Topic "How to accept adding the key to the cache ?"
eniosp
I am using the version 4.2.7 on Windows XP SP3.
I am try to run the following command.
"C:\Program Files\WinSCP\winscp.com" usr:pass@server /hostkey="ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx" /console /command "Option batch abort" "cd /home/internal/test" "Put -delete ""c:\temp\File1.pdf""" "Put -delete ""c:\temp\File1.csv""" "Put -delete ""c:\temp\File1.rdy""" "close" "exit"
I have the following output:
Quote:
C:\>"C:\Program Files\WinSCP\winscp.com" usr:pass@server /hostkey="ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx" /console /command "Option batch abort" "cd /home/internal/test" "Put -delete ""c:\temp\File1.pdf""" "Put -delete ""c:\temp\File1.csv""" "Put -delete ""c:\temp\File1.rdy""" "close" "exit"
Searching for host...
Connecting to host...
Authenticating...
The server's host key was not found in the cache. You have no guarantee that the
server is the computer you think it is.
The server's dss key fingerprint is:
ssh-dss 1024 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx
If you trust this host, press Yes. To connect without adding host key to the cac
he, press No. To abandon the connection press Cancel.
Continue connecting and add host key to the cache?
(Y)es, (N)o, C(a)ncel, (C)opy Key:
Is there a way to automatically accept it ?
I've tried the option bellow. But instead of continuing Cancel is chosen.
Quote:
C:\>"C:\Program Files\WinSCP\winscp.com" /console /command "Option batch continue" "open sftp://usr:pass@server -hostkey=""ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx""" "cd /home/internal/test" "Put -delete ""c:\temp\File1.pdf""" "Put -delete ""c:\temp\File1.csv""" "Put -delete ""c:\temp\File1.rdy""" "close" "exit"
batch continue
Authenticating...
(Y)es, (N)o, C(a)ncel, (C)opy Key: Cancel
Host key wasn't verified!
Authentication failed.
No session.
No session.
No session.
No session.
No session.
Many thanks
eniosp
I've checked the documents but I could not make it work.
I've new tests now but I did not work:
Without batch option:
C:\>"C:\Program Files\WinSCP\winscp.com" /console /command "open sftp://usr:pass@host -hostkey=""ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx""" "close" "exit"
Authenticating...
ssh-dss 1024 eb:0d:68:30:8c:ef:2c:15:4d:b4:36:e1:51:e6:8b:fe
With batch option continue:
e" "open sftp://usr:pass@host -hostkey=""ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx""" "close" "exit"
batch           continue
Authenticating...
No session.
C:\>
Many thanks,
Enio
You need to put real key fingerprint into hostkey switch.
eniosp
Hi prikryl,
I've put it it was replaced by xx.xx. I can send you the logs without "masking".
eniosp
eniosp wrote:
Hi prikryl,
I just send an email with complete log.
eniosp2
There is no issue here. Only the fingerprint did change.
I did not pay attention on the fingerprint value and thought there was an issue.
Thanks for the support.
Cheers,
dangfitz
I'm getting the key has changed message. I tried -hostkey & -certificate, but I keep getting the error, "too many parameters for command 'open'."
option batch on
open userid:passwd@server -hostkey="ssh-rsa 1024 xx:xx:xx..."
Make sure you are using the latest version.
Dhirendra
Hi.
I am able to connect it using the C# code with private key authentication. But when I execute this via window service it giving the same error. What do we do now? Please help me, my peers are asking "why did you use this tool?". What should I pass while opening the connection.
I am using 4.3.2 version....
Thanks in advace...
Dhirendra Misra
Please read FAQ:
http://winscp.net/eng/docs/faq_scheduler
ETLEngineer
I had the same problem; if you're using SQL Server Agent to execute your job\script and receiving the following message. You must logon to the server remotely with the userid:ServerAminID and execute WinScp software, login to the ftp site, wait for prompt requesting to cache the host key; once the key is accepted you can execute thru SQL Server Agent
If you trust this host, press Yes. To connect without adding host key to the cache, press No. To abandon the connection press Cancel.
Continue connecting and add host key to the cache? ()
Correct approach would be to use -hostkey switch of open command:
http://winscp.net/eng/docs/scriptcommand_open
LalitKukreja
Hi All,
The automated script is working in 6 out of 10 runs. Below are the messages that are received in success and failure scenarios.
Success Message:
Executed as user: AccountName\UserID C:\Windows\system32>echo offbatch abort confirm off Searching for host...Connecting to host...Authenticating...Using username "UserID". Authenticating with pre-entered password.Authenticated. Starting the session...Reading remote directory...Session started. Active session: Other details
Now the failure message:
Message
Executed as user: AccountName\UserID. C:\Windows\system32>echo offbatch abort confirm off Searching for host... Connecting to host...Authenticating... The server's host key was not found in the cache. You have no guarantee that the server is the computer you think it is. The server's rsa2 key fingerprint is: ssh-rsa XXXX xx:xx:xx:xx:xx:xx:xx:xx:xx:xx If you trust this host, press Yes. To connect without adding host key to the cache, press No. To abandon the connection press Cancel. Continue connecting and add host key to the cache? (Y)es, (N)o, C(a)ncel, (C)opy Key: Cancel Host key wasn't verified! Host key fingerprint is ssh-rsa XXXX xx:xx:xx:xx:xx:xx:xx:xx:xx:xx Authentication failed.
Any help on this please?
Duplicate post:
http://winscp.net/forum/viewtopic.php?t=14602
