Topic "CCC - Clear Command Channel"
glauber
Would it be possible to implement the CCC command (RFC2228) to remove encryption from the command channel of an encrypted FTP connection after authentication?
There are a few servers, unfortunately, that require this.
Thank you,
glauber
Thanks for your post. This request has been added to tracker.
glauber
Thank you for considering this. I've been keeping a certain commercial product around just because of lack of support for this feature in open source products. CCC requirement is, unfortunately, rather common for FTP/SSL servers that interact with firewalls (because firewalls need to be able to read and respond to "PORT" commands).
If i may make a further suggestion, the way i see this could work, is a checkbox or advanced option to "turn off command channel encryption after authentication". There should never be a need to turn off encryption before authentication IMHO, and there should never be a need to turn off encryption on the data channel.
Thanks again,
glauber
banto
Did this get solved???
Does WinSCP support CCC?
glauber
Not yet.
g
banto
Not yet.
g
I found another program that supports CCC, everything is working, but I don't want to use that program. Btw, Filezilla does not support CCC either, they said there are to many security issues, like a hacker could overtake a session.
Any thoughts about this?
glauber
Thoughts?
(1) In a perfect world, we wouldn't need CCC, but this is not a perfect world.
(2) IMHO, that danger is overstated. Certainly the danger is less than with plain unencrypted FTP (which Filezilla is happy to support).
(3) The developer of Filezilla has very strong feelings about this and is not likely to change his mind. Filezilla is his app and he has the right to do what he wants with it. It's an excellent app if you don't need this feature.
jpadgett
Any chance this has been added to WinSCP since the last post?
Was not.
still not, I assume?
matej sk
Any chance this feature will be implemented? I would greatly appreciate being able to pass through application-aware firewalls.
Thanks.
Thanks.
I have raised priority of this request.
