: 07 December 2010 19:24:28
. 2010-12-07 19:24:28.438 Session name: xxxxxxxxxxxxxxxxxxxxxxxxxxx
. 2010-12-07 19:24:28.438 Host name: xxxxxxxxxxxxxxxxxx (Port: 22)
. 2010-12-07 19:24:28.438 User name: xxxxxxxxxxx (Password: No, Key file: Yes)
. 2010-12-07 19:24:28.438 Tunnel: No
. 2010-12-07 19:24:28.438 Transfer Protocol: SFTP
. 2010-12-07 19:24:28.438 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2010-12-07 19:24:28.438 Proxy: none
. 2010-12-07 19:24:28.438 SSH protocol version: 2; Compression: No
. 2010-12-07 19:24:28.438 Bypass authentication: No
. 2010-12-07 19:24:28.438 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2010-12-07 19:24:28.438 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2010-12-07 19:24:28.438 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2010-12-07 19:24:28.438 SFTP Bugs: -,-
. 2010-12-07 19:24:28.438 Return code variable: Autodetect; Lookup user groups: Yes
. 2010-12-07 19:24:28.438 Shell: rssh, EOL: 0
. 2010-12-07 19:24:28.438 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2010-12-07 19:24:28.438 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2010-12-07 19:24:28.438 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-12-07 19:24:28.438 Cache directory changes: Yes, Permanent: Yes
. 2010-12-07 19:24:28.438 DST mode: 1
. 2010-12-07 19:24:28.438 Looking up host "xxxxxxxxxxxxxxx"
. 2010-12-07 19:24:28.438 Connecting to xxxxxxxxxxxxxxx port 22
. 2010-12-07 19:24:28.454 Server version: SSH-2.0-Sun_SSH_1.1.1
. 2010-12-07 19:24:28.454 Using SSH protocol version 2
. 2010-12-07 19:24:28.454 We claim version: SSH-2.0-WinSCP_release_4.2.7
. 2010-12-07 19:24:28.470 Doing Diffie-Hellman group exchange
. 2010-12-07 19:24:28.485 Doing Diffie-Hellman key exchange with hash SHA-1
. 2010-12-07 19:24:28.517 Host key fingerprint is:
. 2010-12-07 19:24:28.517 ssh-rsa 1024 xxxxxxxxxxxxxxx
. 2010-12-07 19:24:28.517 Initialised AES-128 SDCTR client->server encryption
. 2010-12-07 19:24:28.517 Initialised HMAC-SHA1 client->server MAC algorithm
. 2010-12-07 19:24:28.517 Initialised AES-128 SDCTR server->client encryption
. 2010-12-07 19:24:28.517 Initialised HMAC-SHA1 server->client MAC algorithm
. 2010-12-07 19:24:28.532 Reading private key file "xxxxxxxxxxxxxxx"
! 2010-12-07 19:24:28.532 Using username "xxxxxxxxxxxxxxxxxx".
. 2010-12-07 19:24:28.532 Offered public key
. 2010-12-07 19:24:28.610 Offer of public key accepted
! 2010-12-07 19:24:28.610 Authenticating with public key "dsa-key-20091021"
. 2010-12-07 19:24:28.673 Access granted
. 2010-12-07 19:24:28.704 Opened channel for session
. 2010-12-07 19:24:28.751 Started a shell/command
. 2010-12-07 19:24:28.751 --------------------------------------------------------------------------
. 2010-12-07 19:24:28.751 Using SFTP protocol.
. 2010-12-07 19:24:28.751 Doing startup conversation with host.
> 2010-12-07 19:24:28.751 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2010-12-07 19:24:28.767 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2010-12-07 19:24:28.767 SFTP version 3 negotiated.
. 2010-12-07 19:24:28.767 We believe the server has signed timestamps bug
. 2010-12-07 19:24:28.767 We will use UTF-8 strings for status messages only
. 2010-12-07 19:24:28.767 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2010-12-07 19:24:28.767 Getting current directory name.
. 2010-12-07 19:24:28.767 Getting real path for '.'
> 2010-12-07 19:24:28.767 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2010-12-07 19:24:28.767 Type: SSH_FXP_NAME, Size: 45, Number: 16
. 2010-12-07 19:24:28.767 Real path is '/home/xxxxxxxxxxxxxxxxxx'
. 2010-12-07 19:24:28.767 Startup conversation with host finished.
. 2010-12-07 19:24:28.767 Cached directory change via "xxxxxxxxxxxxxxx/" to "xxxxxxxxxxxxxxx".
. 2010-12-07 19:24:28.767 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:24:28.767 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:24:28.767 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:24:28.767 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:24:28.767 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:24:28.767 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:24:28.767 Binary transfer mode selected.
. 2010-12-07 19:24:28.767 Checking existence of file.
> 2010-12-07 19:24:28.767 Type: SSH_FXP_LSTAT, Size: 76, Number: 263
< 2010-12-07 19:24:30.735 Type: SSH_FXP_ATTRS, Size: 37, Number: 263
. 2010-12-07 19:24:30.735 Checking existence of partially transfered file.
> 2010-12-07 19:24:30.735 Type: SSH_FXP_LSTAT, Size: 85, Number: 519
< 2010-12-07 19:24:31.564 Type: SSH_FXP_STATUS, Size: 29, Number: 519
< 2010-12-07 19:24:31.564 Status code: 2
. 2010-12-07 19:24:31.564 Opening remote file.
> 2010-12-07 19:24:31.564 Type: SSH_FXP_OPEN, Size: 101, Number: 771
< 2010-12-07 19:24:32.657 Type: SSH_FXP_HANDLE, Size: 13, Number: 771
> 2010-12-07 19:24:32.657 Type: SSH_FXP_WRITE, Size: 4121, Number: 1286
. 2010-12-07 19:24:32.689 53 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-12-07 19:24:32.689 Type: SSH_FXP_CLOSE, Size: 13, Number: 8452
< 2010-12-07 19:24:32.689 Type: SSH_FXP_STATUS, Size: 24, Number: 7942
< 2010-12-07 19:24:32.689 Type: SSH_FXP_STATUS, Size: 24, Number: 8198
< 2010-12-07 19:24:32.860 Type: SSH_FXP_STATUS, Size: 24, Number: 8452
< 2010-12-07 19:24:32.860 Status code: 0
> 2010-12-07 19:24:32.860 Type: SSH_FXP_REMOVE, Size: 76, Number: 8717
< 2010-12-07 19:24:34.079 Type: SSH_FXP_STATUS, Size: 24, Number: 8717
< 2010-12-07 19:24:34.079 Status code: 0
> 2010-12-07 19:24:34.079 Type: SSH_FXP_RENAME, Size: 156, Number: 8978
< 2010-12-07 19:24:36.298 Type: SSH_FXP_STATUS, Size: 24, Number: 8978
< 2010-12-07 19:24:36.298 Status code: 0
> 2010-12-07 19:24:36.298 Type: SSH_FXP_SETSTAT, Size: 92, Number: 1033
< 2010-12-07 19:24:37.017 Type: SSH_FXP_STATUS, Size: 24, Number: 1033
< 2010-12-07 19:24:37.017 Status code: 0
. 2010-12-07 19:24:37.017 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:24:37.017 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:24:37.017 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:24:37.017 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:24:37.017 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:24:37.032 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:24:37.032 Binary transfer mode selected.
. 2010-12-07 19:24:37.032 Opening remote file.
> 2010-12-07 19:24:37.032 Type: SSH_FXP_OPEN, Size: 91, Number: 9219
< 2010-12-07 19:24:38.001 Type: SSH_FXP_HANDLE, Size: 13, Number: 9219
> 2010-12-07 19:24:38.001 Type: SSH_FXP_WRITE, Size: 989, Number: 9734
> 2010-12-07 19:24:38.001 Type: SSH_FXP_CLOSE, Size: 13, Number: 9988
> 2010-12-07 19:24:38.001 Type: SSH_FXP_SETSTAT, Size: 87, Number: 9481
< 2010-12-07 19:24:38.048 Type: SSH_FXP_STATUS, Size: 24, Number: 9734
< 2010-12-07 19:24:38.220 Type: SSH_FXP_STATUS, Size: 24, Number: 9988
< 2010-12-07 19:24:38.220 Status code: 0
< 2010-12-07 19:24:39.079 Type: SSH_FXP_STATUS, Size: 24, Number: 9481
< 2010-12-07 19:24:39.079 Status code: 0
. 2010-12-07 19:24:39.095 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:24:39.095 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:24:39.095 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:24:39.095 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:24:39.095 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:24:39.095 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:24:39.095 Binary transfer mode selected.
