Topic "Host does not exist error in SSIS"
I developed a script:
option batch on
open <session name>
cd <directory containing remote file>
get <remote file name> <local path>
When I run open <session name> from the command window, it connects just fine. When I run the script in the Execute Process Task of SSIS, it prints:
Searching for host...
Host does not exist
Here is the excerpt from the log:
. 2010-08-12 17:54:56.459 --------------------------------------------------------------------------
. 2010-08-12 17:54:56.459 WinSCP Version 4.2.8 (Build 818) (OS 5.2.3790 Service Pack 2)
. 2010-08-12 17:54:56.459 Login time: Thursday, August 12, 2010 5:54:56 PM
. 2010-08-12 17:54:56.459 Session name: D
. 2010-08-12 17:54:56.459 Host name: D (Port: -1)
. 2010-08-12 17:54:56.459 User name: (Password: No, Key file: No)
. 2010-08-12 17:54:56.459 Tunnel: No
. 2010-08-12 17:54:56.459 Transfer Protocol: SFTP (SCP)
. 2010-08-12 17:54:56.459 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2010-08-12 17:54:56.459 Proxy: none
. 2010-08-12 17:54:56.459 SSH protocol version: 2; Compression: No
. 2010-08-12 17:54:56.459 Bypass authentication: No
. 2010-08-12 17:54:56.459 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2010-08-12 17:54:56.459 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2010-08-12 17:54:56.459 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2010-08-12 17:54:56.459 SFTP Bugs: -,-
. 2010-08-12 17:54:56.459 Return code variable: Autodetect; Lookup user groups: Yes
. 2010-08-12 17:54:56.459 Shell: default
. 2010-08-12 17:54:56.459 EOL: 0, UTF: 2
. 2010-08-12 17:54:56.459 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2010-08-12 17:54:56.459 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2010-08-12 17:54:56.459 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-08-12 17:54:56.459 Cache directory changes: Yes, Permanent: Yes
. 2010-08-12 17:54:56.459 DST mode: 1
. 2010-08-12 17:54:56.459 Looking up host "D"
Jason
niffer76
I am getting the same error. I am trying to automate the upload of a file to a STFP server. The script that I have created works just fine from a command prompt, but when I set up the Execute Process Task in SSIS, I just get the error message that the Server Host does not exist. I am using WinSCP 4.2.9.
I have set up the Argument as follows:
Arguments: -script = C:\mylocaldir\script.txt
Any ideas on how to get this to work???
Have you read the FAQ referenced above?
bkamal
Hey, this FAQ didn't help me, i am still having the same issues, i am running the task on my remote desktop, winscp connects to the host fine but ssis does not
Sorry, your post does not include enough information.
Please read how to troubleshoot problems with WinSCP. If it turns out that you are not able to help yourself, read how to ask for support or report bugs efficiently, so others can help you.
See also http://winscp.net/eng/docs/faq_script_vs_gui
