Topic "Problem passing/reading argument in Script file"
Arun
I have started using winscp for ftping file to a secure ftp site. since we have lots of files to ftped to diff ftp server in future , i wrote a script file which will accept argument passed in command line..
Here is the script :
---------------------------------- SFTP_Script.txt
option batch on
open %1% -hostkey=%2%
put %3%
My command line is like this :
winscp.com /script=SFTP_Script.txt /parameter "sftp://{username}:{passwd}@{servername}" /parameter "ssh-rsa 1024 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx" /parameter ":\data\test_sftp.txt"
When i run this command line , i get the error message :
----------------------------------error msg
Searching for host...
Host does not exist
batch on
confirm off
Connecting to host...
Authenticating...
Using username "ftp_rptsvcs".
Authenticated.
Starting the session...
Reading remote directory...
Session started.
Active session: [1] ftp_rptsvcs@10.254.4.170
File or folder '%3' does not exist.
System Error. Code: 2.
The system cannot find the file specified
Not sure what the reason for the error is. can anyone please help me on this
PS :
But when i run the following script from command line , where i do have only 2 arguments , it runs perfectly.
-------------------------------SFTP_Script_old.txt
option batch on
put c:\data\test_sftp.txt
Arun
small correction to my post. my command line is like this :
winscp.com /script=SFTP_Script.txt /parameter "sftp://{username}:{passwd}@{servername}" /parameter "ssh-rsa 1024 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx" /parameter "c:\data\test_sftp.txt"
corrected stated the 3rd argument.
Arun
Use the /parameter switch only once.
Arun
Thanks for your reply. I tried as u said :
winscp.com /script=SFTP_Script.txt /parameter "sftp://{username}:{passwd}@{servername}" "ssh-rsa 1024 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx" "c:\data\test_sftp.txt"
If i run the above command line , i get the following error msg.
batch on
confirm off
Too many parameters for command 'open'.
No session.
we should put /parameter for each argument we pass?
Put double quotes around parameter references, particularly around %2%.