. 2010-12-07 19:24:39.095 Opening remote file.
> 2010-12-07 19:24:39.095 Type: SSH_FXP_OPEN, Size: 92, Number: 10243
< 2010-12-07 19:24:41.329 Type: SSH_FXP_HANDLE, Size: 13, Number: 10243
> 2010-12-07 19:24:41.329 Type: SSH_FXP_WRITE, Size: 4121, Number: 10758
. 2010-12-07 19:24:41.329 8 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-12-07 19:24:41.329 Type: SSH_FXP_CLOSE, Size: 13, Number: 12548
< 2010-12-07 19:24:41.329 Type: SSH_FXP_STATUS, Size: 24, Number: 11270
< 2010-12-07 19:24:41.329 Status code: 0
> 2010-12-07 19:24:41.329 Type: SSH_FXP_SETSTAT, Size: 88, Number: 10505
< 2010-12-07 19:24:41.329 Type: SSH_FXP_STATUS, Size: 24, Number: 11526
< 2010-12-07 19:24:41.329 Type: SSH_FXP_STATUS, Size: 24, Number: 11782
< 2010-12-07 19:24:41.501 Type: SSH_FXP_STATUS, Size: 24, Number: 12038
< 2010-12-07 19:24:41.501 Type: SSH_FXP_STATUS, Size: 24, Number: 12294
< 2010-12-07 19:24:41.501 Type: SSH_FXP_STATUS, Size: 24, Number: 12548
< 2010-12-07 19:24:41.501 Status code: 0
< 2010-12-07 19:24:42.111 Type: SSH_FXP_STATUS, Size: 24, Number: 10505
< 2010-12-07 19:24:42.111 Status code: 0
. 2010-12-07 19:24:42.111 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:24:42.111 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:24:42.111 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:24:42.111 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:24:42.111 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:24:42.111 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:24:42.111 Binary transfer mode selected.
. 2010-12-07 19:24:42.111 Opening remote file.
> 2010-12-07 19:24:42.111 Type: SSH_FXP_OPEN, Size: 93, Number: 12803
< 2010-12-07 19:24:43.267 Type: SSH_FXP_HANDLE, Size: 13, Number: 12803
> 2010-12-07 19:24:43.267 Type: SSH_FXP_WRITE, Size: 4121, Number: 13318
. 2010-12-07 19:24:43.267 6 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-12-07 19:24:43.267 Type: SSH_FXP_CLOSE, Size: 13, Number: 14596
< 2010-12-07 19:24:43.267 Type: SSH_FXP_STATUS, Size: 24, Number: 13830
< 2010-12-07 19:24:43.267 Status code: 0
> 2010-12-07 19:24:43.267 Type: SSH_FXP_SETSTAT, Size: 89, Number: 13065
< 2010-12-07 19:24:43.267 Type: SSH_FXP_STATUS, Size: 24, Number: 14086
< 2010-12-07 19:24:43.267 Type: SSH_FXP_STATUS, Size: 24, Number: 14342
< 2010-12-07 19:24:43.470 Type: SSH_FXP_STATUS, Size: 24, Number: 14596
< 2010-12-07 19:24:43.470 Status code: 0
< 2010-12-07 19:24:43.720 Type: SSH_FXP_STATUS, Size: 24, Number: 13065
< 2010-12-07 19:24:43.720 Status code: 0
. 2010-12-07 19:24:43.720 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:24:43.720 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:24:43.720 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:24:43.720 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:24:43.720 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:24:43.720 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:24:43.720 Binary transfer mode selected.
. 2010-12-07 19:24:43.720 Opening remote file.
> 2010-12-07 19:24:43.720 Type: SSH_FXP_OPEN, Size: 90, Number: 14851
< 2010-12-07 19:24:44.829 Type: SSH_FXP_HANDLE, Size: 13, Number: 14851
> 2010-12-07 19:24:44.829 Type: SSH_FXP_WRITE, Size: 3808, Number: 15366
> 2010-12-07 19:24:44.829 Type: SSH_FXP_CLOSE, Size: 13, Number: 15620
> 2010-12-07 19:24:44.829 Type: SSH_FXP_SETSTAT, Size: 86, Number: 15113
< 2010-12-07 19:24:44.829 Type: SSH_FXP_STATUS, Size: 24, Number: 15366
< 2010-12-07 19:24:44.861 Type: SSH_FXP_STATUS, Size: 24, Number: 15620
< 2010-12-07 19:24:44.861 Status code: 0
< 2010-12-07 19:24:45.486 Type: SSH_FXP_STATUS, Size: 24, Number: 15113
< 2010-12-07 19:24:45.486 Status code: 0
. 2010-12-07 19:24:45.486 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:24:45.486 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:24:45.486 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:24:45.486 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:24:45.486 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:24:45.486 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:24:45.486 Binary transfer mode selected.
. 2010-12-07 19:24:45.486 Opening remote file.
> 2010-12-07 19:24:45.486 Type: SSH_FXP_OPEN, Size: 91, Number: 15875
< 2010-12-07 19:24:46.423 Type: SSH_FXP_HANDLE, Size: 13, Number: 15875
> 2010-12-07 19:24:46.423 Type: SSH_FXP_WRITE, Size: 2008, Number: 16390
> 2010-12-07 19:24:46.423 Type: SSH_FXP_CLOSE, Size: 13, Number: 16644
> 2010-12-07 19:24:46.423 Type: SSH_FXP_SETSTAT, Size: 87, Number: 16137
< 2010-12-07 19:24:46.423 Type: SSH_FXP_STATUS, Size: 24, Number: 16390
< 2010-12-07 19:24:46.642 Type: SSH_FXP_STATUS, Size: 24, Number: 16644
< 2010-12-07 19:24:46.642 Status code: 0
< 2010-12-07 19:24:47.111 Type: SSH_FXP_STATUS, Size: 24, Number: 16137
< 2010-12-07 19:24:47.111 Status code: 0
. 2010-12-07 19:24:47.111 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:24:47.111 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:24:47.111 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:24:47.111 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:24:47.111 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:24:47.111 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:24:47.111 Binary transfer mode selected.
. 2010-12-07 19:24:47.111 Opening remote file.
> 2010-12-07 19:24:47.111 Type: SSH_FXP_OPEN, Size: 89, Number: 16899
< 2010-12-07 19:24:48.486 Type: SSH_FXP_HANDLE, Size: 13, Number: 16899
> 2010-12-07 19:24:48.486 Type: SSH_FXP_WRITE, Size: 1566, Number: 17414
> 2010-12-07 19:24:48.486 Type: SSH_FXP_CLOSE, Size: 13, Number: 17668
> 2010-12-07 19:24:48.486 Type: SSH_FXP_SETSTAT, Size: 85, Number: 17161
< 2010-12-07 19:24:48.486 Type: SSH_FXP_STATUS, Size: 24, Number: 17414
< 2010-12-07 19:24:48.611 Type: SSH_FXP_STATUS, Size: 24, Number: 17668
< 2010-12-07 19:24:48.611 Status code: 0
< 2010-12-07 19:24:49.048 Type: SSH_FXP_STATUS, Size: 24, Number: 17161
< 2010-12-07 19:24:49.048 Status code: 0
. 2010-12-07 19:24:49.064 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:24:49.064 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:24:49.064 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:24:49.064 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:24:49.064 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:24:49.064 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:24:49.064 Binary transfer mode selected.
. 2010-12-07 19:24:49.064 Opening remote file.
