Topic "Re-read directory contents after each chdir -- feature req"
When I debug some script on unix it creates a lot of files.
FAR plugin caches directory contents so I shall press Ctrl-R for re-reading directory contents even when changing dir.
It will be nice to forcibly re-read directory after chdir if some option is set.
Thank you.
I use Far Plugin 1.6.2
You can disable the cache on Directories tab of login dialog.
I'll try it, thank you!
