Topic "Local timestamp one hour ahead in synchronize list"
gallde
Using: WinSCP V.4.2.8 Build 818 on Windows 7
Logged in via SFTP
Weird behavior: Timestamps are fine on normal listing, and file compare works fine. But when I do a Synchronize preview, the LOCAL files (on my PC) are listed as advanced by one hour, so no longer match the remote. The setting for DST in the session does not make a difference. I have tried to find a solution to this in the forums to no avail. Any help?
Thanks for your post. This bug is being tracked already.
gallde
I see the bug is fixed in 4.2.9. Where can I get that version?
I have sent you an email.
ds316
similar problem, assume the same:
- Client 4.2.8 running on W2K3 SP2
- Host is W2K8.
- Time and timezone exactly same both servers.
- Files have same timestamp on client and server, however winscp synchronisation script considers server files to be one hour ahead of the client side.
Is this the same issue, and if so how would I go about getting the 4.2.9 code?
ds316
Should add to the above:
- SFTP protocol.
- happens both from command line and from GUI.
- Host is W2K8.
ds316
Hi Martin, thanks a lot for quick reply, I've emailed you my findings.
johnstonj99
I am having a the same problem. Where do I download version 4.2.9?
Thanks!
It will be released shortly.
I have the same problem when synchronizig my win 7 pc on my Linux server.
Can you sent me the newest version 4.2.9 too, please?
pet
Can you send me the newst version 4.2.9 please
to solve my problem with synchronization of my Win7 PC with a Linux server?
niver
Using 4.2.9 on Win7 x64, I get the same problem as 4.2.8.
With 4.2.7, using the sftp protocol, everything is working, all timestamps are synchronized. When I upgrade to 4.2.9, all timestamps on the server are one hour behind the local timestamps, in both the file list and the Synchronize dialog.
The DST setting is set "Adjust remote timestamp to local conventions", but if I set it to "Adjust remote timestamp with DST", the problem becomes even worse, with a 2-hours difference between files that should have the same one.
The remote server is not on the same timezone than I, but this shouldn't make any difference for the SFTP protocol.
Did I do something wrong? Why is 4.2.9 different from 4.2.7 regarding timezones?
What if you upload new file? Would it have a correct timestamp? Also when talking about timestamps on the server, do you mean timestamp you see in the file panel or actual timestamp (e.g. in console)?
niver
Thanks for the heads up, I was simply assuming 4.2.7 was correct, while it was one hour off. A mere resync of the timestamps in 4.2.9 will likely fix my issue.
goog49
I'm using 4.3.3. same problem. Working it for a couple hours now. Can't find a way to enter the timezone offset in any 'login dialog'. That's as close as I got to a solution. The server only uses plain FTP, not SCP or SFTP. The server uses UTC, I'm using EDST.
http://winscp.net/eng/docs/ui_login_environment