> 2010-12-07 19:24:49.064 Type: SSH_FXP_OPEN, Size: 92, Number: 17923
< 2010-12-07 19:24:51.111 Type: SSH_FXP_HANDLE, Size: 13, Number: 17923
> 2010-12-07 19:24:51.111 Type: SSH_FXP_WRITE, Size: 1382, Number: 18438
> 2010-12-07 19:24:51.111 Type: SSH_FXP_CLOSE, Size: 13, Number: 18692
> 2010-12-07 19:24:51.111 Type: SSH_FXP_SETSTAT, Size: 88, Number: 18185
< 2010-12-07 19:24:51.158 Type: SSH_FXP_STATUS, Size: 24, Number: 18438
< 2010-12-07 19:24:51.345 Type: SSH_FXP_STATUS, Size: 24, Number: 18692
< 2010-12-07 19:24:51.345 Status code: 0
< 2010-12-07 19:24:51.564 Type: SSH_FXP_STATUS, Size: 24, Number: 18185
< 2010-12-07 19:24:51.564 Status code: 0
. 2010-12-07 19:24:51.564 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:24:51.564 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:24:51.564 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:24:51.564 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:24:51.564 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:24:51.564 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:24:51.564 Binary transfer mode selected.
. 2010-12-07 19:24:51.564 Opening remote file.
> 2010-12-07 19:24:51.564 Type: SSH_FXP_OPEN, Size: 93, Number: 18947
< 2010-12-07 19:24:52.658 Type: SSH_FXP_HANDLE, Size: 13, Number: 18947
> 2010-12-07 19:24:52.658 Type: SSH_FXP_WRITE, Size: 1574, Number: 19462
> 2010-12-07 19:24:52.658 Type: SSH_FXP_CLOSE, Size: 13, Number: 19716
> 2010-12-07 19:24:52.658 Type: SSH_FXP_SETSTAT, Size: 89, Number: 19209
< 2010-12-07 19:24:52.658 Type: SSH_FXP_STATUS, Size: 24, Number: 19462
< 2010-12-07 19:24:52.876 Type: SSH_FXP_STATUS, Size: 24, Number: 19716
< 2010-12-07 19:24:52.876 Status code: 0
< 2010-12-07 19:24:53.626 Type: SSH_FXP_STATUS, Size: 24, Number: 19209
< 2010-12-07 19:24:53.626 Status code: 0
. 2010-12-07 19:24:53.626 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:24:53.626 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:24:53.626 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:24:53.626 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:24:53.626 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:24:53.626 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:24:53.626 Binary transfer mode selected.
. 2010-12-07 19:24:53.626 Opening remote file.
> 2010-12-07 19:24:53.626 Type: SSH_FXP_OPEN, Size: 62, Number: 19971
< 2010-12-07 19:24:54.923 Type: SSH_FXP_HANDLE, Size: 13, Number: 19971
> 2010-12-07 19:24:54.923 Type: SSH_FXP_WRITE, Size: 668, Number: 20486
> 2010-12-07 19:24:54.923 Type: SSH_FXP_CLOSE, Size: 13, Number: 20740
> 2010-12-07 19:24:54.923 Type: SSH_FXP_SETSTAT, Size: 58, Number: 20233
< 2010-12-07 19:24:54.970 Type: SSH_FXP_STATUS, Size: 24, Number: 20486
< 2010-12-07 19:24:55.173 Type: SSH_FXP_STATUS, Size: 24, Number: 20740
< 2010-12-07 19:24:55.173 Status code: 0
< 2010-12-07 19:24:55.392 Type: SSH_FXP_STATUS, Size: 24, Number: 20233
< 2010-12-07 19:24:55.392 Status code: 0
. 2010-12-07 19:24:55.392 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:24:55.392 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:24:55.392 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:24:55.392 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:24:55.392 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:24:55.392 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:24:55.392 Binary transfer mode selected.
. 2010-12-07 19:24:55.392 Opening remote file.
> 2010-12-07 19:24:55.392 Type: SSH_FXP_OPEN, Size: 96, Number: 20995
< 2010-12-07 19:24:56.423 Type: SSH_FXP_HANDLE, Size: 13, Number: 20995
> 2010-12-07 19:24:56.423 Type: SSH_FXP_WRITE, Size: 4121, Number: 21510
. 2010-12-07 19:24:56.423 8 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-12-07 19:24:56.423 Type: SSH_FXP_CLOSE, Size: 13, Number: 23300
< 2010-12-07 19:24:56.423 Type: SSH_FXP_STATUS, Size: 24, Number: 22022
< 2010-12-07 19:24:56.423 Status code: 0
> 2010-12-07 19:24:56.423 Type: SSH_FXP_SETSTAT, Size: 92, Number: 21257
< 2010-12-07 19:24:56.423 Type: SSH_FXP_STATUS, Size: 24, Number: 22278
< 2010-12-07 19:24:56.423 Type: SSH_FXP_STATUS, Size: 24, Number: 22534
< 2010-12-07 19:24:56.423 Type: SSH_FXP_STATUS, Size: 24, Number: 22790
< 2010-12-07 19:24:56.595 Type: SSH_FXP_STATUS, Size: 24, Number: 23046
< 2010-12-07 19:24:56.595 Type: SSH_FXP_STATUS, Size: 24, Number: 23300
< 2010-12-07 19:24:56.595 Status code: 0
< 2010-12-07 19:24:57.377 Type: SSH_FXP_STATUS, Size: 24, Number: 21257
< 2010-12-07 19:24:57.377 Status code: 0
. 2010-12-07 19:24:57.377 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:24:57.377 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:24:57.377 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:24:57.377 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:24:57.392 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:24:57.392 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:24:57.392 Binary transfer mode selected.
. 2010-12-07 19:24:57.392 Checking existence of file.
> 2010-12-07 19:24:57.392 Type: SSH_FXP_LSTAT, Size: 78, Number: 23559
< 2010-12-07 19:24:58.627 Type: SSH_FXP_ATTRS, Size: 37, Number: 23559
. 2010-12-07 19:24:58.627 Checking existence of partially transfered file.
> 2010-12-07 19:24:58.627 Type: SSH_FXP_LSTAT, Size: 87, Number: 23815
< 2010-12-07 19:24:59.939 Type: SSH_FXP_STATUS, Size: 29, Number: 23815
< 2010-12-07 19:24:59.939 Status code: 2
. 2010-12-07 19:24:59.939 Opening remote file.
> 2010-12-07 19:24:59.939 Type: SSH_FXP_OPEN, Size: 103, Number: 24067
< 2010-12-07 19:25:01.595 Type: SSH_FXP_HANDLE, Size: 13, Number: 24067
> 2010-12-07 19:25:01.595 Type: SSH_FXP_WRITE, Size: 4121, Number: 24582
. 2010-12-07 19:25:01.627 74 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-12-07 19:25:01.627 Type: SSH_FXP_CLOSE, Size: 13, Number: 34564
< 2010-12-07 19:25:01.627 Type: SSH_FXP_STATUS, Size: 24, Number: 33798
< 2010-12-07 19:25:01.627 Status code: 0
< 2010-12-07 19:25:01.627 Type: SSH_FXP_STATUS, Size: 24, Number: 34054
< 2010-12-07 19:25:01.845 Type: SSH_FXP_STATUS, Size: 24, Number: 34310
< 2010-12-07 19:25:01.845 Type: SSH_FXP_STATUS, Size: 24, Number: 34564
< 2010-12-07 19:25:01.845 Status code: 0
> 2010-12-07 19:25:01.845 Type: SSH_FXP_REMOVE, Size: 78, Number: 34829
< 2010-12-07 19:25:03.111 Type: SSH_FXP_STATUS, Size: 24, Number: 34829
< 2010-12-07 19:25:03.111 Status code: 0
> 2010-12-07 19:25:03.111 Type: SSH_FXP_RENAME, Size: 160, Number: 35090
< 2010-12-07 19:25:06.299 Type: SSH_FXP_STATUS, Size: 24, Number: 35090
< 2010-12-07 19:25:06.299 Status code: 0
> 2010-12-07 19:25:06.299 Type: SSH_FXP_SETSTAT, Size: 94, Number: 24329
< 2010-12-07 19:25:07.627 Type: SSH_FXP_STATUS, Size: 24, Number: 24329
< 2010-12-07 19:25:07.627 Status code: 0
. 2010-12-07 19:25:07.627 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:25:07.627 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:25:07.627 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:25:07.627 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:25:07.627 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:25:07.627 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:25:07.627 Binary transfer mode selected.
