Topic "Timeout in remote-local copy operation"
Adem
I have a QNAP TS-800 NAS in which I need to do copy operations (all in the NAS, i.e. from one directory in NAS to another directory in the same NAS).
If the copy operation takes sometime (it usually does, due to larger number of small files), WinSCP gets back to me with "host not responding for 15 secs" message.
And, there's only one option/button on that message: Abort.
The thing is, there is not reason to 'Abort' --if only it could re-check in that time, WinSCP would also find out that the NAS is alive.
Or, better still, if I could specify the time-out option somewhere, things would be much nicer.
WinSCP should dismiss the dialog once the server responds. Just wait long enough. If the dialog does not dismiss for you let me know.
Adem
It doesn't disappear.
In fact, I waited really really long; but it stayed on.
When I gave up and restarted, the operation had long finished.
