Topic "Handling filenames with spaces"
mazott
I believe this is an already answered question but here it goes.
I should upload a set of files whose names contain space characters. The upload is from a Windows host running WinSCP to a Unix ftp sever.
The obvious problem is that the Unix host doesn't allow writing filenames of such kind. More in general, using a vanilla command line ftp client I would use quoting the names in my put commands. How could I do that using WinSCP?
Thank you, Marco
You can quote them in WinSCP too. Supposing you are using scripting interface of WinSCP.
mazott
Actually, I'm not quoting. As I found that scripting can be done, that is the likely solution I was looking for. Thank you for reply so far.
Vichu
I am getting file not found error when I try the following cmd
winscp.com /console /command "option batch on" "option confirm off" "open user:pwd@myServer" "cd Upload" "put My SFTPTest.txt" "exit" /log="C:\temp\Winscp.l
winscp.com /console /command "option batch on" "option confirm off" "open user:pwd@myServer" "cd Upload" "put ""My SFTPTest.txt""" "exit" /log="C:\temp\Winscp.log"
Please read
http://winscp.net/eng/docs/scripting#syntax