. 2010-12-07 19:25:07.627 Checking existence of file.
> 2010-12-07 19:25:07.627 Type: SSH_FXP_LSTAT, Size: 77, Number: 35335
< 2010-12-07 19:25:08.345 Type: SSH_FXP_ATTRS, Size: 37, Number: 35335
. 2010-12-07 19:25:08.345 Checking existence of partially transfered file.
> 2010-12-07 19:25:08.345 Type: SSH_FXP_LSTAT, Size: 86, Number: 35591
< 2010-12-07 19:25:13.596 Type: SSH_FXP_STATUS, Size: 29, Number: 35591
< 2010-12-07 19:25:13.596 Status code: 2
. 2010-12-07 19:25:13.596 Opening remote file.
> 2010-12-07 19:25:13.596 Type: SSH_FXP_OPEN, Size: 102, Number: 35843
< 2010-12-07 19:25:18.189 Type: SSH_FXP_HANDLE, Size: 13, Number: 35843
> 2010-12-07 19:25:18.189 Type: SSH_FXP_WRITE, Size: 4121, Number: 36358
. 2010-12-07 19:25:18.221 69 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-12-07 19:25:18.221 Type: SSH_FXP_CLOSE, Size: 13, Number: 45572
< 2010-12-07 19:25:18.221 Type: SSH_FXP_STATUS, Size: 24, Number: 45062
< 2010-12-07 19:25:18.221 Type: SSH_FXP_STATUS, Size: 24, Number: 45318
< 2010-12-07 19:25:18.377 Type: SSH_FXP_STATUS, Size: 24, Number: 45572
< 2010-12-07 19:25:18.377 Status code: 0
> 2010-12-07 19:25:18.377 Type: SSH_FXP_REMOVE, Size: 77, Number: 45837
< 2010-12-07 19:25:19.908 Type: SSH_FXP_STATUS, Size: 24, Number: 45837
< 2010-12-07 19:25:19.908 Status code: 0
> 2010-12-07 19:25:19.908 Type: SSH_FXP_RENAME, Size: 158, Number: 46098
< 2010-12-07 19:25:23.377 Type: SSH_FXP_STATUS, Size: 24, Number: 46098
< 2010-12-07 19:25:23.377 Status code: 0
> 2010-12-07 19:25:23.377 Type: SSH_FXP_SETSTAT, Size: 93, Number: 36105
< 2010-12-07 19:25:23.830 Type: SSH_FXP_STATUS, Size: 24, Number: 36105
< 2010-12-07 19:25:23.830 Status code: 0
. 2010-12-07 19:25:23.830 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:25:23.830 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:25:23.830 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:25:23.830 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:25:23.830 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:25:23.830 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:25:23.830 Binary transfer mode selected.
. 2010-12-07 19:25:23.830 Checking existence of file.
> 2010-12-07 19:25:23.830 Type: SSH_FXP_LSTAT, Size: 77, Number: 46343
< 2010-12-07 19:25:24.127 Type: SSH_FXP_ATTRS, Size: 37, Number: 46343
. 2010-12-07 19:25:24.127 Checking existence of partially transfered file.
> 2010-12-07 19:25:24.127 Type: SSH_FXP_LSTAT, Size: 86, Number: 46599
< 2010-12-07 19:25:25.236 Type: SSH_FXP_STATUS, Size: 29, Number: 46599
< 2010-12-07 19:25:25.236 Status code: 2
. 2010-12-07 19:25:25.236 Opening remote file.
> 2010-12-07 19:25:25.236 Type: SSH_FXP_OPEN, Size: 102, Number: 46851
< 2010-12-07 19:25:26.861 Type: SSH_FXP_HANDLE, Size: 13, Number: 46851
> 2010-12-07 19:25:26.861 Type: SSH_FXP_WRITE, Size: 4121, Number: 47366
. 2010-12-07 19:25:26.908 19 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-12-07 19:25:26.908 Type: SSH_FXP_CLOSE, Size: 13, Number: 50180
< 2010-12-07 19:25:26.908 Type: SSH_FXP_STATUS, Size: 24, Number: 49670
< 2010-12-07 19:25:26.908 Status code: 0
< 2010-12-07 19:25:27.111 Type: SSH_FXP_STATUS, Size: 24, Number: 49926
< 2010-12-07 19:25:27.111 Type: SSH_FXP_STATUS, Size: 24, Number: 50180
< 2010-12-07 19:25:27.111 Status code: 0
> 2010-12-07 19:25:27.111 Type: SSH_FXP_REMOVE, Size: 77, Number: 50445
< 2010-12-07 19:25:28.736 Type: SSH_FXP_STATUS, Size: 24, Number: 50445
< 2010-12-07 19:25:28.736 Status code: 0
> 2010-12-07 19:25:28.736 Type: SSH_FXP_RENAME, Size: 158, Number: 50706
< 2010-12-07 19:25:31.190 Type: SSH_FXP_STATUS, Size: 24, Number: 50706
< 2010-12-07 19:25:31.190 Status code: 0
> 2010-12-07 19:25:31.190 Type: SSH_FXP_SETSTAT, Size: 93, Number: 47113
< 2010-12-07 19:25:33.377 Type: SSH_FXP_STATUS, Size: 24, Number: 47113
< 2010-12-07 19:25:33.377 Status code: 0
. 2010-12-07 19:25:33.377 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:25:33.377 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:25:33.377 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:25:33.377 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:25:33.377 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:25:33.377 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:25:33.377 Binary transfer mode selected.
. 2010-12-07 19:25:33.377 Checking existence of file.
> 2010-12-07 19:25:33.377 Type: SSH_FXP_LSTAT, Size: 76, Number: 50951
< 2010-12-07 19:25:34.721 Type: SSH_FXP_ATTRS, Size: 37, Number: 50951
. 2010-12-07 19:25:34.721 Checking existence of partially transfered file.
> 2010-12-07 19:25:34.721 Type: SSH_FXP_LSTAT, Size: 85, Number: 51207
< 2010-12-07 19:25:35.971 Type: SSH_FXP_STATUS, Size: 29, Number: 51207
< 2010-12-07 19:25:35.971 Status code: 2
. 2010-12-07 19:25:35.971 Opening remote file.
> 2010-12-07 19:25:35.971 Type: SSH_FXP_OPEN, Size: 101, Number: 51459
< 2010-12-07 19:25:38.205 Type: SSH_FXP_HANDLE, Size: 13, Number: 51459
> 2010-12-07 19:25:38.205 Type: SSH_FXP_WRITE, Size: 4121, Number: 51974
. 2010-12-07 19:25:38.237 55 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-12-07 19:25:38.237 Type: SSH_FXP_CLOSE, Size: 13, Number: 59396
< 2010-12-07 19:25:38.237 Type: SSH_FXP_STATUS, Size: 24, Number: 58886
< 2010-12-07 19:25:38.237 Type: SSH_FXP_STATUS, Size: 24, Number: 59142
< 2010-12-07 19:25:38.377 Type: SSH_FXP_STATUS, Size: 24, Number: 59396
< 2010-12-07 19:25:38.377 Status code: 0
> 2010-12-07 19:25:38.377 Type: SSH_FXP_REMOVE, Size: 76, Number: 59661
< 2010-12-07 19:25:39.705 Type: SSH_FXP_STATUS, Size: 24, Number: 59661
< 2010-12-07 19:25:39.705 Status code: 0
> 2010-12-07 19:25:39.705 Type: SSH_FXP_RENAME, Size: 156, Number: 59922
< 2010-12-07 19:25:43.393 Type: SSH_FXP_STATUS, Size: 24, Number: 59922
< 2010-12-07 19:25:43.393 Status code: 0
> 2010-12-07 19:25:43.393 Type: SSH_FXP_SETSTAT, Size: 92, Number: 51721
< 2010-12-07 19:25:44.174 Type: SSH_FXP_STATUS, Size: 24, Number: 51721
< 2010-12-07 19:25:44.174 Status code: 0
. 2010-12-07 19:25:44.174 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:25:44.174 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:25:44.174 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:25:44.174 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:25:44.174 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:25:44.174 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:25:44.174 Binary transfer mode selected.
. 2010-12-07 19:25:44.174 Checking existence of file.
> 2010-12-07 19:25:44.174 Type: SSH_FXP_LSTAT, Size: 77, Number: 60167
< 2010-12-07 19:25:45.206 Type: SSH_FXP_ATTRS, Size: 37, Number: 60167
. 2010-12-07 19:25:45.206 Checking existence of partially transfered file.
> 2010-12-07 19:25:45.206 Type: SSH_FXP_LSTAT, Size: 86, Number: 60423
< 2010-12-07 19:25:46.471 Type: SSH_FXP_STATUS, Size: 29, Number: 60423
< 2010-12-07 19:25:46.471 Status code: 2
. 2010-12-07 19:25:46.471 Opening remote file.
> 2010-12-07 19:25:46.471 Type: SSH_FXP_OPEN, Size: 102, Number: 60675
< 2010-12-07 19:25:48.878 Type: SSH_FXP_HANDLE, Size: 13, Number: 60675
> 2010-12-07 19:25:48.878 Type: SSH_FXP_WRITE, Size: 4121, Number: 61190
. 2010-12-07 19:25:48.924 23 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-12-07 19:25:48.924 Type: SSH_FXP_CLOSE, Size: 13, Number: 64516
< 2010-12-07 19:25:48.924 Type: SSH_FXP_STATUS, Size: 24, Number: 64006
< 2010-12-07 19:25:48.924 Type: SSH_FXP_STATUS, Size: 24, Number: 64262
< 2010-12-07 19:25:49.096 Type: SSH_FXP_STATUS, Size: 24, Number: 64516
< 2010-12-07 19:25:49.096 Status code: 0
> 2010-12-07 19:25:49.096 Type: SSH_FXP_REMOVE, Size: 77, Number: 64781
< 2010-12-07 19:25:50.299 Type: SSH_FXP_STATUS, Size: 24, Number: 64781
< 2010-12-07 19:25:50.299 Status code: 0
> 2010-12-07 19:25:50.299 Type: SSH_FXP_RENAME, Size: 158, Number: 65042
< 2010-12-07 19:25:53.331 Type: SSH_FXP_STATUS, Size: 24, Number: 65042
< 2010-12-07 19:25:53.331 Status code: 0
> 2010-12-07 19:25:53.331 Type: SSH_FXP_SETSTAT, Size: 93, Number: 60937
< 2010-12-07 19:25:55.800 Type: SSH_FXP_STATUS, Size: 24, Number: 60937
< 2010-12-07 19:25:55.800 Status code: 0
. 2010-12-07 19:25:55.800 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:25:55.800 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:25:55.800 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:25:55.800 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:25:55.800 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:25:55.800 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:25:55.815 Binary transfer mode selected.
. 2010-12-07 19:25:55.815 Opening remote file.
> 2010-12-07 19:25:55.815 Type: SSH_FXP_OPEN, Size: 95, Number: 65283
< 2010-12-07 19:25:58.440 Type: SSH_FXP_HANDLE, Size: 13, Number: 65283
> 2010-12-07 19:25:58.440 Type: SSH_FXP_WRITE, Size: 4121, Number: 65798
. 2010-12-07 19:25:58.440 6 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-12-07 19:25:58.440 Type: SSH_FXP_CLOSE, Size: 13, Number: 67076
> 2010-12-07 19:25:58.440 Type: SSH_FXP_SETSTAT, Size: 91, Number: 65545
< 2010-12-07 19:25:58.456 Type: SSH_FXP_STATUS, Size: 24, Number: 66310
< 2010-12-07 19:25:58.456 Status code: 0
< 2010-12-07 19:25:58.456 Type: SSH_FXP_STATUS, Size: 24, Number: 66566
< 2010-12-07 19:25:58.612 Type: SSH_FXP_STATUS, Size: 24, Number: 66822
< 2010-12-07 19:25:58.612 Type: SSH_FXP_STATUS, Size: 24, Number: 67076
< 2010-12-07 19:25:58.612 Status code: 0
< 2010-12-07 19:26:01.425 Type: SSH_FXP_STATUS, Size: 24, Number: 65545
< 2010-12-07 19:26:01.425 Status code: 0
. 2010-12-07 19:26:01.425 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:26:01.425 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:26:01.425 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:26:01.425 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:26:01.425 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:26:01.425 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:26:01.425 Binary transfer mode selected.
. 2010-12-07 19:26:01.425 Opening remote file.
> 2010-12-07 19:26:01.425 Type: SSH_FXP_OPEN, Size: 99, Number: 67331
< 2010-12-07 19:26:02.003 Type: SSH_FXP_HANDLE, Size: 13, Number: 67331
> 2010-12-07 19:26:02.003 Type: SSH_FXP_WRITE, Size: 4121, Number: 67846
. 2010-12-07 19:26:02.018 4 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-12-07 19:26:02.018 Type: SSH_FXP_CLOSE, Size: 13, Number: 68612
> 2010-12-07 19:26:02.018 Type: SSH_FXP_SETSTAT, Size: 95, Number: 67593
< 2010-12-07 19:26:02.222 Type: SSH_FXP_STATUS, Size: 24, Number: 68358
< 2010-12-07 19:26:02.222 Type: SSH_FXP_STATUS, Size: 24, Number: 68612
< 2010-12-07 19:26:02.222 Status code: 0
< 2010-12-07 19:26:02.472 Type: SSH_FXP_STATUS, Size: 24, Number: 67593
< 2010-12-07 19:26:02.472 Status code: 0
. 2010-12-07 19:26:02.472 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:26:02.472 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:26:02.472 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:26:02.472 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:26:02.472 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:26:02.472 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:26:02.472 Binary transfer mode selected.
. 2010-12-07 19:26:02.472 Opening remote file.
> 2010-12-07 19:26:02.472 Type: SSH_FXP_OPEN, Size: 93, Number: 68867
< 2010-12-07 19:26:03.956 Type: SSH_FXP_HANDLE, Size: 13, Number: 68867
> 2010-12-07 19:26:03.956 Type: SSH_FXP_WRITE, Size: 3385, Number: 69382
> 2010-12-07 19:26:03.956 Type: SSH_FXP_CLOSE, Size: 13, Number: 69636
> 2010-12-07 19:26:03.956 Type: SSH_FXP_SETSTAT, Size: 89, Number: 69129
< 2010-12-07 19:26:03.956 Type: SSH_FXP_STATUS, Size: 24, Number: 69382
< 2010-12-07 19:26:04.003 Type: SSH_FXP_STATUS, Size: 24, Number: 69636
< 2010-12-07 19:26:04.003 Status code: 0
< 2010-12-07 19:26:04.737 Type: SSH_FXP_STATUS, Size: 24, Number: 69129
< 2010-12-07 19:26:04.737 Status code: 0
. 2010-12-07 19:26:04.737 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:26:04.737 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:26:04.737 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:26:04.737 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:26:04.737 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:26:04.737 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:26:04.737 Binary transfer mode selected.
. 2010-12-07 19:26:04.737 Checking existence of file.
> 2010-12-07 19:26:04.737 Type: SSH_FXP_LSTAT, Size: 76, Number: 69895
< 2010-12-07 19:26:05.597 Type: SSH_FXP_ATTRS, Size: 37, Number: 69895
. 2010-12-07 19:26:05.597 Checking existence of partially transfered file.
> 2010-12-07 19:26:05.597 Type: SSH_FXP_LSTAT, Size: 85, Number: 70151
< 2010-12-07 19:26:06.112 Type: SSH_FXP_STATUS, Size: 29, Number: 70151
< 2010-12-07 19:26:06.112 Status code: 2
. 2010-12-07 19:26:06.112 Opening remote file.
> 2010-12-07 19:26:06.112 Type: SSH_FXP_OPEN, Size: 101, Number: 70403
< 2010-12-07 19:26:07.753 Type: SSH_FXP_HANDLE, Size: 13, Number: 70403
> 2010-12-07 19:26:07.753 Type: SSH_FXP_WRITE, Size: 4121, Number: 70918
. 2010-12-07 19:26:07.800 37 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-12-07 19:26:07.800 Type: SSH_FXP_CLOSE, Size: 13, Number: 76036
< 2010-12-07 19:26:07.800 Type: SSH_FXP_STATUS, Size: 24, Number: 75526
< 2010-12-07 19:26:07.800 Type: SSH_FXP_STATUS, Size: 24, Number: 75782
< 2010-12-07 19:26:08.018 Type: SSH_FXP_STATUS, Size: 24, Number: 76036
< 2010-12-07 19:26:08.018 Status code: 0
> 2010-12-07 19:26:08.018 Type: SSH_FXP_REMOVE, Size: 76, Number: 76301
< 2010-12-07 19:26:09.581 Type: SSH_FXP_STATUS, Size: 24, Number: 76301
< 2010-12-07 19:26:09.581 Status code: 0
> 2010-12-07 19:26:09.581 Type: SSH_FXP_RENAME, Size: 156, Number: 76562
< 2010-12-07 19:26:11.440 Type: SSH_FXP_STATUS, Size: 24, Number: 76562
< 2010-12-07 19:26:11.440 Status code: 0
> 2010-12-07 19:26:11.440 Type: SSH_FXP_SETSTAT, Size: 92, Number: 70665
< 2010-12-07 19:26:13.737 Type: SSH_FXP_STATUS, Size: 24, Number: 70665
< 2010-12-07 19:26:13.737 Status code: 0
. 2010-12-07 19:26:13.737 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:26:13.737 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:26:13.737 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:26:13.737 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:26:13.737 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:26:13.753 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:26:13.753 Binary transfer mode selected.
. 2010-12-07 19:26:13.753 Opening remote file.
> 2010-12-07 19:26:13.753 Type: SSH_FXP_OPEN, Size: 91, Number: 76803
< 2010-12-07 19:26:15.066 Type: SSH_FXP_HANDLE, Size: 13, Number: 76803
> 2010-12-07 19:26:15.066 Type: SSH_FXP_WRITE, Size: 989, Number: 77318
> 2010-12-07 19:26:15.066 Type: SSH_FXP_CLOSE, Size: 13, Number: 77572
> 2010-12-07 19:26:15.081 Type: SSH_FXP_SETSTAT, Size: 87, Number: 77065
< 2010-12-07 19:26:15.128 Type: SSH_FXP_STATUS, Size: 24, Number: 77318
< 2010-12-07 19:26:15.347 Type: SSH_FXP_STATUS, Size: 24, Number: 77572
< 2010-12-07 19:26:15.347 Status code: 0
< 2010-12-07 19:26:15.566 Type: SSH_FXP_STATUS, Size: 24, Number: 77065
< 2010-12-07 19:26:15.566 Status code: 0
. 2010-12-07 19:26:15.566 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:26:15.566 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:26:15.566 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:26:15.566 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:26:15.566 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:26:15.566 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:26:15.566 Binary transfer mode selected.
. 2010-12-07 19:26:15.566 Opening remote file.
> 2010-12-07 19:26:15.566 Type: SSH_FXP_OPEN, Size: 92, Number: 77827
< 2010-12-07 19:26:16.612 Type: SSH_FXP_HANDLE, Size: 13, Number: 77827
> 2010-12-07 19:26:16.612 Type: SSH_FXP_WRITE, Size: 4121, Number: 78342
. 2010-12-07 19:26:16.612 8 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-12-07 19:26:16.612 Type: SSH_FXP_CLOSE, Size: 13, Number: 80132
< 2010-12-07 19:26:16.612 Type: SSH_FXP_STATUS, Size: 24, Number: 78854
< 2010-12-07 19:26:16.612 Status code: 0
> 2010-12-07 19:26:16.612 Type: SSH_FXP_SETSTAT, Size: 88, Number: 78089
< 2010-12-07 19:26:16.612 Type: SSH_FXP_STATUS, Size: 24, Number: 79110
< 2010-12-07 19:26:16.628 Type: SSH_FXP_STATUS, Size: 24, Number: 79366
< 2010-12-07 19:26:16.628 Type: SSH_FXP_STATUS, Size: 24, Number: 79622
< 2010-12-07 19:26:16.769 Type: SSH_FXP_STATUS, Size: 24, Number: 79878
< 2010-12-07 19:26:16.769 Type: SSH_FXP_STATUS, Size: 24, Number: 80132
< 2010-12-07 19:26:16.769 Status code: 0
< 2010-12-07 19:26:18.534 Type: SSH_FXP_STATUS, Size: 24, Number: 78089
< 2010-12-07 19:26:18.534 Status code: 0
. 2010-12-07 19:26:18.534 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:26:18.534 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:26:18.534 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:26:18.534 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:26:18.534 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:26:18.534 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:26:18.534 Binary transfer mode selected.
. 2010-12-07 19:26:18.534 Opening remote file.
> 2010-12-07 19:26:18.534 Type: SSH_FXP_OPEN, Size: 93, Number: 80387
< 2010-12-07 19:26:19.737 Type: SSH_FXP_HANDLE, Size: 13, Number: 80387
> 2010-12-07 19:26:19.737 Type: SSH_FXP_WRITE, Size: 4121, Number: 80902
. 2010-12-07 19:26:19.737 5 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-12-07 19:26:19.737 Type: SSH_FXP_CLOSE, Size: 13, Number: 82180
< 2010-12-07 19:26:19.737 Type: SSH_FXP_STATUS, Size: 24, Number: 81158
< 2010-12-07 19:26:19.737 Status code: 0
> 2010-12-07 19:26:19.753 Type: SSH_FXP_SETSTAT, Size: 89, Number: 80649
< 2010-12-07 19:26:19.753 Type: SSH_FXP_STATUS, Size: 24, Number: 81414
< 2010-12-07 19:26:19.753 Type: SSH_FXP_STATUS, Size: 24, Number: 81670
< 2010-12-07 19:26:19.941 Type: SSH_FXP_STATUS, Size: 24, Number: 81926
< 2010-12-07 19:26:19.941 Type: SSH_FXP_STATUS, Size: 24, Number: 82180
< 2010-12-07 19:26:19.941 Status code: 0
< 2010-12-07 19:26:20.269 Type: SSH_FXP_STATUS, Size: 24, Number: 80649
< 2010-12-07 19:26:20.269 Status code: 0
. 2010-12-07 19:26:20.269 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:26:20.269 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:26:20.269 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:26:20.269 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:26:20.269 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:26:20.269 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:26:20.269 Binary transfer mode selected.
. 2010-12-07 19:26:20.269 Opening remote file.
> 2010-12-07 19:26:20.269 Type: SSH_FXP_OPEN, Size: 90, Number: 82435
< 2010-12-07 19:26:21.956 Type: SSH_FXP_HANDLE, Size: 13, Number: 82435
> 2010-12-07 19:26:21.956 Type: SSH_FXP_WRITE, Size: 3808, Number: 82950
> 2010-12-07 19:26:21.956 Type: SSH_FXP_CLOSE, Size: 13, Number: 83204
> 2010-12-07 19:26:21.956 Type: SSH_FXP_SETSTAT, Size: 86, Number: 82697
< 2010-12-07 19:26:21.956 Type: SSH_FXP_STATUS, Size: 24, Number: 82950
< 2010-12-07 19:26:22.128 Type: SSH_FXP_STATUS, Size: 24, Number: 83204
< 2010-12-07 19:26:22.128 Status code: 0
< 2010-12-07 19:26:22.456 Type: SSH_FXP_STATUS, Size: 24, Number: 82697
< 2010-12-07 19:26:22.456 Status code: 0
. 2010-12-07 19:26:22.456 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:26:22.456 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:26:22.456 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:26:22.456 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:26:22.456 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:26:22.456 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:26:22.456 Binary transfer mode selected.
. 2010-12-07 19:26:22.456 Opening remote file.
> 2010-12-07 19:26:22.456 Type: SSH_FXP_OPEN, Size: 91, Number: 83459
< 2010-12-07 19:26:24.019 Type: SSH_FXP_HANDLE, Size: 13, Number: 83459
> 2010-12-07 19:26:24.019 Type: SSH_FXP_WRITE, Size: 2008, Number: 83974
> 2010-12-07 19:26:24.019 Type: SSH_FXP_CLOSE, Size: 13, Number: 84228
> 2010-12-07 19:26:24.019 Type: SSH_FXP_SETSTAT, Size: 87, Number: 83721
< 2010-12-07 19:26:24.019 Type: SSH_FXP_STATUS, Size: 24, Number: 83974
< 2010-12-07 19:26:24.050 Type: SSH_FXP_STATUS, Size: 24, Number: 84228
< 2010-12-07 19:26:24.050 Status code: 0
< 2010-12-07 19:26:24.316 Type: SSH_FXP_STATUS, Size: 24, Number: 83721
< 2010-12-07 19:26:24.316 Status code: 0
. 2010-12-07 19:26:24.316 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:26:24.316 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:26:24.316 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:26:24.316 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:26:24.316 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:26:24.316 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:26:24.316 Binary transfer mode selected.
. 2010-12-07 19:26:24.316 Opening remote file.
> 2010-12-07 19:26:24.316 Type: SSH_FXP_OPEN, Size: 89, Number: 84483
< 2010-12-07 19:26:26.269 Type: SSH_FXP_HANDLE, Size: 13, Number: 84483
> 2010-12-07 19:26:26.269 Type: SSH_FXP_WRITE, Size: 1566, Number: 84998
> 2010-12-07 19:26:26.269 Type: SSH_FXP_CLOSE, Size: 13, Number: 85252
> 2010-12-07 19:26:26.269 Type: SSH_FXP_SETSTAT, Size: 85, Number: 84745
< 2010-12-07 19:26:26.269 Type: SSH_FXP_STATUS, Size: 24, Number: 84998
< 2010-12-07 19:26:26.394 Type: SSH_FXP_STATUS, Size: 24, Number: 85252
< 2010-12-07 19:26:26.394 Status code: 0
< 2010-12-07 19:26:26.613 Type: SSH_FXP_STATUS, Size: 24, Number: 84745
< 2010-12-07 19:26:26.613 Status code: 0
. 2010-12-07 19:26:26.613 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:26:26.613 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:26:26.613 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:26:26.613 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:26:26.613 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:26:26.613 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:26:26.613 Binary transfer mode selected.
. 2010-12-07 19:26:26.613 Opening remote file.
> 2010-12-07 19:26:26.613 Type: SSH_FXP_OPEN, Size: 92, Number: 85507
< 2010-12-07 19:26:28.269 Type: SSH_FXP_HANDLE, Size: 13, Number: 85507
> 2010-12-07 19:26:28.269 Type: SSH_FXP_WRITE, Size: 1382, Number: 86022
> 2010-12-07 19:26:28.269 Type: SSH_FXP_CLOSE, Size: 13, Number: 86276
> 2010-12-07 19:26:28.269 Type: SSH_FXP_SETSTAT, Size: 88, Number: 85769
< 2010-12-07 19:26:28.316 Type: SSH_FXP_STATUS, Size: 24, Number: 86022
< 2010-12-07 19:26:28.488 Type: SSH_FXP_STATUS, Size: 24, Number: 86276
< 2010-12-07 19:26:28.488 Status code: 0
< 2010-12-07 19:26:28.691 Type: SSH_FXP_STATUS, Size: 24, Number: 85769
< 2010-12-07 19:26:28.691 Status code: 0
. 2010-12-07 19:26:28.691 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:26:28.691 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:26:28.691 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:26:28.691 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:26:28.691 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:26:28.691 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:26:28.691 Binary transfer mode selected.
. 2010-12-07 19:26:28.691 Opening remote file.
> 2010-12-07 19:26:28.691 Type: SSH_FXP_OPEN, Size: 93, Number: 86531
< 2010-12-07 19:26:29.800 Type: SSH_FXP_HANDLE, Size: 13, Number: 86531
> 2010-12-07 19:26:29.800 Type: SSH_FXP_WRITE, Size: 1574, Number: 87046
> 2010-12-07 19:26:29.800 Type: SSH_FXP_CLOSE, Size: 13, Number: 87300
> 2010-12-07 19:26:29.800 Type: SSH_FXP_SETSTAT, Size: 89, Number: 86793
< 2010-12-07 19:26:29.800 Type: SSH_FXP_STATUS, Size: 24, Number: 87046
< 2010-12-07 19:26:30.003 Type: SSH_FXP_STATUS, Size: 24, Number: 87300
< 2010-12-07 19:26:30.003 Status code: 0
< 2010-12-07 19:26:30.331 Type: SSH_FXP_STATUS, Size: 24, Number: 86793
< 2010-12-07 19:26:30.331 Status code: 0
. 2010-12-07 19:26:30.331 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:26:30.331 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:26:30.331 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:26:30.331 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:26:30.331 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:26:30.331 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:26:30.331 Binary transfer mode selected.
. 2010-12-07 19:26:30.331 Opening remote file.
> 2010-12-07 19:26:30.331 Type: SSH_FXP_OPEN, Size: 96, Number: 87555
< 2010-12-07 19:26:30.691 Type: SSH_FXP_HANDLE, Size: 13, Number: 87555
> 2010-12-07 19:26:30.691 Type: SSH_FXP_WRITE, Size: 4121, Number: 88070
. 2010-12-07 19:26:30.691 9 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-12-07 19:26:30.691 Type: SSH_FXP_CLOSE, Size: 13, Number: 89860
< 2010-12-07 19:26:30.691 Type: SSH_FXP_STATUS, Size: 24, Number: 88838
< 2010-12-07 19:26:30.691 Status code: 0
> 2010-12-07 19:26:30.691 Type: SSH_FXP_SETSTAT, Size: 92, Number: 87817
< 2010-12-07 19:26:30.691 Type: SSH_FXP_STATUS, Size: 24, Number: 89094
< 2010-12-07 19:26:30.691 Type: SSH_FXP_STATUS, Size: 24, Number: 89350
< 2010-12-07 19:26:30.988 Type: SSH_FXP_STATUS, Size: 24, Number: 89606
< 2010-12-07 19:26:30.988 Type: SSH_FXP_STATUS, Size: 24, Number: 89860
< 2010-12-07 19:26:30.988 Status code: 0
< 2010-12-07 19:26:31.456 Type: SSH_FXP_STATUS, Size: 24, Number: 87817
< 2010-12-07 19:26:31.456 Status code: 0
. 2010-12-07 19:26:31.456 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:26:31.456 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:26:31.456 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:26:31.456 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:26:31.456 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:26:31.456 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:26:31.456 Binary transfer mode selected.
. 2010-12-07 19:26:31.456 Checking existence of file.
> 2010-12-07 19:26:31.456 Type: SSH_FXP_LSTAT, Size: 78, Number: 90119
< 2010-12-07 19:26:32.206 Type: SSH_FXP_ATTRS, Size: 37, Number: 90119
. 2010-12-07 19:26:32.206 Checking existence of partially transfered file.
> 2010-12-07 19:26:32.206 Type: SSH_FXP_LSTAT, Size: 87, Number: 90375
< 2010-12-07 19:26:33.144 Type: SSH_FXP_STATUS, Size: 29, Number: 90375
< 2010-12-07 19:26:33.144 Status code: 2
. 2010-12-07 19:26:33.144 Opening remote file.
> 2010-12-07 19:26:33.144 Type: SSH_FXP_OPEN, Size: 103, Number: 90627
< 2010-12-07 19:26:34.206 Type: SSH_FXP_HANDLE, Size: 13, Number: 90627
> 2010-12-07 19:26:34.206 Type: SSH_FXP_WRITE, Size: 4121, Number: 91142
. 2010-12-07 19:26:34.238 69 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-12-07 19:26:34.238 Type: SSH_FXP_CLOSE, Size: 13, Number: 100356
< 2010-12-07 19:26:34.238 Type: SSH_FXP_STATUS, Size: 24, Number: 99846
< 2010-12-07 19:26:34.238 Type: SSH_FXP_STATUS, Size: 24, Number: 100102
< 2010-12-07 19:26:34.378 Type: SSH_FXP_STATUS, Size: 24, Number: 100356
< 2010-12-07 19:26:34.378 Status code: 0
> 2010-12-07 19:26:34.378 Type: SSH_FXP_REMOVE, Size: 78, Number: 100621
< 2010-12-07 19:26:35.113 Type: SSH_FXP_STATUS, Size: 24, Number: 100621
< 2010-12-07 19:26:35.113 Status code: 0
> 2010-12-07 19:26:35.113 Type: SSH_FXP_RENAME, Size: 160, Number: 100882
< 2010-12-07 19:26:38.316 Type: SSH_FXP_STATUS, Size: 24, Number: 100882
< 2010-12-07 19:26:38.316 Status code: 0
> 2010-12-07 19:26:38.316 Type: SSH_FXP_SETSTAT, Size: 94, Number: 90889
< 2010-12-07 19:26:40.050 Type: SSH_FXP_STATUS, Size: 24, Number: 90889
< 2010-12-07 19:26:40.050 Status code: 0
. 2010-12-07 19:26:40.050 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:26:40.050 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:26:40.050 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:26:40.050 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:26:40.050 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:26:40.050 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:26:40.050 Binary transfer mode selected.
. 2010-12-07 19:26:40.050 Checking existence of file.
> 2010-12-07 19:26:40.050 Type: SSH_FXP_LSTAT, Size: 77, Number: 101127
< 2010-12-07 19:26:40.769 Type: SSH_FXP_ATTRS, Size: 37, Number: 101127
. 2010-12-07 19:26:40.769 Checking existence of partially transfered file.
> 2010-12-07 19:26:40.769 Type: SSH_FXP_LSTAT, Size: 86, Number: 101383
< 2010-12-07 19:26:41.504 Type: SSH_FXP_STATUS, Size: 29, Number: 101383
< 2010-12-07 19:26:41.504 Status code: 2
. 2010-12-07 19:26:41.504 Opening remote file.
> 2010-12-07 19:26:41.504 Type: SSH_FXP_OPEN, Size: 102, Number: 101635
< 2010-12-07 19:26:42.925 Type: SSH_FXP_HANDLE, Size: 13, Number: 101635
> 2010-12-07 19:26:42.925 Type: SSH_FXP_WRITE, Size: 4121, Number: 102150
. 2010-12-07 19:26:42.957 45 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-12-07 19:26:42.957 Type: SSH_FXP_CLOSE, Size: 13, Number: 108292
< 2010-12-07 19:26:42.957 Type: SSH_FXP_STATUS, Size: 24, Number: 107782
< 2010-12-07 19:26:42.957 Type: SSH_FXP_STATUS, Size: 24, Number: 108038
< 2010-12-07 19:26:43.129 Type: SSH_FXP_STATUS, Size: 24, Number: 108292
< 2010-12-07 19:26:43.129 Status code: 0
> 2010-12-07 19:26:43.129 Type: SSH_FXP_REMOVE, Size: 77, Number: 108557
< 2010-12-07 19:26:43.457 Type: SSH_FXP_STATUS, Size: 24, Number: 108557
< 2010-12-07 19:26:43.457 Status code: 0
> 2010-12-07 19:26:43.457 Type: SSH_FXP_RENAME, Size: 158, Number: 108818
< 2010-12-07 19:26:45.300 Type: SSH_FXP_STATUS, Size: 24, Number: 108818
< 2010-12-07 19:26:45.300 Status code: 0
> 2010-12-07 19:26:45.300 Type: SSH_FXP_SETSTAT, Size: 93, Number: 101897
< 2010-12-07 19:26:46.863 Type: SSH_FXP_STATUS, Size: 24, Number: 101897
< 2010-12-07 19:26:46.863 Status code: 0
. 2010-12-07 19:26:46.863 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:26:46.863 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-12-07 19:26:46.863 TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-12-07 19:26:46.863 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-12-07 19:26:46.863 File: "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx"
. 2010-12-07 19:26:46.863 Copying "yyyyyyyyyyyyyyyyyyyyyyxxxxxxxx" to remote directory started.
. 2010-12-07 19:26:46.863 Binary transfer mode selected.
. 2010-12-07 19:26:46.863 Checking existence of file.
> 2010-12-07 19:26:46.863 Type: SSH_FXP_LSTAT, Size: 77, Number: 109063
< 2010-12-07 19:26:48.676 Type: SSH_FXP_ATTRS, Size: 37, Number: 109063
. 2010-12-07 19:26:48.676 Checking existence of partially transfered file.
> 2010-12-07 19:26:48.676 Type: SSH_FXP_LSTAT, Size: 86, Number: 109319
< 2010-12-07 19:26:49.191 Type: SSH_FXP_STATUS, Size: 29, Number: 109319
< 2010-12-07 19:26:49.191 Status code: 2
. 2010-12-07 19:26:49.191 Opening remote file.
> 2010-12-07 19:26:49.191 Type: SSH_FXP_OPEN, Size: 102, Number: 109571
< 2010-12-07 19:26:50.504 Type: SSH_FXP_HANDLE, Size: 13, Number: 109571
> 2010-12-07 19:26:50.504 Type: SSH_FXP_WRITE, Size: 4121, Number: 110086
. 2010-12-07 19:26:50.551 18 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-12-07 19:26:50.551 Type: SSH_FXP_CLOSE, Size: 13, Number: 112900
< 2010-12-07 19:26:50.551 Type: SSH_FXP_STATUS, Size: 24, Number: 112134
< 2010-12-07 19:26:50.551 Status code: 0
< 2010-12-07 19:26:50.551 Type: SSH_FXP_STATUS, Size: 24, Number: 112390
< 2010-12-07 19:26:50.691 Type: SSH_FXP_STATUS, Size: 24, Number: 112646
< 2010-12-07 19:26:50.707 Type: SSH_FXP_STATUS, Size: 24, Number: 112900
< 2010-12-07 19:26:50.707 Status code: 0
> 2010-12-07 19:26:50.707 Type: SSH_FXP_REMOVE, Size: 77, Number: 113165
< 2010-12-07 19:26:51.207 Type: SSH_FXP_STATUS, Size: 24, Number: 113165
< 2010-12-07 19:26:51.207 Status code: 0
> 2010-12-07 19:26:51.207 Type: SSH_FXP_RENAME, Size: 158, Number: 113426
< 2010-12-07 19:26:53.222 Type: SSH_FXP_STATUS, Size: 24, Number: 113426
< 2010-12-07 19:26:53.222 Status code: 0
> 2010-12-07 19:26:53.222 Type: SSH_FXP_SETSTAT, Size: 93, Number: 109833
< 2010-12-07 19:26:54.598 Type: SSH_FXP_STATUS, Size: 24, Number: 109833
< 2010-12-07 19:26:54.598 Status code: 0
. 2010-12-07 19:26:54.598 Copying 1 files/directories to remote directory "xxxxxxxxxxxxxxx"
. 2010-12-07 19:26:54.598 PrTime: Yes; PrRO:
endo56
Looks like the whole log can't be passed through a message. Is there a way to attach files?
thanks
First, I need a log file from 4.2.9!
You may email me the log file. You will find my address (if you log in) in my forum profile. Please include link back to this topic in your email. Also note in this topic that you have emailed the log.
